74ALVCH16501
18-bit universal bus transceiver; 3-state
Rev. 7 — 24 November 2021
Product data sheet
1. General description
The 74ALVCH16501 is an 18-bit universal transceiver with bus hold inputs and 3-state outputs.
Data flow in each direction is controlled by output enable (OEAB and OEBA), latch enable (LEAB
and LEBA), and clock (CPAB and CPBA) inputs. For A-to-B data flow, the device operates in the
transparent mode when LEAB is HIGH. When LEAB is LOW, the A data is latched if CPAB is held
at a HIGH or LOW logic level. If LEAB is LOW, the A-bus data is stored in the latch/flip-flop on the
LOW-to-HIGH transition of CPAB. When OEAB is HIGH, the outputs are active. When OEAB is
LOW, the outputs are in the high-impedance state. Data flow for B-to-A is similar to that of A-to-B
but uses OEBA, LEBA and CPBA. The output enables are complimentary (OEAB is active HIGH
and OEBA is active LOW). This device is fully specified for partial power down applications using
IOFF. The IOFF circuitry disables the output, preventing the potentially damaging backflow current
through the device when it is powered down.
2. Features and benefits
Wide supply voltage range from 1.2 V to 3.6 V
CMOS low power dissipation
Direct interface with TTL levels
Current drive ±24 mA at VCC = 3.0 V
Universal bus transceiver with D-type latches and D-type flip-flops capable of operating in
transparent, latched or clocked mode
Bus hold on all data inputs
Output drive capability 50 Ω transmission lines at 85 °C
3-state non-inverting outputs for bus-oriented applications
Latch-up performance exceeds 100 mA per JESD78 Class II Level B
Complies with JEDEC standards:
• JESD8-7 (1.65 V to 1.95 V)
• JESD8-5 (2.3 V to 2.7 V)
• JESD8C (2.7 V to 3.6 V)
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-B exceeds 200 V
Specified from -40 °C to +85 °C
3. Ordering information
Table 1. Ordering information
Type number
Package
74ALVCH16501DGG
Temperature range
Name
Description
Version
-40 °C to +85 °C
TSSOP56
plastic thin shrink small outline package;
56 leads; body width 6.1 mm
SOT364-1
74ALVCH16501
Nexperia
4. Functional diagram
OEAB
CPAB
LEAB
OEBA
3
5
6
8
9
10
12
13
14
15
16
17
19
23
24
26
1
2
55
Fig. 1.
A0
B0
A1
B1
A2
B2
A3
B3
A4
B4
A5
B5
A6
B6
A7
B7
A8
B8
A9
B9
A10
B10
A11
B11
A12
B12
A13
B13
A14
B14
A15
B15
A16
B16
A17
B17
OEAB
OEBA
LEAB
LEBA
CPAB
CPBA
CPBA
54
LEBA
52
1
55
2
27
30
28
EN1
2C3
C3
G2
EN4
5C6
C6
G5
51
49
A0
48
47
A1
45
A2
44
A3
43
A4
42
A5
41
A6
40
A7
38
A8
37
A9
36
A10
34
A11
33
A12
31
A13
A14
27
A15
28
A16
30
A17
3
5
3D
1
1
4
1
6D
54
52
6
51
8
49
9
48
10
47
12
45
13
44
14
43
15
42
16
41
17
40
19
38
21
36
23
34
24
33
26
31
001aal718
B0
B1
B2
B3
B4
B5
B6
B7
B8
B9
B10
B11
B12
B13
B14
B15
B16
B17
001aal717
Logic symbol
Fig. 2.
IEC logic symbol
VCC
data input
to internal circuit
001aal733
Fig. 3.
Bus hold circuit
74ALVCH16501
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 15
74ALVCH16501
Nexperia
OEAB
CPBA
LEBA
CPAB
LEAB
OEBA
A1
C1
C1
1D
1D
C1
C1
1D
1D
B1
18 IDENTICAL CHANNELS
001aal719
Fig. 4.
Logic diagram
74ALVCH16501
Product data sheet
3 / 15
74ALVCH16501
Nexperia
5. Pinning information
5.1. Pinning
74ALVCH16501
OEAB
1
56 GND
LEAB
2
55 CPAB
A0
3
54 B0
GND
4
53 GND
A1
5
52 B1
A2
6
51 B2
VCC
7
50 VCC
A3
8
49 B3
A4
9
48 B4
A5 10
47 B5
GND 11
46 GND
A6 12
45 B6
A7 13
44 B7
A8 14
43 B8
A9 15
42 B9
A10 16
41 B10
A11 17
40 B11
GND 18
39 GND
A12 19
38 B12
A13 20
37 B13
A14 21
36 B14
VCC 22
35 VCC
A15 23
34 B15
A16 24
33 B16
GND 25
32 GND
A17 26
31 B17
OEBA 27
30 CPBA
LEBA 28
29 GND
001aal716
Fig. 5.
Pin configuration SOT364-1 (TSSOP56)
74ALVCH16501
Product data sheet
4 / 15
74ALVCH16501
Nexperia
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
OEAB
1
output enable A-to-B input (active HIGH)
LEAB
2
latch enable A-to-B input
A0 to A17
3, 5, 6, 8, 9, 10, 12, 13, 14, 15, 16, 17,
19, 20, 21, 23, 24, 26
data inputs or outputs
GND
4, 11, 18, 25, 29, 32, 39, 46, 53, 56
ground (0 V)
VCC
7, 22, 35, 50
positive supply voltage
OEBA
27
output enable B-to-A (active LOW)
LEBA
28
latch enable B-to-A
CPBA
30
clock input B-to-A
B0 to B17
54, 52, 51, 49, 48, 47, 45, 44, 43, 42, 41, 40,
38, 37, 36, 34, 33, 31
CPAB
55
clock input A-to-B
6. Functional description
Table 3. Function table
A-to-B data flow is shown; B-to-A flow is similar but uses OEBA, LEBA and CPBA.
H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the enable or clock transition;
L = LOW voltage level; l = LOW voltage level one set-up time prior to the enable or clock transition;
X = don’t care; Z = high-impedance OFF-state;
↓ = HIGH-to-LOW clock transition; ↑ = LOW-to-HIGH clock transition.
Output
Inputs
Operating mode
OEAB
LEAB
CPAB
An
Bn
L
X
X
X
Z
disabled
H
H
X
H
H
transparent
H
H
X
L
L
H
X
h
H
H
X
l
L
H
L
h
H
H
L
l
L
H
L
H or L
X
H
H
L
H or L
X
L
74ALVCH16501
Product data sheet
latch data and display
clock data and display
hold data and display
5 / 15
74ALVCH16501
Nexperia
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+4.6
V
-50
VCC
supply voltage
IIK
input clamping current
VI < 0 V
VI
input voltage
control inputs
[1]
-0.5
data inputs
[1]
-0.5
IOK
output clamping current
VO
output voltage
IO
output current
ICC
IGND
VO > VCC or VO < 0 V
+4.6
±50
-0.5
mA
VCC + 0.5 V
±50
mA
supply current
100
mA
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
VO = 0 V to VCC
V
VCC + 0.5 V
[1]
mA
Tamb = -40 °C to +85 °C
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
VCC
supply voltage
Min
Typ
Max
Unit
CL = 30 pF
2.3
2.7
V
CL = 50 pF
3.0
3.6
V
low-voltage applications
1.2
3.6
V
maximum speed performance
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
in free air
-40
+85
°C
Δt/ΔV
input transition rise and fall rate
VCC = 2.3 V to 3.0 V
ns/V
VCC = 3.0 V to 3.6 V
ns/V
74ALVCH16501
Product data sheet
6 / 15
74ALVCH16501
Nexperia
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Typ [1]
Max
Unit
V
VIH
HIGH-level input
voltage
VCC = 2.3 V to 2.7 V
1.7
1.2
VCC = 2.7 V to 3.6 V
2.0
1.5
V
VIL
LOW-level input
voltage
1.2
0.7
V
1.5
0.8
V
HIGH-level output
voltage
VI = VIH or VIL
IO = -100 μA; VCC = 2.3 V to 3.6 V
VCC - 0.2
VCC
V
IO = -6 mA; VCC = 2.3 V
VCC - 0.3 VCC - 0.08
V
IO = -12 mA; VCC = 2.3 V
VCC - 0.6 VCC - 0.26
V
IO = -12 mA; VCC = 2.7 V
VCC - 0.5 VCC - 0.14
V
IO = -12 mA; VCC = 3.0 V
VCC - 0.6 VCC - 0.09
V
IO = -24 mA; VCC = 3.0 V
VCC - 1.0 VCC - 0.28
V
VOH
VOL
LOW-level output
voltage
VI = VIH or VIL
IO = 100 μA; VCC = 2.3 V to 3.6 V
GND
0.20
V
IO = 6 mA; VCC = 2.3 V
0.07
0.40
V
IO = 12 mA; VCC = 2.3 V
0.15
0.70
V
IO = 12 mA; VCC = 2.7 V
0.14
0.40
V
IO = 24 mA; VCC = 3.0 V
0.27
0.55
V
II
input leakage current
VI = VCC or GND; VCC = 2.3 V to 3.6 V
0.1
5
μA
IOZ
OFF-state output
current
VI = VIH or VIL; VO = VCC or GND;
0.1
10
μA
ICC
supply current
VCC = 2.3 V to 3.6 V; VI = VCC or GND;
IO = 0 A
0.2
40
μA
ΔICC
additional supply
current
per data I/O pin; VCC = 2.3 V to 3.6 V;
VI = VCC - 0.6 V; IO = 0 A
150
750
μA
IBHL
bus hold LOW current VCC = 2.3 V; VI = 0.7 V
[2]
45
μA
VCC = 3.0 V; VI = 0.8 V
[2]
75
150
μA
IBHH
bus hold HIGH
current
VCC = 2.3 V; VI = 1.7 V
[2]
-45
μA
VCC = 3.0 V; VI = 2.0 V
[2]
-75
-175
μA
IBHLO
bus hold LOW
overdrive current
VCC = 3.6 V
[2]
500
μA
IBHHO
bus hold HIGH
overdrive current
VCC = 3.6 V
[2]
-500
μA
CI
input capacitance
4.0
pF
CI/O
input/output
capacitance
8.0
pF
[1]
[2]
All typical values are measured at Tamb = 25 °C.
Valid for data inputs of bus hold parts only.
74ALVCH16501
Product data sheet
7 / 15
74ALVCH16501
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 10.
Symbol Parameter
Conditions
Min
Typ [1]
Max
Unit
fmax
maximum frequency
see Fig. 8
[2]
150
333
MHz
[3]
150
340
MHz
150
333
MHz
VCC = 2.7 V
tpd
propagation delay
An to Bn; Bn to An; see Fig. 6
[4]
[2]
1.0
2.8
5.1
ns
[3]
1.0
3.0
4.2
ns
3.0
4.6
ns
VCC = 2.7 V
LEAB, LEBA to Bn, An; see Fig. 8
[2]
1.1
3.5
6.1
ns
[3]
1.3
3.4
4.8
ns
3.6
5.3
ns
VCC = 2.7 V
CPAB, CPBA to Bn, An; see Fig. 8
[2]
1.0
3.3
6.1
ns
[3]
1.4
3.3
4.9
ns
3.4
5.6
ns
VCC = 2.7 V
ten
enable time
OEBA to An; see Fig. 7
[4]
[2]
1.3
2.8
6.3
ns
[3]
1.1
2.5
5.0
ns
3.3
6.0
ns
VCC = 2.7 V
OEAB to Bn; see Fig. 7
[2]
1.0
2.5
5.8
ns
[3]
1.0
2.4
4.6
ns
2.7
5.3
ns
VCC = 2.7 V
tdis
disable time
[4]
[2]
1.3
2.5
5.3
ns
[3]
1.3
3.1
4.2
ns
3.3
4.6
ns
VCC = 2.7 V
[2]
1.5
2.5
6.2
ns
[3]
1.4
2.9
5.0
ns
3.6
5.7
ns
VCC = 2.7 V
74ALVCH16501
Product data sheet
8 / 15
74ALVCH16501
Nexperia
Symbol Parameter
Conditions
tW
LEAB, LEBA HIGH; see Fig. 8
pulse width
Min
Typ [1]
Max
Unit
[2]
3.3
0.8
ns
[3]
3.3
0.9
ns
3.3
0.7
ns
VCC = 2.7 V
CPAB, CPBA HIGH or LOW; see Fig. 8
[2]
3.3
2.0
ns
[3]
3.3
1.1
ns
3.3
1.4
ns
VCC = 2.7 V
tsu
set-up time
An, Bn to CPAB, CPBA; see Fig. 9
[2]
1.7
0.1
ns
[3]
1.3
-0.3
ns
1.4
-0.1
ns
VCC = 2.7 V
An, Bn to LEAB, LEBA; see Fig. 9
[2]
1.1
0.1
ns
[3]
1.0
0.3
ns
1.0
-0.2
ns
VCC = 2.7 V
th
hold time
[2]
1.7
0.3
ns
[3]
1.3
0.4
ns
1.6
0.3
ns
VCC = 2.7 V
[2]
1.6
0.3
ns
[3]
1.2
0.1
ns
1.5
0.1
ns
outputs enabled
21
pF
outputs disabled
3
pF
VCC = 2.7 V
power dissipation capacitance per buffer; VI = GND to VCC
CPD
[1]
[2]
[3]
[4]
[5]
[5]
Typical values are measured at VCC = 2.5 V.
Typical values are measured at VCC = 3.3 V.
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in Volts;
N = total load switching outputs;
2
Σ(CL × VCC × fo) = sum of outputs.
74ALVCH16501
Product data sheet
9 / 15
74ALVCH16501
Nexperia
10.1. Waveforms and test circuit
VI
An, Bn
input
VM
VM
tPHL
tPLH
GND
VOH
Bn, An
output
VM
VM
VOL
001aal734
Measurement points are given in Table 8.
VOL and VOH are typical output levels that occur with the output load.
Fig. 6.
Propagation delay, data input (An, Bn) to data output (Bn, An)
VI
OEAB, OEBA
input
VM
VM
GND
tPLZ
An, Bn output
LOW-to-OFF
OFF-to-LOW
tPZL
VCC
VM
VX
VOL
tPZH
tPHZ
An, Bn output
HIGH-to-OFF
OFF-to-HIGH
VOH
VY
VM
GND
outputs
enabled
outputs
disabled
outputs
enabled
001aal721
Fig. 7.
3-state output enable and disable times
1 / fmax
VI
LExx
input
CPxx
input GND
An, Bn
output
VOH
VM
VM
VM
tW
tPLH
tPHL
VM
VOL
VM
001aal720
Fig. 8.
Propagation delay, latch enable input (LEAB, LEBA) and clock pulse input (CPAB, CPBA) to data output,
and pulse width
74ALVCH16501
Product data sheet
10 / 15
74ALVCH16501
Nexperia
VI
An, Bn
input
VM
VM
GND
tsu
VM
th
VM
tsu
th
VI
CPxx, LExx
input
VM
VM
GND
001aal722
Fig. 9.
Data set-up and hold times (An, Bn inputs to LEAB, LEBA, CPAB and CPBA inputs)
Table 8. Measurement points
Supply voltage
Input
Output
VCC
VI
VM
VM
VX
VY
1.2 V
VCC
0.5 × VCC
0.5 × VCC
VOL + 0.15 V
VOH - 0.15 V
1.8 V
VCC
0.5 × VCC
0.5 × VCC
VOL + 0.15 V
VOH - 0.15 V
2.3 V to 2.7 V
VCC
0.5 × VCC
0.5 × VCC
VOL + 0.15 V
VOH - 0.15 V
2.7 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
3.0 V to 3.6 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
mna616
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance includes jig and probe capacitance.
RT = Termination resistance should be equal to Zo of pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 10. Test circuit for measuring switching times
Table 9. Test data
Supply voltage
Input
VCC
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
1.2 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2 × VCC
GND
1.8 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2 × VCC
GND
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2 × VCC
GND
2.7 V
2.7 V
2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
3.0 V to 3.6 V
2.7 V
2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
74ALVCH16501
Product data sheet
Load
VEXT
11 / 15
74ALVCH16501
Nexperia
11. Package outline
TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm
SOT364-1
E
D
A
X
c
HE
y
v M A
Z
56
29
Q
A2
(A 3 )
A1
pin 1 index
A
θ
Lp
L
1
28
w M
bp
e
detail X
2.5
5 mm
scale
DIMENSIONS (mm are the original dimensions).
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z
θ
mm
1.2
0.15
0.05
1.05
0.85
0.25
0.28
0.17
0.2
0.1
14.1
13.9
6.2
6.0
0.5
8.3
7.9
1
0.8
0.4
0.50
0.35
0.25
0.08
0.1
0.5
0.1
8
o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT364-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig. 11. Package outline SOT364-1 (TSSOP56)
74ALVCH16501
Product data sheet
12 / 15
74ALVCH16501
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74ALVCH16501 v.7
20211124
Product data sheet
74ALVCH16501 v.6
Modifications:
74ALVCH16501 v.6
20190313
74ALVCH16501 v.5
Modifications:
Section 1 and Section 2 updated.
Errata corrected in Table 4.
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type numbers 74ALVCH16501DL (SOT371-1) removed.
74ALVCH16501 v.5
20120710
Modifications:
74ALVCH16501 v.4
20111117
Modifications:
74ALVCH16501 v.3
20100402
74ALVCH16501 v.2
19980929
74ALVCH16501 v.1
19980929
74ALVCH16501
Product data sheet
Product data sheet
Product data sheet
74ALVCH16501 v.4
74ALVCH16501 v.3
Product data sheet
74ALVCH16501 v.2
Product specification
74ALVCH16501 v.1
Table 8 corrected (errata).
Product data sheet
Legal pages updated.
13 / 15
74ALVCH16501
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74ALVCH16501
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
14 / 15
74ALVCH16501
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................4
5.1. Pinning.........................................................................4
5.2. Pin description............................................................. 5
6. Functional description................................................. 5
7. Limiting values............................................................. 6
8. Recommended operating conditions..........................6
9. Static characteristics....................................................7
10. Dynamic characteristics............................................ 8
10.1. Waveforms and test circuit...................................... 10
11. Package outline........................................................ 12
12. Abbreviations............................................................ 13
13. Revision history........................................................13
14. Legal information......................................................14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 24 November 2021
74ALVCH16501
Product data sheet
15 / 15
