74ALVC162334A
16-bit registered driver with inverted register enable and 30 Ω
termination resistors (3-state)
Rev. 03 — 13 December 2006
Product data sheet
1. General description
The 74ALVC162334A is a 16-bit universal bus driver. Data flow is controlled by
active LOW output enable (OE), active LOW latch enable (LE), and clock input (CP).
When LE is LOW, the A to Y data flow is transparent. When LE is HIGH and CP is held at
LOW or HIGH, the data is latched; on the LOW to HIGH transient of CP, the A data is
stored in the latch/flip-flop.
The 74ALVC162334A is designed with 30 Ω series resistors in both HIGH or LOW output
stages.
When OE is LOW, the outputs are active. When OE is HIGH, the outputs go to the
high-impedance OFF-state. Operation of the OE input does not affect the state of the
latch/flip-flop.
To ensure the high-impedance state during power-up or power-down, OE should be tied to
VCC through a pull-up resistor; the minimum value of the resistor is determined by the
current-sinking capability of the driver.
2. Features
n
n
n
n
n
n
n
n
n
n
Wide supply voltage range of 1.2 V to 3.6 V
Complies with JEDEC standard 8-1A
CMOS low power consumption
Direct interface with TTL levels
Current drive: ±24 mA at 3.0 V
MULTIBYTE flow-through standard pinout architecture
Low inductance multiple VCC and GND pins for minimum noise and ground bounce
Output drive capability 50 Ω transmission lines at 85 °C
Integrated 30 Ω termination resistors
Input diodes to accommodate strong drivers
74ALVC162334A
Nexperia
16-bit registered driver (3-state)
3. Quick reference data
Table 1.
VCC = 3.3 V ± 0.3 V; GND = 0 V; tr = tf ≤ 2.5 ns; CL = 50 pF (see Figure 11).
Symbol
Parameter
Conditions
Min
Typ[1]
Max
Unit
tPHL
HIGH-to-LOW propagation delay
An to Yn; Figure 5
1.0
2.8
4.3
ns
LOW-to-HIGH propagation delay
tPLH
fmax
maximum input clock frequency
Ci
input capacitance
Cio
input/output capacitance
power dissipation capacitance
CPD
LE to Yn; Figure 6
1.3
2.8
4.4
ns
CP to Yn; Figure 8
1.4
3.2
4.9
ns
An to Yn; Figure 5
1.0
2.8
4.3
ns
LE to Yn; Figure 6
1.3
2.8
4.4
ns
CP to Yn; Figure 8
1.4
3.2
4.9
ns
Figure 8
150
240
MHz
4.0
pF
8.0
pF
transparent mode; output enabled
10
pF
transparent mode; output disabled
3
pF
clocked mode; output enabled
21
pF
clocked mode; output disabled
15
pF
per buffer; VI = GND to VCC
[1]
All typical values are at Tamb = 25 °C.
[2]
CPD is used to determine the dynamic power dissipation (PD) in µW.
PD = CPD × VCC2 × fi + Σ (CL × VCC2 × fo), where:
fi = input frequency in MHz;
CL = output load capacitance in pF;
fo = output frequency in MHz;
VCC = supply voltage in V;
Σ (CL × VCC2 × fo) = sum of outputs.
[2]
4. Ordering information
Table 2.
Type number
74ALVC162334ADGG
Temperature
range
Package
Name
Description
Version
−40 °C to +85 °C
TSSOP48
plastic thin shrink small outline package;
48 leads; body width 6.1 mm
SOT362-1
74ALVC162334A_3
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 19
74ALVC162334A
Nexperia
5. Functional diagram
1
OE
48
CP
25
LE
Y1
Y2
Y3
Y4
Y5
Y6
Y7
Y8
Y9
Y10
Y11
Y12
Y13
Y14
Y15
Y16
EN1
2C3
C3
G2
2
3
5
6
8
9
11
12
13
14
16
17
19
23
1
1
3D
47
46
44
43
41
40
38
37
36
35
33
32
30
29
27
26
A1
A2
A3
A4
A5
A6
A7
A8
A9
A10
A11
A12
A13
A14
A15
A16
002aac723
Fig 1. Logic symbol (IEEE/IEC)
OE
CP
LE
A1
D
LE
CP
Y1
to the 15 other channels
002aac724
Fig 2. Logic diagram
VCC
A1
002aac725
Fig 3. Typical input (data or control)
74ALVC162334A_3
Product data sheet
3 of 19
74ALVC162334A
Nexperia
6. Pinning information
6.1 Pinning
OE
1
48 CP
Y1
2
47 A1
Y2
3
46 A2
GND
4
45 GND
Y3
5
44 A3
Y4
6
43 A4
VCC
7
Y5
8
42 VCC
41 A5
Y6
9
40 A6
GND 10
39 GND
Y7 11
Y8 12
Y9 13
38 A7
74ALVC162334ADGG
37 A8
36 A9
Y10 14
35 A10
GND 15
34 GND
Y11 16
33 A11
Y12 17
32 A12
VCC 18
Y13 19
31 VCC
30 A13
Y14 20
29 A14
GND 21
28 GND
Y15 22
27 A15
Y16 23
26 A16
n.c. 24
25 LE
002aac722
Fig 4. Pin configuration for TSSOP48
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
OE
1
output enable input (active LOW)
Y1
2
data output 1
Y2
3
data output 2
GND
4, 10, 15, 21,
28, 34, 39, 45
ground supply (0 V)
Y3
5
data output 3
Y4
6
data output 4
VCC
7, 18, 31, 42
positive supply voltage
Y5
8
data output 5
Y6
9
data output 6
Y7
11
data output 7
Y8
12
data output 8
74ALVC162334A_3
Product data sheet
4 of 19
74ALVC162334A
Nexperia
Table 3.
Pin description …continued
Symbol
Pin
Description
Y9
13
data output 9
Y10
14
data output 10
Y11
16
data output 11
Y12
17
data output 12
Y13
19
data output 13
Y14
data output 14
Y15
22
data output 15
Y16
23
data output 16
n.c.
24
not connected
LE
25
latch enable input (active LOW)
A16
26
data input 16
A15
27
data input 15
A14
29
data input 14
A13
30
data input 13
A12
32
data input 12
A11
33
data input 11
A10
35
data input 10
A9
36
data input 9
A8
37
data input 8
A7
38
data input 7
A6
40
data input 6
A5
41
data input 5
A4
43
data input 4
A3
44
data input 3
A2
46
data input 2
A1
47
data input 1
CP
48
clock input
74ALVC162334A_3
Product data sheet
5 of 19
74ALVC162334A
Nexperia
7. Functional description
Refer to Figure 1 “Logic symbol (IEEE/IEC)” and Figure 2 “Logic diagram”.
7.1 Function selection
Table 4.
Function selection
H = HIGH voltage level; L = LOW voltage level; X = Don’t care; Z = high-impedance OFF-state;
↑ = LOW to HIGH level transition.
Inputs
Outputs
OE
LE
CP
An
Yn
H
X
L
L
X
X
Z
X
L
L
L
L
X
H
H
L
H
L
L
L
H
H
H
L
H
H
X
Y0[1]
L
H
L
X
Y0[2]
[1]
Output level before the indicated steady-state input conditions were established, provided that CP is HIGH
before LE goes LOW.
[2]
Output level before the indicated steady-state input conditions were established.
74ALVC162334A_3
Product data sheet
6 of 19
74ALVC162334A
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
Conditions
Min
VI < 0 V
[1]
VO > VCC or VO < 0 V
[1]
output voltage
VO
IO(sink/source) output sink or source current
VO = 0 V to VCC
Max
Unit
−0.5
+4.6
V
−50
mA
−0.5
+4.6
V
±50
mA
−0.5
VCC + 0.5
V
±50
mA
ICC
supply current
±100
mA
IGND
ground current
±100
mA
Tstg
storage temperature
Ptot/pack
total power dissipation
per package
[1]
for temperature range −40 °C to +125 °C;
above +55 °C derate linearly with 8 mW/K
−65
+150
°C
600
mW
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
9. Recommended operating conditions
Table 6.
Operating conditions
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCC
supply voltage
2.5 V range for maximum speed performance
at 30 pF output load
2.3
2.7
V
3.3 V range for maximum speed performance
at 50 pF output load
3.0
3.6
V
for low-voltage applications
1.2
3.6
V
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
operating in free-air
−40
+85
°C
tr
rise time
VCC = 2.3 V to 3.0 V
ns/V
VCC = 3.0 V to 3.6 V
ns/V
tf
fall time
ns/V
ns/V
74ALVC162334A_3
Product data sheet
7 of 19
74ALVC162334A
Nexperia
10. Static characteristics
Table 7.
Tamb = −40 °C to +85 °C; over recommended operating conditions; voltages are referenced to GND (ground = 0 V);
unless otherwise specified.
Symbol
Parameter
VIH
HIGH-level input voltage
LOW-level input voltage
VIL
VOH
Min
Typ[1]
Max
Unit
VCC = 2.3 V to 2.7 V
1.7
1.2
V
VCC = 2.7 V to 3.6 V
2.0
1.5
V
1.2
0.7
V
1.5
0.8
V
VCC = 2.3 V to 3.6 V; IO = −100 µA
VCC − 0.2
VCC
V
VCC = 2.3 V; IO = −4 mA
VCC − 0.4
VCC − 0.11
V
VCC = 2.3 V; IO = −6 mA
VCC − 0.6
VCC − 0.17
V
VCC = 2.7 V; IO = −4 mA
VCC − 0.5
VCC − 0.09
V
VCC = 2.7 V; IO = −8 mA
VCC − 0.7
VCC − 0.19
V
VCC = 3.0 V; IO = −6 mA
VCC − 0.6
VCC − 0.13
V
VCC = 3.0 V; IO = −12 mA
VCC − 1.0
VCC − 0.27
V
VCC = 2.3 V to 3.6 V; IO = 100 µA
GND
0.20
V
VCC = 2.3 V; IO = 4 mA
0.07
0.40
V
VCC = 2.3 V; IO = 6 mA
0.11
0.55
V
VCC = 2.7 V; IO = 4 mA
0.06
0.40
V
VCC = 2.7 V; IO = 8 mA
0.13
0.60
V
VCC = 3.0 V; IO = 6 mA
0.09
0.55
V
VCC = 3.0 V; IO = 12 mA
0.19
0.80
V
HIGH-level output voltage VI = VIH or VIL
LOW-level output voltage
VOL
Conditions
VI = VIH or VIL
ILI
input leakage current
VI = VCC or GND
0.1
5
µA
IOZ
off-state output current
3-state; VCC = 2.3 V to 3.6 V;
VI = VIH or VIL; VO = VCC or GND
0.1
10
µA
ICC
supply current
VI = VCC or GND; IO = 0 mA
0.2
40
µA
∆ICC
additional supply current
VI = VCC − 0.6 V; IO = 0 mA
150
750
µA
Ci
input capacitance
4.0
pF
Cio
8.0
pF
10
pF
power dissipation
capacitance
CPD
3
pF
21
pF
15
pF
[1]
[2]
74ALVC162334A_3
Product data sheet
[2]
8 of 19
74ALVC162334A
Nexperia
11. Dynamic characteristics
Table 8.
Dynamic characteristics for VCC = 2.3 V to 2.7 V range
VCC = 2.3 V to 2.7 V; GND = 0 V; tr = tf ≤ 2.0 ns; CL = 30 pF (see Figure 11).
Symbol
Parameter
Conditions
Min
Typ[1]
Max
Unit
tPHL
An to Yn; Figure 5
1.0
3.5
5.0
ns
LE to Yn; Figure 6
1.3
3.5
5.0
ns
tPLH
CP to Yn; Figure 8
1.4
3.7
5.4
ns
An to Yn; Figure 5
1.0
3.5
5.0
ns
LE to Yn; Figure 6
1.3
3.5
5.0
ns
CP to Yn; Figure 8
1.4
3.7
5.4
ns
tPZH
OFF-state to HIGH propagation delay OE to Yn; Figure 10
[2]
1.4
3.5
5.0
ns
tPZL
OFF-state to LOW propagation delay OE to Yn; Figure 10
[2]
1.4
3.5
5.0
ns
HIGH to OFF-state propagation delay OE to Yn; Figure 10
[3]
1.0
2.8
4.5
ns
tPLZ
LOW to OFF-state propagation delay OE to Yn; Figure 10
[3]
1.0
2.8
4.5
ns
tw
pulse width
CP HIGH or LOW; Figure 8
3.3
1.0
ns
LE HIGH; Figure 6
3.3
0.7
ns
An to CP; Figure 9
1.0
ns
An to LE; Figure 7
1.5
ns
An to CP; Figure 9
0.4
0.4
ns
An to LE; Figure 7
1.4
0.4
ns
Figure 8
150
190
MHz
Conditions
Min
Typ[1]
Max
Unit
tPHZ
set-up time
tsu
hold time
th
fmax
[1]
All typical values are at VCC = 2.5 V and Tamb = 25 °C.
[2]
3-state output enable time.
[3]
3-state output disable time.
Table 9.
Dynamic characteristics for VCC = 2.7 V
VCC = 2.7 V; GND = 0 V; tr = tf ≤ 2.5 ns; CL = 50 pF (see Figure 11).
Symbol
Parameter
tPHL
tPLH
An to Yn; Figure 5
1.0
3.3
4.6
ns
LE to Yn; Figure 6
1.3
3.4
4.8
ns
CP to Yn; Figure 8
1.4
3.8
6.2
ns
An to Yn; Figure 5
1.0
3.3
4.6
ns
LE to Yn; Figure 6
1.3
3.4
4.8
ns
CP to Yn; Figure 8
1.4
3.8
6.2
ns
[2]
1.1
3.7
6.0
ns
[2]
1.1
3.7
6.0
ns
tPHZ
[3]
1.3
3.5
4.9
ns
tPLZ
[3]
1.3
3.5
4.9
ns
tPZH
tPZL
74ALVC162334A_3
Product data sheet
9 of 19
74ALVC162334A
Nexperia
Table 9.
Dynamic characteristics for VCC = 2.7 V …continued
Symbol
Parameter
Conditions
Min
Typ[1]
Max
Unit
tw
pulse width
3.3
1.2
ns
LE HIGH; Figure 6
3.3
0.6
ns
An to CP; Figure 9
1.0
ns
An to LE; Figure 7
1.5
ns
An to CP; Figure 9
0.6
0.3
ns
An to LE; Figure 7
1.7
0.4
ns
Figure 8
150
190
MHz
set-up time
tsu
hold time
th
fmax
[1]
All typical values are measured at Tamb = 25 °C.
[2]
[3]
Table 10. Dynamic characteristics for VCC = 3.0 V to 3.6 V range
Symbol
Parameter
Conditions
Min
Typ[1]
Max
Unit
tPHL
An to Yn; Figure 5
1.0
2.8
4.3
ns
LE to Yn; Figure 6
1.3
2.8
4.4
ns
tPLH
CP to Yn; Figure 8
1.4
3.2
4.9
ns
An to Yn; Figure 5
1.0
2.8
4.3
ns
LE to Yn; Figure 6
1.3
2.8
4.4
ns
CP to Yn; Figure 8
1.4
3.2
4.9
ns
tPZH
[2]
1.1
2.4
4.5
ns
tPZL
[2]
1.1
2.4
4.5
ns
[3]
1.3
2.4
4.8
ns
tPLZ
[3]
1.3
2.4
4.8
ns
tw
pulse width
3.3
0.7
ns
LE HIGH; Figure 6
3.3
0.6
ns
An to CP; Figure 9
1.0
ns
An to LE; Figure 7
1.5
ns
An to CP; Figure 9
0.9
0.3
ns
An to LE; Figure 7
1.4
0.4
ns
Figure 8
150
240
MHz
tPHZ
set-up time
tsu
hold time
th
fmax
[1]
All typical values are measured at VCC = 3.3 V, Tamb = 25 °C.
[2]
[3]
74ALVC162334A_3
Product data sheet
10 of 19
74ALVC162334A
Nexperia
11.1 AC waveforms
VCC = 3.0 V to 3.6 V and VCC = 2.7 V range:
VM = 1.5 V; VX = VOL + 0.3 V; VY = VOH − 0.3 V; VI = 2.7 V.
VOL and VOH are the typical output voltage drop that occur with the output load.
VCC = 2.3 V to 2.7 V and VCC < 2.3 V range:
VM = 0.5 V; VX = VOL + 0.15 V; VY = VOH − 0.15 V; VI = VCC.
VI
VI
An input
LE input
VM
VM
GND
tPHL
VM
GND
tw
tPLH
VOH
VM
Yn output
tPLH
tPHL
VOH
VM
Yn output
VOL
002aac727
VOL
002aac726
Fig 5. Input (An) to output (Yn) propagation delay
Fig 6. LE input pulse width, LE input to Yn output
propagation delays
1 / fmax
VI
An
input
VM
CP input
VM
th
tsu
GND
th
tsu
LE
input
GND
tPLH
tPHL
VOH
VM
Yn output
VM
VM
tw
VI
VM
VI
VM
VOL
002aac729
GND
002aac728
The shaded areas indicate when the input is
permitted to change for predictable output
performance.
Fig 7. Data set-up and hold times, An input to
LE input
Fig 8. CP to Yn propagation delays, clock pulse width,
and maximum clock frequency
VI
OE input
CP
input
th
tsu
GND
th
VI
An
input
Yn
output
GND
VI
GND
VOH
tPZL
tPLZ
VM
tsu
VM
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
tPHZ
output
HIGH-to-OFF
OFF-to-HIGH
VOH
VY
VM
GND
outputs
enabled
VOL
002aac730
tPZH
outputs
disabled
outputs
enabled
002aac731
performance.
Fig 9. Data set-up and hold times, An input to
CP input
Fig 10. 3-state enable and disable times
74ALVC162334A_3
Product data sheet
11 of 19
74ALVC162334A
Nexperia
12. Test information
S1
VCC
PULSE
GENERATOR
VI
RL
500 Ω
VO
2 × VCC
open
GND
DUT
RT
CL
RL
500 Ω
002aac732
Test data are given in Table 11.
RL = load resistance.
CL = load capacitance includes jig and probe capacitance.
RT = termination resistance should be equal to Zo of pulse generators.
Fig 11. Test circuitry for switching times
Table 11.
Test data
Supply voltage Input
VCC
VI
Load
Switch S1
tr, tf
CL
RL
tPLH, tPHL
tPZH, tPHZ
tPZL, tPLZ
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
GND (0 V)
2 × VCC
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
GND (0 V)
2 × VCC
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
GND (0 V)
2 × VCC
74ALVC162334A_3
Product data sheet
12 of 19
74ALVC162334A
Nexperia
13. Package outline
TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1 mm
SOT362-1
E
D
A
X
c
HE
y
v M A
Z
48
25
Q
A2
(A 3)
A1
pin 1 index
A
θ
Lp
L
1
detail X
24
w M
bp
e
2.5
5 mm
scale
DIMENSIONS (mm are the original dimensions).
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z
θ
mm
1.2
0.15
0.05
1.05
0.85
0.25
0.28
0.17
0.2
0.1
12.6
12.4
6.2
6.0
0.5
8.3
7.9
1
0.8
0.4
0.50
0.35
0.25
0.08
0.1
0.8
0.4
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT362-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig 12. Package outline SOT362-1 (TSSOP48)
74ALVC162334A_3
Product data sheet
13 of 19
74ALVC162334A
Nexperia
14. Soldering
This text provides a very brief insight into a complex technology. A more in-depth account
of soldering ICs can be found in Application Note AN10365 “Surface mount reflow
soldering description”.
14.1 Introduction to soldering
Soldering is one of the most common methods through which packages are attached to
Printed Circuit Boards (PCBs), to form electrical circuits. The soldered joint provides both
the mechanical and the electrical connection. There is no single soldering method that is
ideal for all IC packages. Wave soldering is often preferred when through-hole and
Surface Mount Devices (SMDs) are mixed on one printed wiring board; however, it is not
suitable for fine pitch SMDs. Reflow soldering is ideal for the small pitches and high
densities that come with increased miniaturization.
14.2 Wave and reflow soldering
Wave soldering is a joining technology in which the joints are made by solder coming from
a standing wave of liquid solder. The wave soldering process is suitable for the following:
• Through-hole components
• Leaded or leadless SMDs, which are glued to the surface of the printed circuit board
Not all SMDs can be wave soldered. Packages with solder balls, and some leadless
packages which have solder lands underneath the body, cannot be wave soldered. Also,
leaded SMDs with leads having a pitch smaller than ~0.6 mm cannot be wave soldered,
due to an increased probability of bridging.
The reflow soldering process involves applying solder paste to a board, followed by
component placement and exposure to a temperature profile. Leaded packages,
packages with solder balls, and leadless packages are all reflow solderable.
Key characteristics in both wave and reflow soldering are:
Board specifications, including the board finish, solder masks and vias
Package footprints, including solder thieves and orientation
The moisture sensitivity level of the packages
Package placement
Inspection and repair
Lead-free soldering versus PbSn soldering
14.3 Wave soldering
Key characteristics in wave soldering are:
• Process issues, such as application of adhesive and flux, clinching of leads, board
transport, the solder wave parameters, and the time during which components are
exposed to the wave
• Solder bath specifications, including temperature and impurities
74ALVC162334A_3
Product data sheet
14 of 19
74ALVC162334A
Nexperia
14.4 Reflow soldering
Key characteristics in reflow soldering are:
• Lead-free versus SnPb soldering; note that a lead-free reflow process usually leads to
higher minimum peak temperatures (see Figure 13) than a PbSn process, thus
reducing the process window
• Solder paste printing issues including smearing, release, and adjusting the process
window for a mix of large and small components on one board
• Reflow temperature profile; this profile includes preheat, reflow (in which the board is
heated to the peak temperature) and cooling down. It is imperative that the peak
temperature is high enough for the solder to make reliable solder joints (a solder paste
characteristic). In addition, the peak temperature must be low enough that the
packages and/or boards are not damaged. The peak temperature of the package
depends on package thickness and volume and is classified in accordance with
Table 12 and 13
Table 12.
SnPb eutectic process (from J-STD-020C)
Package thickness (mm)
Package reflow temperature (°C)
Volume (mm3)
< 350
≥ 350
< 2.5
235
220
≥ 2.5
220
220
Table 13.
Lead-free process (from J-STD-020C)
Volume (mm3)
< 350
350 to 2000
> 2000
< 1.6
260
260
260
1.6 to 2.5
260
250
245
> 2.5
250
245
245
Moisture sensitivity precautions, as indicated on the packing, must be respected at all
times.
Studies have shown that small packages reach higher temperatures during reflow
soldering, see Figure 13.
74ALVC162334A_3
Product data sheet
15 of 19
74ALVC162334A
Nexperia
maximum peak temperature
= MSL limit, damage level
temperature
= minimum soldering temperature
peak
temperature
time
001aac844
MSL: Moisture Sensitivity Level
Fig 13. Temperature profiles for large and small components
For further information on temperature profiles, refer to Application Note AN10365
“Surface mount reflow soldering description”.
15. Abbreviations
Table 14.
Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
TTL
Transistor-Transistor Logic
16. Revision history
Table 15.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74ALVC162334A_3
20061213
Product data sheet
74ALVC162334A_2
Modifications:
The format of this data sheet has been redesigned to comply with the new identity guidelines of
Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Section 1 “General description”, 1st paragraph, 2nd sentence: changed “OE” to “OE”
Table 2 “Ordering information”: changed (SOT364-1; TSSOP56) package to (SOT362-1;
TSSOP48) package
Table 3 “Pin description” corrected:
– changed “Y1 to Y18” to (Y1 to Y16, noted separately)
– GND pins: added pins 4 and 39
– VCC pins changed from “7, 22, 35, 50” to “7, 18, 31, 42”
– changed “A1 to A18” to (A1 to A16, noted separately)
Figure 1 “Logic symbol (IEEE/IEC)”: corrected pin number for Y15 from “21” to “22”
74ALVC162334A_3
Product data sheet
16 of 19
74ALVC162334A
Nexperia
Table 15.
Revision history …continued
Document ID
Modifications:
(continued)
Release date
Data sheet status
Change notice
Supersedes
Figure 2 “Logic diagram”:
– changed signal “A0” to “A1”
– changed signal “Y0” to “Y1”
– changed “to the 17 other channels” to “to the 15 other channels”
Table 5 “Limiting values” (title changed from “Absolute maximum ratings”):
– parameter definition of IIK changed from “DC input diode current” to “input clamping current”
– parameter definition of IOK changed from “DC output diode current” to “output clamping
current”
– symbol “IO” (DC output source or sink current) changed to “IO(sink/source)” (output sink or
source current)
– removed Ptot/pack information for SSOP package
Table 7 “Static characteristics” (title changed from “DC electrical characteristics”):
– changed symbol “II” to “ILI”
– parameter definition of IOZ changed from “3-State output OFF-state current” to “OFF-state
output current” (moved “3-state” to Conditions column)
– parameter definition of ICC changed from “quiescent supply current” to “supply current”
– parameter definition of ∆ICC changed from “additional quiescent supply current” to
“additional supply current”
– added Ci, Cio, and CPD parameters
Section 11 “Dynamic characteristics”: table “AC characteristics for VCC = 3.0 V to 3.6 V range
and VCC = 2.7 V” separated into 2 tables
Section 11.1 “AC waveforms”:
– 1st paragraph, 2nd line: changed “VM = 1.5 VCC” to “VM = 1.5 V”
– removed statement “VM = 0.5VCC at VCC = 2.3 V to 2.7 V.” from Figure 5, Figure 6, Figure 7,
Figure 8, Figure 9 and Figure 10 as redundant (depends on voltage as stated above these
figures)
Section 13 “Package outline”: replaced SOT364-1 (TSSOP56) package outline drawing with
Figure 12 “Package outline SOT362-1 (TSSOP48)”
74ALVC162334A_2
(9397 750 07246)
20000620
Product specification
853-2197 23931
74ALVC162334A_1
74ALVC162334A_1
(9397 750 06963)
20000314
853-2197 23314
74ALVC162334A_3
Product data sheet
17 of 19
74ALVC162334A
Nexperia
17. Legal information
17.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
17.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
17.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected to
result in personal injury, death or severe property or environmental damage.
Nexperia accepts no liability for inclusion and/or use of Nexperia
products in such equipment or applications and therefore
such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
17.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
18. Contact information
For additional information, please visit: http://www.nexperia.com
For sales office addresses, send an email to: salesaddresses@nexperia.com
74ALVC162334A_3
Product data sheet
18 of 19
Nexperia
74ALVC162334A
19. Contents
1
2
3
4
5
6
6.1
6.2
7
7.1
8
9
10
11
11.1
12
13
14
14.1
14.2
14.3
14.4
15
16
17
17.1
17.2
17.3
17.4
18
19
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 3
Pinning information . . . . . . . . . . . . . . . . . . . . . . 4
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 6
Function selection. . . . . . . . . . . . . . . . . . . . . . . 6
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 7
Recommended operating conditions. . . . . . . . 7
Static characteristics. . . . . . . . . . . . . . . . . . . . . 8
Dynamic characteristics . . . . . . . . . . . . . . . . . . 9
AC waveforms. . . . . . . . . . . . . . . . . . . . . . . . . 11
Test information . . . . . . . . . . . . . . . . . . . . . . . . 12
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 13
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14
Introduction to soldering . . . . . . . . . . . . . . . . . 14
Wave and reflow soldering . . . . . . . . . . . . . . . 14
Wave soldering . . . . . . . . . . . . . . . . . . . . . . . . 14
Reflow soldering . . . . . . . . . . . . . . . . . . . . . . . 15
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16
Legal information. . . . . . . . . . . . . . . . . . . . . . . 18
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 18
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Contact information. . . . . . . . . . . . . . . . . . . . . 18
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 13 December 2006
