74HC373; 74HCT373
Octal D-type transparent latch; 3-state
Rev. 8 — 6 September 2021
Product data sheet
1. General description
The 74HC373; 74HCT373 is an octal D-type transparent latch with 3-state outputs. The device
features latch enable (LE) and output enable (OE) inputs. When LE is HIGH, data at the inputs
enter the latches. In this condition the latches are transparent, a latch output will change each time
its corresponding D-input changes. When LE is LOW the latches store the information that was
present at the inputs a set-up time preceding the HIGH-to-LOW transition of LE. A HIGH on OE
causes the outputs to assume a high-impedance OFF-state. Operation of the OE input does not
affect the state of the latches. Inputs include clamp diodes. This enables the use of current limiting
resistors to interface inputs to voltages in excess of VCC.
2. Features and benefits
Wide supply voltage range from 2.0 V to 6.0 V
CMOS low power dissipation
High noise immunity
Latch-up performance exceeds 100 mA per JESD 78 Class II Level B
Complies with JEDEC standards:
• JESD8C (2.7 V to 3.6 V)
• JESD7A (2.0 V to 6.0 V)
Input levels:
• For 74HC373: CMOS level
• For 74HCT373: TTL level
3-state non-inverting outputs for bus oriented applications
Common 3-state output enable input
ESD protection:
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V
Multiple package options
Specified from -40 °C to +85 °C and from -40 °C to +125 °C
3. Ordering information
Table 1. Ordering information
Type number
Package
74HC373D
Temperature range Name
Description
Version
-40 °C to +125 °C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
-40 °C to +125 °C
TSSOP20
plastic thin shrink small outline package; 20 leads;
body width 4.4 mm
SOT360-1
-40 °C to +125 °C
DHVQFN20
plastic dual in-line compatible thermal enhanced
very thin quad flat package; no leads; 20 terminals;
body 2.5 × 4.5 × 0.85 mm
SOT764-1
74HCT373D
74HC373PW
74HCT373PW
74HC373BQ
74HCT373BQ
74HC373; 74HCT373
Nexperia
4. Functional diagram
3
4
7
8
13
14
17
18
11
1
D0
D1
D2
D3
D4
D5
D6
D7
LATCH
1 TO 8
3-STATE
OUTPUTS
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
2
5
6
9
12
15
16
19
LE
OE
001aae050
Fig. 1.
Functional diagram
OE
LE
11
3
4
7
8
13
14
17
18
LE
D0
Q0
D1
Q1
D2
Q2
D3
Q3
D4
Q4
D5
Q5
D6
Q6
D7
OE
1
Fig. 2.
Q7
D0
2
5
D1
6
D2
9
D3
12
D4
15
D5
16
D6
19
D7
1
11
3
EN
C1
2
1D
4
5
7
6
8
9
13
12
14
15
17
16
18
19
001aae048
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
001aae049
Logic symbol
Fig. 3.
IEC logic symbol
LE
LE
LE
D
LE
Fig. 4.
Q
001aae051
Logic diagram (one latch)
74HC_HCT373
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 16
74HC373; 74HCT373
Nexperia
D0
D1
D
Q
D2
D
Q
D3
D
Q
D4
D
Q
D5
D
Q
D6
D
Q
D7
D
Q
D
Q
LATCH
1
LATCH
2
LATCH
3
LATCH
4
LATCH
5
LATCH
6
LATCH
7
LATCH
8
LE LE
LE LE
LE LE
LE LE
LE LE
LE LE
LE LE
LE LE
LE
OE
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
001aae052
Fig. 5.
Logic diagram
5. Pinning information
5.1. Pinning
1
OE
terminal 1
index area
1
Q0
2
20 VCC
19 Q7
D0
3
18 D7
D1
4
17 D6
Q1
5
16 Q6
Q2
6
15 Q5
D2
7
14 D5
D3
8
13 D4
Q3
9
12 Q4
GND 10
11 LE
Pin configuration SOT163-1 (SO20) and
SOT360-1 (TSSOP20)
74HC_HCT373
Product data sheet
19 Q7
D0
3
18 D7
D1
4
17 D6
Q1
5
16 Q6
Q2
6
15 Q5
D2
7
D3
8
Q3
9
GND(1)
14 D5
13 D4
12 Q4
001aae047
Transparent top view
(1) This is not a ground pin. There is no electrical or
mechanical requirement to solder the pad. In case
soldered, the solder land should remain floating or
connected to GND.
001aae046
Fig. 6.
2
LE 11
OE
Q0
GND 10
74HC373
74HCT373
20 VCC
74HC373
74HCT373
Fig. 7.
Pin configuration SOT764-1 (DHVQFN20)
3 / 16
74HC373; 74HCT373
Nexperia
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
OE
1
3-state output enable input (active LOW)
Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7
2, 5, 6, 9, 12, 15, 16, 19
3-state latch output
D0, D1, D2, D3, D4, D5, D6, D7
3, 4, 7, 8, 13, 14, 17, 18
data input
GND
10
ground (0 V)
LE
11
latch enable input (active HIGH)
VCC
supply voltage
6. Functional description
Table 3. Functional description
H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the HIGH-to-LOW LE transition;
L = LOW voltage level; I = LOW voltage level one set-up time prior to the HIGH-to-LOW LE transition;
X = don’t care; Z = high-impedance OFF-state.
Operating mode
Input
Control
Output
Internal latches
OE
LE
Dn
Enable and read register
(transparent mode)
L
H
L
L
L
H
H
H
Latch and read register
L
l
L
L
h
H
H
X
X
Z
Latch register and disable
outputs
H
L
X
Qn
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
VCC
supply voltage
-0.5
+7
V
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
IO
output current
VO = -0.5 V to (VCC + 0.5 V)
±35
mA
ICC
supply current
+70
mA
IGND
ground current
Tstg
storage temperature
Ptot
total power dissipation
[1]
[1]
-70
mA
-65
+150
°C
500
mW
For SOT163-1 (SO20) package: Ptot derates linearly with 12.3 mW/K above 109 °C.
For SOT360-1 (TSSOP20) package: Ptot derates linearly with 10.0 mW/K above 100 °C.
For SOT764-1 (DHVQFN20) package: Ptot derates linearly with 12.9 mW/K above 111 °C.
74HC_HCT373
Product data sheet
4 / 16
74HC373; 74HCT373
Nexperia
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
74HC373
74HCT373
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Tamb = 25 °C
Tamb = -40 °C
to 85 °C
Tamb = -40 °C Unit
to 125 °C
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
VI = VIH or VIL
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -6.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -7.8 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 6.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 7.8 mA; VCC = 6.0 V
74HC373
VIH
VIL
VOH
VOL
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level output
voltage
LOW-level output
voltage
VI = VIH or VIL
0.16
0.26
0.33
0.4
V
II
input leakage
current
VI = VCC or GND; VCC = 6.0 V
±0.1
±1.0
±1.0
μA
IOZ
OFF-state output
current
VI = VIH or VIL; VCC = 6.0 V;
VO = VCC or GND
±0.5
±5.0
±10.0 μA
ICC
supply current
VCC = 6.0 V; IO = 0 A;
VI = VCC or GND
8.0
80
74HC_HCT373
Product data sheet
160
μA
5 / 16
74HC373; 74HCT373
Nexperia
Symbol Parameter
CI
Conditions
Tamb = 25 °C
Tamb = -40 °C
to 85 °C
Tamb = -40 °C Unit
to 125 °C
Min
Typ
Max
Min
Max
Min
Max
3.5
pF
input capacitance
74HCT373
VIH
HIGH-level input
voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level input
voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level output
voltage
VI = VIH or VIL
4.4
4.5
4.4
4.4
V
3.98
4.32
3.84
3.7
V
0.0
0.1
0.1
0.1
V
0.16
0.26
0.33
0.4
V
VOL
LOW-level output
voltage
VI = VIH or VIL
II
input leakage
current
VI = VCC or GND; VCC = 5.5 V
±0.1
±1.0
±1.0
μA
IOZ
OFF-state output
current
VI = VIH or VIL; VCC = 5.5 V;
VO = VCC or GND
±0.5
±5.0
±10
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 5.5 V
8.0
80
160
μA
ΔICC
additional supply
current
VI = VCC - 2.1 V;
other inputs at VCC or GND;
VCC = 4.5 V to 5.5 V; IO = 0 A
CI
Dn
30
108
135
147
μA
LE
150
540
675
735
μA
OE
100
360
450
490
μA
3.5
pF
input capacitance
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Fig. 12.
Symbol Parameter
Conditions
Tamb = 25 °C
Tamb = -40 °C
to +85 °C
Tamb = -40 °C
to +125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
41
150
190
225
ns
VCC = 4.5 V
15
30
38
45
ns
VCC = 5 V; CL = 15 pF
12
ns
VCC = 6.0 V
12
26
33
38
ns
VCC = 2.0 V
50
175
220
265
ns
VCC = 4.5 V
18
35
44
53
ns
15
ns
VCC = 6.0 V
14
30
37
45
ns
74HC373
tpd
propagation
delay
Dn to Qn; see Fig. 8
[1]
LE to Qn; see Fig. 9
74HC_HCT373
Product data sheet
6 / 16
74HC373; 74HCT373
Nexperia
Symbol Parameter
ten
tdis
tt
tW
tsu
th
CPD
enable time
disable time
transition time
pulse width
set-up time
hold time
Conditions
Tamb = 25 °C
Tamb = -40 °C
to +85 °C
Tamb = -40 °C
to +125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
44
150
190
225
ns
VCC = 4.5 V
16
30
38
45
ns
VCC = 6.0 V
13
26
33
38
ns
VCC = 2.0 V
47
150
190
225
ns
VCC = 4.5 V
17
30
38
45
ns
VCC = 6.0 V
14
26
33
38
ns
VCC = 2.0 V
14
60
75
90
ns
VCC = 4.5 V
5
12
15
18
ns
VCC = 6.0 V
4
10
13
15
ns
VCC = 2.0 V
80
17
100
120
ns
VCC = 4.5 V
16
6
ns
VCC = 6.0 V
14
5
17
ns
VCC = 2.0 V
50
14
65
75
ns
VCC = 4.5 V
10
5
13
15
ns
VCC = 6.0 V
9
4
11
13
ns
VCC = 2.0 V
+5
-8
5
5
ns
VCC = 4.5 V
+5
-3
5
5
ns
VCC = 6.0 V
+5
-2
5
5
ns
45
pF
VCC = 4.5 V
17
30
38
45
ns
14
ns
VCC = 4.5 V
16
32
40
48
ns
13
ns
OE to Qn; see Fig. 10
Qn; see Fig. 8 and Fig. 9
[2]
[3]
[4]
LE HIGH; see Fig. 9
Dn to LE; see Fig. 11
power dissipation per latch; VI = GND to VCC
capacitance
[5]
74HCT373
tpd
propagation
delay
[1]
ten
enable time
OE to Qn; VCC = 4.5 V;
see Fig. 10
[2]
19
32
40
48
ns
tdis
disable time
see Fig. 10
[3]
18
30
38
45
ns
tt
transition time
Qn; VCC = 4.5 V;
[4]
5
12
15
18
ns
74HC_HCT373
Product data sheet
7 / 16
74HC373; 74HCT373
Nexperia
Symbol Parameter
Conditions
Tamb = 25 °C
Tamb = -40 °C
to +85 °C
Tamb = -40 °C
to +125 °C
Min
Typ
Max
Min
Max
Min
Max
Unit
tW
pulse width
LE HIGH; VCC = 4.5 V;
see Fig. 9
16
4
ns
tsu
set-up time
Dn to LE; VCC = 4.5 V;
see Fig. 11
12
6
15
18
ns
th
hold time
see Fig. 11
4
-1
4
4
ns
CPD
capacitance
VI = GND to (VCC - 1.5 V)
41
pF
[1]
[2]
[3]
[4]
[5]
[5]
tpd is the same as tPLH and tPHL.
ten is the same as tPZH and tPZL.
tdis is the same as tPLZ and tPHZ.
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL × VCC × fo) = sum of outputs.
10.1. Waveforms and test circuit
Dn input
VM
t PLH
t PHL
90 %
VM
Qn output
10 %
t TLH
t THL
001aae082
Measurement points are given in Table 8.
Fig. 8.
Propagation delay input (Dn) to output (Qn) and transition time output (Qn)
LE input
VM
tW
t PHL
t PLH
90 %
VM
Qn output
10 %
t THL
t TLH
001aae083
Fig. 9.
Pulse width latch enable input (LE), propagation delay (LE) to output (Qn) and transition time output (Qn)
74HC_HCT373
Product data sheet
8 / 16
74HC373; 74HCT373
Nexperia
VI
OE input
VM
GND
tPLZ
tPZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
10%
VOL
tPHZ
tPZH
VOH
90%
output
HIGH-to-OFF
OFF-to-HIGH
GND
VM
outputs
enabled
outputs
disabled
outputs
enabled
001aae307
Fig. 10. 3-state enable and disable time
VM
LE input
t su
th
t su
th
VM
Dn input
001aae084
Fig. 11. Set-up and hold time data input (Dn) to latch enable input (LE)
Table 8. Measurement points
Type
Input
Output
VM
VM
74HC373
0.5VCC
0.5VCC
74HCT373
1.3 V
1.3 V
74HC_HCT373
Product data sheet
9 / 16
74HC373; 74HCT373
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VCC
VO
RT
RL
S1
open
CL
001aad983
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
RL = Load resistor
S1 = Test selection switch
Fig. 12. Test circuit for measuring switching times
Table 9. Test data
Type
Input
Load
S1 position
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
74HC373
VCC
6 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74HCT373
3V
6 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74HC_HCT373
Product data sheet
10 / 16
74HC373; 74HCT373
Nexperia
11. Package outline
SO20: plastic small outline package; 20 leads; body width 7.5 mm
SOT163-1
D
E
A
X
c
y
HE
v M A
Z
Q
A2
A
(A 3 )
A1
pin 1 index
θ
Lp
L
1
10
e
bp
detail X
w M
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
13.0
12.6
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.9
0.4
inches
0.1
0.012 0.096
0.004 0.089
0.01
0.019 0.013
0.014 0.009
0.51
0.49
0.30
0.29
0.05
0.419
0.043
0.055
0.394
0.016
0.043
0.039
0.01
0.01
0.004
0.035
0.016
Z
(1)
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT163-1
075E04
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 13. Package outline SOT163-1 (SO20)
74HC_HCT373
Product data sheet
11 / 16
74HC373; 74HCT373
Nexperia
TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm
D
SOT360-1
E
A
X
c
HE
y
v M A
Z
11
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
10
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
6.6
6.4
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT360-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig. 14. Package outline SOT360-1 (TSSOP20)
74HC_HCT373
Product data sheet
12 / 16
74HC373; 74HCT373
Nexperia
DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
20 terminals; body 2.5 x 4.5 x 0.85 mm
B
D
SOT764-1
A
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
e1
C
e
b
2
9
v
w
C A B
C
y1 C
y
L
1
10
Eh
e
19
12
X
Dh
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
A(1)
A1
b
max 1.00 0.05 0.30
nom 0.90 0.02 0.25
min 0.80 0.00 0.18
mm
c
D(1)
Dh
E(1)
Eh
e
e1
L
v
0.2
4.6
4.5
4.4
3.15
3.00
2.85
2.6
2.5
2.4
1.15
1.00
0.85
0.5
3.5
0.5
0.4
0.3
0.1
w
y
0.05 0.05
y1
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
References
Outline
version
IEC
JEDEC
JEITA
SOT764-1
MO-241
sot764-1_po
European
projection
Issue date
03-01-27
14-12-12
Fig. 15. Package outline SOT764-1 (DHVQFN20)
74HC_HCT373
Product data sheet
13 / 16
74HC373; 74HCT373
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74HC_HCT373 v.8
20210906
Product data sheet
Modifications:
74HC_HCT373 v.7
20200722
Modifications:
Type number 74HC373DB (SOT339-1/SSOP20) removed.
20160226
Modifications:
74HC_HCT373 v.5
20111213
Modifications:
74HC_HCT373 v.4
20100903
74HC_HCT373 v.3
74HC_HCT373_CNV v.2
Product data sheet
Product data sheet
74HC_HCT373 v.6
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Type number 74HCT373DB (SOT339-1/SSOP20) removed.
Table 4: Derating values for Ptot total power dissipation updated.
74HC_HCT373 v.6
74HC_HCT373
74HC_HCT373 v.7
Product data sheet
74HC_HCT373 v.5
Type numbers 74HC373N and 74HCT373N (SOT146-1) removed.
Product data sheet
74HC_HCT373 v.4
Product data sheet
74HC_HCT373 v.3
20060120
Product data sheet
74HC_HCT373_CNV v.2
19970827
Product specification
Legal pages updated.
14 / 16
74HC373; 74HCT373
Nexperia
14. Legal information
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Data sheet status
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
74HC_HCT373
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s own risk,
and (c) customer fully indemnifies Nexperia for any liability, damages or failed
product claims resulting from customer design and use of the product for
automotive applications beyond Nexperia’s standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
15 / 16
74HC373; 74HCT373
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................1
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 4
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................5
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 6
10.1. Waveforms and test circuit........................................ 8
11. Package outline........................................................ 11
12. Abbreviations............................................................ 14
13. Revision history........................................................14
14. Legal information......................................................15
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 6 September 2021
74HC_HCT373
Product data sheet
16 / 16
