74LVT16373ADGG,512
74LVT16373ADGG,512
    NEXPERIA(安世)
    TSSOP-48
    IC 16BIT TRANSP LATCH D 48TSSOP
74LVT16373ADGG,512 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia INTEGRATED CIRCUITS 74LVT16373A 3.3V LVT 16-bit transparent D-type latch (3-State) Product specification Supersedes data of 1994 Dec 15 IC23 Data Handbook       1998 Feb 19 Philips Semiconductors Product specification 3.3V 16-bit transparent D-type latch (3-State) FEATURES 74LVT16373A DESCRIPTION • 16-bit transparent latch • 3-State buffers • Output capability: +64mA/-32mA • TTL input and output switching levels • Input and output interface capability to systems at 5V supply • Bus-hold data inputs eliminate the need for external pull-up The 74LVT16373A is a high-performance BiCMOS product designed for VCC operation at 3.3V. This device is a 16-bit transparent D-type latch with non-inverting 3-State bus compatible outputs. The device can be used as two 8-bit latches or one 16-bit latch. When enable (E) input is High, the Q outputs follow the data (D) inputs. When enable is taken Low, the Q outputs are latched at the levels of the D inputs one setup time prior to the High-to-Low transition. resistors to hold unused inputs • Live insertion/extraction permitted • Power-up reset • Power-up 3-State • No bus current loading when output is tied to 5V bus • Latch-up protection exceeds 500mA per JEDEC Std 17 • ESD protection exceeds 2000V per MIL STD 883 Method 3015 and 200V per Machine Model QUICK REFERENCE DATA SYMBOL CONDITIONS Tamb = 25°C PARAMETER TYPICAL UNIT 1.9 ns 3 pF tPLH tPHL Propagation delay nDx to nQx CL = 50pF; VCC = 3.3V CIN Input capacitance VI = 0V or 3.0V COUT Output capacitance Outputs disabled; VO = 0V or 3.0V 9 pF ICCZ Total supply current Outputs disabled; VCC = 3.6V 70 µA ORDERING INFORMATION PACKAGES TEMPERATURE RANGE OUTSIDE NORTH AMERICA NORTH AMERICA DWG NUMBER 48-Pin Plastic SSOP Type III –40°C to +85°C 74LVT16373A DL VT16373A DL SOT370-1 48-Pin Plastic TSSOP Type II –40°C to +85°C 74LVT16373A DGG VT16373A DGG SOT362-1 LOGIC SYMBOL 47 PIN DESCRIPTION 46 44 43 41 40 38 1D0 1D1 1D2 1D3 1D4 1D5 1D6 1D7 48 1LE 1 1OE PIN NUMBER SYMBOL FUNCTION 47, 46, 44, 43, 41, 40, 38, 37, 36, 35, 33, 32, 30, 29, 27, 26 1D0 – 1D7 2D0 – 2D7 Data inputs 2, 3, 5, 6, 8, 9, 11, 12, 13, 14, 16, 17, 19, 20, 22, 23 1Q0 – 1Q7 2Q0 – 2Q7 Data outputs 1, 24 1OE, 2OE Output enable inputs (active-Low) 37 1Q0 1Q1 1Q2 1Q3 1Q4 1Q5 1Q6 1Q7 2 3 5 6 8 9 11 12 48, 25 1E, 2E Enable inputs (active-High) 36 35 33 32 30 29 27 26 4, 10, 15, 21, 28, 34, 39, 45 GND Ground (0V) 7, 18, 31, 42 VCC Positive supply voltage 2D0 2D21 2D2 2D3 2D4 2D5 2D6 2D7 25 2LE 24 2OE 2Q0 2Q1 2Q2 2Q3 2Q4 2Q5 2Q6 2Q7 13 14 16 17 19 20 22 23 SA00044 1998 Feb 19 2 853-1780 18989 Philips Semiconductors Product specification 3.3V 16-bit transparent D-type latch (3-State) LOGIC SYMBOL (IEEE/IEC) 74LVT16373A PIN CONFIGURATION 1OE 1 1EN 1OE 1 48 1LE 1LE 48 C3 1Q0 2 47 1D0 2OE 24 2EN 1Q1 3 46 1D1 2LE 25 C4 GND 4 45 GND 1Q2 5 44 1D2 1Q3 6 43 1D3 VCC 7 42 VCC 1Q4 8 41 1D4 1Q5 9 40 1D5 GND 10 39 GND 1Q6 11 38 1D6 1Q7 12 37 1D7 2Q0 13 36 2D0 2Q1 14 35 2D1 GND 15 34 GND 2Q2 16 33 2D2 2Q3 17 32 2D3 1D1 1D2 47 2 1∇ 3D 46 1Q1 3 1Q2 1D3 44 5 1D4 43 6 1Q4 1D5 41 8 1Q5 1D6 40 1D7 1Q3 9 1Q6 38 11 1Q7 1D8 37 12 2D1 36 13 2D2 35 14 2D3 33 16 2D4 32 17 2D5 30 19 2Q5 2D6 29 20 2Q6 VCC 18 31 VCC 2D7 27 22 2Q7 2Q4 19 30 2D4 2D8 26 23 2Q8 2Q5 20 29 2D5 SW00010 GND 21 28 GND 2Q6 22 27 2D6 2Q7 23 26 2D7 2OE 24 25 2LE 2∇ 4D 1Q8 2Q1 2Q2 2Q3 2Q4 SA00043 LOGIC DIAGRAM nD1 nD0 D E nD2 D Q E nD3 D Q E nD4 D Q nD5 D E Q E nD6 D Q E nD7 D Q E D Q E Q nLE nOE nQ0 nQ1 nQ2 nQ3 nQ4 nQ5 nQ6 nQ7 SA00046 1998 Feb 19 3 Philips Semiconductors Product specification 3.3V 16-bit transparent D-type latch (3-State) 74LVT16373A FUNCTION TABLE INPUTS H = h = L = l = NC= X = Z = ↓ = OUTPUTS nOE nE nDx INTERNAL REGISTER L L H H L H L H L H Enable and read register L L ↓ ↓ l h L H L H Latch and read register L L X NC NC H H L H X nDx NC nDx Z Z OPERATING MODE nQ0 – nQ7 Hold Disable outputs High voltage level High voltage level one set-up time prior to the High-to-Low E transition Low voltage level Low voltage level one set-up time prior to the High-to-Low E transition No change Don’t care High impedance “off ” state High-to-Low E transition ABSOLUTE MAXIMUM RATINGS1, 2 SYMBOL VCC IIK PARAMETER CONDITIONS DC supply voltage DC input diode current VI < 0 voltage3 VI DC input IOK DC output diode current VOUT DC output voltage3 IOUT O DC output current Tstg Storage temperature range RATING UNIT –0.5 to +4.6 V –50 mA –0.5 to +7.0 V VO < 0 –50 mA Output in Off or High state –0.5 to +7.0 V Output in Low state 128 Output in High state –64 mA –65 to +150 °C NOTES: 1. Stresses beyond those listed may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. 2. The performance capability of a high-performance integrated circuit in conjunction with its thermal environment can create junction temperatures which are detrimental to reliability. The maximum junction temperature of this integrated circuit should not exceed 150°C. 3. The input and output negative voltage ratings may be exceeded if the input and output clamp current ratings are observed. RECOMMENDED OPERATING CONDITIONS SYMBOL VCC LIMITS PARAMETER DC supply voltage UNIT MIN MAX 2.7 3.6 V 0 5.5 V VI Input voltage VIH High-level input voltage VIL Input voltage 0.8 V IOH High-level output current –32 mA IOL Low-level output current 32 mA Low-level output current; current duty cycle ≤ 50%; f ≥ 1kHz 64 ∆t/∆v Input transition rise or fall rate; Outputs enabled Tamb Operating free-air temperature range 1998 Feb 19 2.0 –40 4 V 10 ns/V +85 °C Philips Semiconductors Product specification 3.3V 16-bit transparent D-type latch (3-State) 74LVT16373A DC ELECTRICAL CHARACTERISTICS LIMITS SYMBOL PARAMETER TEST CONDITIONS Temp = -40°C to +85°C MIN VIK Input clamp voltage VCC = 2.7V; IIK = –18mA VCC = 2.7 to 3.6V; IOH = –100µA VOH VOL VRST High-level output voltage Low–level output voltage Power-up output Low voltage5 Input In ut leakage current Output off current Bus Hold current D inputs7 –1.2 VCC = 2.7V; IOH = –8mA 2.4 2.5 VCC = 3.0V; IOH = –32mA 2.0 2.3 0.07 0.2 VCC = 2.7V; IOL = 24mA 0.3 0.5 VCC = 3.0V; IOL = 16mA 0.25 0.4 VCC = 3.0V; IOL = 32mA 0.3 0.5 VCC = 3.0V; IOL = 64mA 0.4 0.55 VCC = 3.6V; IO = 1mA; VI = GND or VCC 0.1 0.55 0.1 ±1 VCC = 0 or 3.6V; VI = 5.5V 0.4 10 VCC = 3.6V; VI = VCC 0.1 1 -0.4 -5 0.1 ±100 Control pins Data pins ins4 VCC = 0V; VI or VO = 0 to 4.5V 75 135 VCC = 3V; VI = 2.0V –75 -135 VCC = 0V to 3.6V; VCC = 3.6V ±500 UNIT V V VCC = 2.7V; IOL = 100µA VCC = 3V; VI = 0.8V IHOLD –.85 VCC VCC = 3.6V; VI = 0 IOFF MAX VCC-0.2 VCC = 3.6V; VI = VCC or GND II TYP1 V V µA µA µA Current into an output in the High state when VO > VCC VO = 5.5V; VCC = 3.0V 50 125 µA Power up/down 3-State output current3 VCC ≤ 1.2V; VO = 0.5V to VCC; VI = GND or VCC; OE/OE = Don’t care 1 ±100 µA IOZH 3-State output High current VCC = 3.6V; VO = 3.0V; VI = VIH or VIL 0.5 5 IOZL 3-State output Low current VCC = 3.6V; VO = 0.5V; VI = VIH or VIL 0.5 –5 µA VCC = 3.6V; Outputs High, VI = GND or VCC, IO = 0 0.07 0.12 IEX IPU/PD ICCH ICCL Quiescent supply current ICCZ ∆ICC Additional supply current per input pin2 VCC = 3.6V; Outputs Low, VI = GND or VCC, IO = 0 4.0 6 VCC = 3.6V; Outputs Disabled; VI = GND or VCC, IO = 06 0.07 0.12 VCC = 3V to 3.6V; One input at VCC-0.6V, Other inputs at VCC or GND 0.1 0.2 mA mA NOTES: 1. All typical values are at VCC = 3.3V and Tamb = 25°C. 2. This is the increase in supply current for each input at the specified voltage level other than VCC or GND. 3. This parameter is valid for any VCC between 0V and 1.2V with a transition time of up to 10msec. From VCC = 1.2V to VCC = 3.3V ± 0.3V a transition time of 100µsec is permitted. This parameter is valid for Tamb = 25°C only. 4. Unused pins at VCC or GND. 5. For valid test results, data must not be loaded into the flip-flops (or latches) after applying power. 6. ICCZ is measured with outputs pulled to VCC or GND. 7. This is the bus hold overdrive current required to force the input to the opposite logic state. 1998 Feb 19 5 Philips Semiconductors Product specification 3.3V 16-bit transparent D-type latch (3-State) 74LVT16373A AC CHARACTERISTICS GND = 0V; tR = tF = 2.5ns; CL = 50pF; RL = 500Ω; Tamb = –40°C to +85°C. LIMITS SYMBOL PARAMETER VCC = 3.3V ±0.3V VCC = 2.7V MIN TYP1 MAX MAX WAVEFORM UNIT tPLH tPHL Propagation delay nDx to nQx 2 0.5 0.5 1.8 1.9 3.9 3.9 4.5 4.5 ns tPLH tPHL Propagation delay nE to nQx 1 0.5 0.5 2.1 2.2 4.8 4.8 5.4 5.4 ns tPZH tPZL Output enable time to High and Low level 4 5 0.1 0.1 2.8 2.6 4.5 4.3 5.1 4.7 ns tPHZ tPLZ Output disable time from High and Low Level 4 5 0.1 0.1 3.3 3.0 4.5 4.3 5.1 4.7 ns NOTE: 1. All typical values are at VCC = 3.3V and Tamb = 25°C. AC SETUP REQUIREMENTS GND = 0V; tR = tF = 2.5ns; CL = 50pF; RL = 500Ω; Tamb = –40°C to +85°C. LIMITS SYMBOL PARAMETER VCC = 3.3V ±0.3V WAVEFORM VCC = 2.7V MIN TYP MIN UNIT tS(H) tS(L) Setup time nDx to nE 3 1.5 2.0 0.1 0.2 1.0 2.0 ns th(H) th(L) Hold time nDx to nE 3 1.0 1.5 0 0 1.0 2.0 ns tW(H) nE pulse width High 1 1.5 0.5 1.5 ns AC WAVEFORMS ÉÉÉ ÉÉÉÉÉÉÉ ÉÉÉÉ ÉÉÉ ÉÉÉÉÉÉÉ ÉÉÉÉ ÉÉÉ ÉÉÉÉÉÉÉ ÉÉÉÉ For all waveforms, VM = 1.5V. 2.7V 2.7V nE VM VM nDx VM nQx VM VM VM 0V ts(H) 0V tw(H) tPHL VM ts(L) th(H) th(L) 2.7V tPLH VM nE VOH VM VM 0V VM NOTE: The shaded areas indicate when the input is permitted to change for predictable output performance. VOL SW00011 SW00013 Waveform 1. Propagation Delay, Enable to Output, and Enable Pulse Width Waveform 3. Data Setup and Hold Times 2.7V 2.7V nDx VM nOE VM tPZH tPHZ tPHL VOH VOH nQx VM 0V 0V tPLH VM VM nQx VM VM VOH -0.3V 0V VOL SW00014 SW00012 Waveform 4. 3-State Output Enable time to High Level and Output Disable Time from High Level Waveform 2. Propagation Delay for Data to Outputs 1998 Feb 19 6 Philips Semiconductors Product specification 3.3V 16-bit transparent D-type latch (3-State) 74LVT16373A 2.7V nOE VM VM 0V tPZL tPLZ 3V VM nQx VOL +0.3V VOL SW00015 Waveform 5. 3-State Output Enable Time to Low Level and Output Disable Time from Low Level TEST CIRCUIT AND WAVEFORMS 6V VCC OPEN VIN VOUT PULSE GENERATOR tW 90% RL GND VM NEGATIVE PULSE CL 10% 0V RL tTHL (tF) tTLH (tR) tTLH (tR) tTHL (tF) 90% POSITIVE PULSE Test Circuit for 3-State Outputs SWITCH tPHZ/tPZH GND tPLZ/tPZL 6V tPLH/tPHL open VM VM 10% tW 0V VM = 1.5V Input Pulse Definition INPUT PULSE REQUIREMENTS DEFINITIONS FAMILY RL = Load resistor; see AC CHARACTERISTICS for value. CL = Load capacitance includes jig and probe capacitance; see AC CHARACTERISTICS for value. AMP (V) 90% 10% SWITCH POSITION TEST AMP (V) VM 10% D.U.T. RT 90% 74LVT16 Amplitude Rep. Rate tW tR 2.7V ≤10MHz 500ns ≤2.5ns tF ≤2.5ns RT = Termination resistance should be equal to ZOUT of pulse generators. SW00003 1998 Feb 19 7 Philips Semiconductors Low Voltage Products Product specification 3.3V LVT 16-bit transparent D-type latch (3-State) SSOP48: plastic shrink small outline package; 48 leads; body width 7.5 mm 1998 Feb 19 8 74LVT16373A SOT370-1 Philips Semiconductors Low Voltage Products Product specification 3.3V LVT 16-bit transparent D-type latch (3-State) TSSOP48: plastic thin shrink small outline package; 48 leads; body width 6.1mm 1998 Feb 19 9 74LVT16373A SOT362-1 Philips Semiconductors Product specification 3.3V LVT 16-bit transparent D-type latch (3-State) 74LVT16373A Data sheet status Data sheet status Product status Definition [1] Objective specification Development This data sheet contains the design target or goal specifications for product development. Specification may change in any manner without notice. Preliminary specification Qualification This data sheet contains preliminary data, and supplementary data will be published at a later date. Philips Semiconductors reserves the right to make chages at any time without notice in order to improve design and supply the best possible product. Product specification Production This data sheet contains final specifications. Philips Semiconductors reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. [1] Please consult the most recently issued datasheet before initiating or completing a design. Definitions Short-form specification — The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Limiting values definition — Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Application information — Applications that are described herein for any of these products are for illustrative purposes only. Philips Semiconductors make no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Disclaimers Life support — These products are not designed for use in life support appliances, devices or systems where malfunction of these products can reasonably be expected to result in personal injury. Philips Semiconductors customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Philips Semiconductors for any damages resulting from such application. Right to make changes — Philips Semiconductors reserves the right to make changes, without notice, in the products, including circuits, standard cells, and/or software, described or contained herein in order to improve design and/or performance. Philips Semiconductors assumes no responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified.  Copyright Philips Electronics North America Corporation 1998 All rights reserved. Printed in U.S.A. Philips Semiconductors 811 East Arques Avenue P.O. Box 3409 Sunnyvale, California 94088–3409 Telephone 800-234-7381 print code Document order number:       yyyy mmm dd 10 Date of release: 05-96 9397-750-03554
74LVT16373ADGG,512 价格&库存
很抱歉,暂时无法提供与“74LVT16373ADGG,512”相匹配的价格&库存,您可以联系我们找货
74LVT16373ADGG,512
  • 1950+2.945221950+0.38104
