74LVC373A-Q100
Octal D-type transparent latch with 5 V tolerant
inputs/outputs; 3-state
Rev. 3 — 4 March 2021
Product data sheet
1. General description
The 74LVC373A-Q100 is an octal D-type transparent latch with 3-state outputs. The device
features latch enable (LE) and output enable (OE) inputs. When LE is HIGH, data at the inputs
enter the latches. In this condition the latches are transparent, a latch output will change each time
its corresponding D-input changes. When LE is LOW the latches store the information that was
present at the inputs a set-up time preceding the HIGH-to-LOW transition of LE. A HIGH on OE
causes the outputs to assume a high-impedance OFF-state. Operation of the OE input does not
affect the state of the latches. Inputs can be driven from either 3.3 V or 5 V devices. This feature
allows the use of these devices as translators in mixed 3.3 V and 5 V environments.
Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall times.
This device is fully specified for partial power down applications using IOFF. The IOFF circuitry
disables the output, preventing the potentially damaging backflow current through the device when
it is powered down.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Overvoltage tolerant inputs to 5.5 V
Wide supply voltage range from 1.2 V to 3.6 V
CMOS low power consumption
Direct interface with TTL levels
High-impedance outputs when VCC = 0 V
IOFF circuitry provides partial Power-down mode operation
Complies with JEDEC standard:
• JESD8-7A (1.65 V to 1.95 V)
• JESD8-5A (2.3 V to 2.7 V)
• JESD8-C/JESD36 (2.7 V to 3.6 V)
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
DHVQFN package with Side-Wettable Flanks enabling Automatic Optical Inspection (AOI) of
solder joints
74LVC373A-Q100
Nexperia
Octal D-type transparent latch with 5 V tolerant inputs/outputs; 3-state
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range
Name
Description
Version
74LVC373AD-Q100
-40 °C to +125 °C
SO20
plastic small outline package; 20 leads;
body width 7.5 mm
SOT163-1
74LVC373APW-Q100
-40 °C to +125 °C
TSSOP20
plastic thin shrink small outline package;
20 leads; body width 4.4 mm
SOT360-1
74LVC373ABQ-Q100
-40 °C to +125 °C
DHVQFN20 plastic dual in-line compatible
thermal enhanced very thin quad
flat package; no leads; 20 terminals;
body 2.5 × 4.5 × 0.85 mm
SOT764-1
4. Functional diagram
1
18
D7
Q7
19
17
D6
Q6
16
14
D5
Q5
15
13
D4
Q4
12
8
D3
Q3
9
7
D2
Q2
6
4
D1
Q1
3
D0
Q0
LE
11
Fig. 1.
11
3
6
14
15
2
17
16
18
19
mna881
mna880
D0
Q0
2
4
D1
Q1
5
7
D2
Q2
6
Q3
9
8
D3
13
D4
14
D5
Q5 15
17
D6
Q6 16
18
D7
Q7 19
3-STATE
OUTPUTS
IEC logic symbol
Q4 12
LE
LE
LE
D
1 OE
Q
mna189
LE
mna882
Product data sheet
7
5
3
74LVC373A_Q100
5
9
Fig. 2.
Functional diagram
4
12
11 LE
Fig. 3.
2
1D
8
Logic symbol
LATCH
1 to 8
C1
13
OE
1
EN
Fig. 4.
Logic diagram (one latch)
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 16
74LVC373A-Q100
Nexperia
D0
D1
D
Q
D2
D
LE LE
Q
D3
D
LE LE
Q
D4
D
LE LE
Q
D5
D
LE LE
Q
D6
D
LE LE
Q
D7
D
LE LE
Q
D
LE LE
Q
LE LE
LE
OE
Q0
Q1
Q2
Q3
Q4
Q5
Q6
Q7
mna883
Fig. 5.
Logic diagram
5. Pinning information
5.1. Pinning
1
OE
terminal 1
index area
2
19 Q7
D0
3
18 D7
D1
4
17 D6
Q1
5
16 Q6
15 Q5
1
20 VCC
Q2
6
Q0
2
19 Q7
D0
3
18 D7
D2
7
D1
4
17 D6
D3
8
Q1
5
16 Q6
Q3
9
Q2
6
15 Q5
D2
7
14 D5
D3
8
13 D4
Q3
9
12 Q4
GND 10
11 LE
Product data sheet
13 D4
12 Q4
001aad089
Transparent top view
Pin configuration SOT163-1 (SO20) and
SOT360-1 (TSSOP20)
74LVC373A_Q100
14 D5
GND(1)
GND 10
OE
(1) This is not a ground pin. There is no electrical or
mechanical requirement to solder the pad. In case
soldered, the solder land should remain floating or
connected to GND.
001aad090
Fig. 6.
Q0
LE 11
74LVC373A
20 VCC
74LVC373A
Fig. 7.
Pin configuration SOT764-1 (DHVQFN20)
3 / 16
74LVC373A-Q100
Nexperia
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
OE
1
output enable input (active LOW)
LE
11
latch enable input (active HIGH)
D0, D1, D2, D3, D4, D5, D6, D7
3, 4, 7, 8, 13, 14, 17, 18
data input
Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7
2, 5, 6, 9, 12, 15, 16, 19
latch output
GND
10
ground (0 V)
VCC
supply voltage
6. Functional description
Table 3. Functional table
H = HIGH voltage level; h = HIGH voltage level one set-up time prior to the HIGH-to-LOW LE transition;
L = LOW voltage level; l = LOW voltage level one set-up time prior to the HIGH-to-LOW LE transition;
Z = High-impedance OFF-state.
Operating modes
Input
Output
Internal latch
OE
LE
Dn
Enable and read register
(transparent mode)
L
H
L
L
L
L
H
H
H
H
Latch and read register
L
L
l
L
L
L
L
h
H
H
H
L
l
L
Z
H
L
h
H
Z
Latch register and disable
outputs
74LVC373A_Q100
Product data sheet
Qn
4 / 16
74LVC373A-Q100
Nexperia
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO > VCC or VO < 0
VO
output voltage
HIGH or LOW-state
[2]
-0.5
3-state
[2]
-0.5
+6.5
V
±50
mA
VI < 0
[1]
Max
Unit
-0.5
+6.5
V
-50
-0.5
+6.5
V
±50
mA
mA
VCC + 0.5 V
IO
output current
ICC
supply current
100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
[2]
[3]
VO = 0 V to VCC
Min
Tamb = -40 °C to +125 °C
[3]
The minimum input voltage ratings may be exceeded if the input current ratings are observed.
The output voltage ratings may be exceeded if the output current ratings are observed.
For SOT163-1 (SO20) package: Ptot derates linearly with 12.3 mW/K above 109 °C.
For SOT360-1 (TSSOP20) package: Ptot derates linearly with 10.0 mW/K above 100 °C.
For SOT764-1 (DHVQFN20) package: Ptot derates linearly with 12.9 mW/K above 111 °C.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCC
1.65
3.6
V
1.2
V
V
HIGH or LOW-state
VCC
V
3-state
V
-40
+125
°C
ns/V
ns/V
supply voltage
functional
VI
input voltage
VO
output voltage
Tamb
ambient temperature
in free air
Δt/ΔV
input transition rise and fall rate VCC = 1.65 V to 2.7 V
VCC = 2.7 V to 3.6 V
74LVC373A_Q100
Product data sheet
5 / 16
74LVC373A-Q100
Nexperia
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VIH
HIGH-level
input voltage
VIL
LOW-level
input voltage
VOH
Conditions
-40 °C to +85 °C
VCC = 1.2 V
VCC = 1.65 V to 1.95 V
Unit
Min
Typ [1]
Max
Min
Max
1.08
1.08
V
0.65VCC
0.65VCC
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
2.0
2.0
V
VCC = 1.2 V
0.12
0.12
V
0.35VCC
0.35VCC
V
0.7
0.7
V
0.8
0.8
V
VCC - 0.2
VCC - 0.3
V
IO = -4 mA; VCC = 1.65 V
1.2
1.05
V
IO = -8 mA; VCC = 2.3 V
1.8
1.65
V
IO = -12 mA; VCC = 2.7 V
2.2
2.05
V
IO = -18 mA; VCC = 3.0 V
2.4
2.25
V
IO = -24 mA; VCC = 3.0 V
2.2
2.0
V
0.2
0.3
V
IO = 4 mA; VCC = 1.65 V
0.45
0.65
V
IO = 8 mA; VCC = 2.3 V
0.6
0.8
V
IO = 12 mA; VCC = 2.7 V
0.4
0.6
V
IO = 24 mA; VCC = 3.0 V
0.55
0.8
V
VI = VIH or VIL
HIGH-level
output voltage
IO = -100 μA;
VCC = 1.65 V to 3.6 V
VI = VIH or VIL
LOW-level
output voltage
IO = 100 μA;
VOL
-40 °C to +125 °C
II
input leakage
current
VCC = 3.6 V; VI = 5.5 V or GND
±0.1
±5
±20
μA
IOZ
OFF-state
output current
VI = VIH or VIL; VCC = 3.6 V;
VO = 5.5 V or GND;
±0.1
±5
±20
μA
IOFF
power-off
VCC = 0 V; VI or VO = 5.5 V
leakage supply
±0.1
±10
±20
μA
ICC
supply current VCC = 3.6 V; VI = VCC or GND;
IO = 0 A
0.1
10
40
μA
ΔICC
additional
per input pin; VCC = 2.7 V to 3.6 V;
supply current VI = VCC - 0.6 V; IO = 0 A
5
500
5000
μA
CI
input
capacitance
5.0
pF
[1]
VCC = 0 V to 3.6 V;
VI = GND to VCC
All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C.
74LVC373A_Q100
Product data sheet
6 / 16
74LVC373A-Q100
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 12.
Symbol Parameter
Conditions
-40 °C to +85 °C
Min
tpd
propagation delay
Dn to Qn; see Fig. 8
14
ns
6.5
15.8
1.5
18.2
ns
1.0
3.4
8.2
1.0
9.4
ns
VCC = 2.7 V
1.5
3.4
7.8
1.5
10.0
ns
VCC = 3.0 V to 3.6 V
1.5
2.9
6.8
1.5
8.5
ns
16
ns
2.2
7.3
16.8
2.2
19.3
ns
1.5
3.9
8.6
1.5
10.0
ns
VCC = 2.7 V
1.5
3.5
8.2
1.5
10.5
ns
1.5
3.3
7.2
1.5
9.0
ns
17
ns
1.5
6.8
17.6
1.5
20.3
ns
1.5
3.8
9.7
1.5
11.2
ns
VCC = 2.7 V
1.5
3.8
8.7
1.5
11.0
ns
1.5
3.1
7.7
1.5
10.0
ns
8.0
ns
2.3
4.3
10.3
2.3
11.9
ns
1.0
2.4
5.8
1.0
6.8
ns
VCC = 2.7 V
1.5
3.2
7.1
1.5
9.0
ns
1.5
3.0
6.1
1.5
8.0
ns
5.0
5.0
ns
4.0
4.0
ns
VCC = 2.7 V
3.0
3.0
ns
3.0
1.5
3.0
ns
4.0
4.0
ns
3.0
3.0
ns
VCC = 2.7 V
2.0
2.0
ns
2.0
0.0
2.0
ns
3.0
3.0
ns
2.0
2.0
ns
VCC = 2.7 V
1.5
1.5
ns
1.5
0.3
1.5
ns
[2]
OE to Qn; see Fig. 10
[2]
VCC = 1.2 V
disable time
[2]
VCC = 1.2 V
tW
tsu
th
pulse width
set-up time
hold time
74LVC373A_Q100
Product data sheet
Max
1.5
VCC = 1.2 V
tdis
Min
LE to Qn; see Fig. 9
enable time
Max
[2]
VCC = 1.2 V
ten
Typ[1]
-40 °C to +125 °C Unit
LE HIGH; see Fig. 9
Dn to LE; see Fig. 11
7 / 16
74LVC373A-Q100
Nexperia
Symbol Parameter
Conditions
-40 °C to +85 °C
Min
Typ[1]
Max
Min
Max
1.0
1.5
ns
16.6
pF
19.2
pF
21.6
pF
tsk(0)
output skew time
[3]
CPD
power dissipation
capacitance
per latch; VI = GND to VCC
[4]
[1]
[2]
[3]
[4]
Typical values are measured at Tamb = 25 °C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V and 3.3 V respectively.
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz; fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
2
Σ(CL × VCC × fo) = sum of the outputs
10.1. Waveforms and test circuit
VI
VM
Dn input
GND
tPHL
tPLH
VOH
VM
Qn output
VOL
mna884
Measurement points are given in Table 8.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 8.
Input (Dn) to output (Qn) propagation delays
1/fmax
VI
LE input
VM
GND
tW
t PHL
t PLH
VOH
VM
Qn output
VOL
mna812
Fig. 9.
Latch Enable input (LE) pulse width, the latch enable input to output (Qn) propagation delays
74LVC373A_Q100
Product data sheet
8 / 16
74LVC373A-Q100
Nexperia
VI
OE input
VM
GND
t PLZ
Qn output
LOW-to-OFF
OFF-to-LOW
t PZL
VCC
V
VOL
t PZH
t PHZ
Qn output
HIGH-to-OFF
OFF-to-HIGH
M
VX
VOH
VY
VM
GND
output
enabled
output
enabled
output
disabled
mna886
Fig. 10. 3-state enable and disable times
VI
VM
Dn input
GND
th
t su
t su
th
VI
LE input
VM
GND
mna814
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig. 11. Data set-up and hold times for the Dn input to the LE input
Table 8. Measurement points
Supply voltage
Input
Output
VCC
VI
VM
VM
VX
VY
1.2 V
VCC
0.5 x VCC
0.5 x VCC
VOL + 0.15 V
VOH - 0.15 V
1.65 V to 1.95 V
VCC
0.5 x VCC
0.5 x VCC
VOL + 0.15 V
VOH - 0.15 V
2.3 V to 2.7 V
VCC
0.5 x VCC
0.5 x VCC
VOL + 0.15 V
VOH - 0.15 V
2.7 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
3.0 V to 3.6 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
74LVC373A_Q100
Product data sheet
9 / 16
74LVC373A-Q100
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig. 12. Test circuit for measuring switching times
Table 9. Test data
Supply voltage Input
Load
VEXT
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
VCC
≤ 2 ns
30 pF
1 kΩ
open
2 x VCC
GND
1.65 V to 1.95 V VCC
≤ 2 ns
30 pF
1 kΩ
open
2 x VCC
GND
2.3 V to 2.7 V
VCC
≤ 2 ns
30 pF
500 Ω
open
2 x VCC
GND
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
2 x VCC
GND
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
2 x VCC
GND
1.2 V
74LVC373A_Q100
Product data sheet
10 / 16
74LVC373A-Q100
Nexperia
11. Package outline
SO20: plastic small outline package; 20 leads; body width 7.5 mm
SOT163-1
D
E
A
X
c
y
HE
v M A
Z
Q
A2
A
(A 3 )
A1
pin 1 index
θ
Lp
L
1
10
e
detail X
w M
bp
10 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
mm
2.65
0.3
0.1
2.45
2.25
0.25
0.49
0.36
0.32
0.23
13.0
12.6
7.6
7.4
1.27
10.65
10.00
1.4
1.1
0.4
1.1
1.0
0.25
0.25
0.1
0.9
0.4
inches
0.1
0.012 0.096
0.004 0.089
0.01
0.019 0.013
0.014 0.009
0.51
0.49
0.30
0.29
0.05
0.419
0.043
0.055
0.394
0.016
0.043
0.039
0.01
0.01
0.004
0.035
0.016
Z
(1)
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT163-1
075E04
MS-013
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 13. Package outline SOT163-1 (SO20)
74LVC373A_Q100
Product data sheet
11 / 16
74LVC373A-Q100
Nexperia
TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm
D
SOT360-1
E
A
X
c
HE
y
v M A
Z
11
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
10
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
6.6
6.4
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.5
0.2
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT360-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Fig. 14. Package outline SOT360-1 (TSSOP20)
74LVC373A_Q100
Product data sheet
12 / 16
74LVC373A-Q100
Nexperia
DHVQFN20: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
20 terminals; body 2.5 x 4.5 x 0.85 mm
B
D
SOT764-1
A
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
e1
C
e
b
2
9
v
w
C A B
C
y1 C
y
L
1
10
Eh
e
19
12
X
Dh
5 mm
scale
Dimensions (mm are the original dimensions)
Unit
mm
A(1)
A1
b
max 1.00 0.05 0.30
nom 0.90 0.02 0.25
min 0.80 0.00 0.18
c
D(1)
Dh
E(1)
Eh
e
e1
L
v
0.2
4.6
4.5
4.4
3.15
3.00
2.85
2.6
2.5
2.4
1.15
1.00
0.85
0.5
3.5
0.5
0.4
0.3
0.1
w
y
0.05 0.05
y1
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
References
Outline
version
IEC
JEDEC
JEITA
SOT764-1
MO-241
sot764-1_po
European
projection
Issue date
03-01-27
14-12-12
Fig. 15. Package outline SOT764-1 (DHVQFN20)
74LVC373A_Q100
Product data sheet
13 / 16
74LVC373A-Q100
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
74LVC373A_Q100 v.3
20210304
Product data sheet
Modifications:
74LVC373A_Q100 v.2
20200824
Modifications:
74LVC373A_Q100 v.1
74LVC373A_Q100
Product data sheet
74LVC373A_Q100 v.2
Type number 74LVC373ADB-Q100 (SOT339-1 / SSOP20) removed.
Section 1 updated.
Fig. 9 and Fig. 11 corrected.
Product data sheet
74LVC373A_Q100 v.1
The format of this data sheet has been redesigned to comply with the identity
guidelines of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
Section 2 updated.
Table 4: Derating values for Ptot total power dissipation have been updated.
Package outline drawing of SOT764-1 (Fig. 15) updated.
20130417
Product data sheet
14 / 16
74LVC373A-Q100
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
14. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74LVC373A_Q100
Product data sheet
15 / 16
74LVC373A-Q100
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................2
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 4
6. Functional description................................................. 4
7. Limiting values............................................................. 5
8. Recommended operating conditions..........................5
9. Static characteristics....................................................6
10. Dynamic characteristics............................................ 7
10.1. Waveforms and test circuit........................................ 8
11. Package outline........................................................ 11
12. Abbreviations............................................................ 14
13. Revision history........................................................14
14. Legal information......................................................15
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 4 March 2021
74LVC373A_Q100
Product data sheet
16 / 16
