74HCT393DB,118
74HCT393DB,118
    NEXPERIA(安世)
    SSOP-14_6.2X5.3MM
    Counter IC Binary Counter 2 Element 4 Bit Negative Edge 14-SSOP
74HCT393DB,118 数据手册
74HC393; 74HCT393 Dual 4-bit binary ripple counter Rev. 8 — 22 October 2021 Product data sheet 1. General description The 74HC393; 74HCT393 is a dual 4-stage binary ripple counter. Each counter features a clock input (nCP), an overriding asynchronous master reset input (nMR) and 4 buffered parallel outputs (nQ0 to nQ3). The counter advances on the HIGH-to-LOW transition of nCP. A HIGH on nMR clears the counter stages and forces the outputs LOW, independent of the state of nCP. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits • • • • • • • • • • Wide supply voltage range from 2.0 V to 6.0 V CMOS low power dissipation High noise immunity Latch-up performance exceeds 100 mA per JESD 78 Class II Level B Complies with JEDEC standards: • JESD8C (2.7 V to 3.6 V) • JESD7A (2.0 V to 6.0 V) Input levels: • For 74HC393: CMOS level • For 74HCT393: TTL level ESD protection: • HBM JESD22-A114F exceeds 2000 V • MM JESD22-A115-A exceeds 200 V. Two 4-bit binary counters with individual clocks Divide by any binary module up to 28 in one package Two master resets to clear each 4-bit counter individually 3. Ordering information Table 1. Ordering information Type number Package 74HC393D Temperature range Name Description Version -40 °C to +125 °C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 -40 °C to +125 °C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 -40 °C to +125 °C DHVQFN14 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 × 3 × 0.85 mm 74HCT393D 74HC393PW 74HCT393PW 74HC393BQ 74HCT393BQ SOT762-1 74HC393; 74HCT393 Nexperia Dual 4-bit binary ripple counter 4. Functional diagram 1 1Q0 1CP 1 2 1MR 13 2CP 2 12 2MR CTR4 3 2 1Q1 4 1Q2 5 1Q3 6 2Q0 11 1 1 2Q1 10 2Q2 9 2Q3 8 CTR4 2 13 12 1MR 2CP 2MR 3 6 0 11 CT = 0 13 10 9 + 3 8 001aad533 1Q0 IEC logic symbol 3 1Q1 4 1Q2 5 1Q3 0 6 2Q0 4-BIT BINARY RIPPLE COUNTER 5 CT Fig. 2. 4-BIT BINARY RIPPLE COUNTER 4 + 12 Logic symbol 1CP 3 CT 001aad532 Fig. 1. 0 CT = 0 11 2Q1 10 2Q2 9 2Q3 8 1 2 3 15 5 14 6 13 7 12 11 10 9 Functional diagram CP Fig. 4. T FF 1 8 001aad535 001aad534 Fig. 3. 4 Q T RD FF 2 State diagram Q T RD FF 3 Q T RD FF 4 Q RD MR Q0 Q1 Q2 Q3 001aad536 Fig. 5. Logic diagram (one counter) 74HC_HCT393 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 22 October 2021 © Nexperia B.V. 2021. All rights reserved 2 / 15 74HC393; 74HCT393 Nexperia Dual 4-bit binary ripple counter 5. Pinning information 5.1. Pinning 1CP 1 terminal 1 index area 1MR 2 13 2CP 1Q0 3 12 2MR 74HC393 74HCT393 1CP 1 14 VCC 1MR 2 13 2CP 1Q0 3 12 2MR 1Q1 4 11 2Q0 1Q2 5 10 2Q1 1Q1 4 11 2Q0 1Q3 6 9 2Q2 1Q2 5 10 2Q1 GND 7 8 2Q3 1Q3 6 9 2Q2 GND 7 8 2Q3 Fig. 6. Pin configuration SOT108-1 (SO14) Fig. 7. Pin configuration SOT402-1 (TSSOP14) 12 2MR 1Q1 4 11 2Q0 1Q2 5 1Q3 6 VCC(1) 13 2CP 10 2Q1 9 2Q2 aaa-007521 Transparent top view (1) This is not a supply pin. There is no electrical or mechanical requirement to solder the pad. In case soldered, the solder land should remain floating or connected to VCC aaa-007523 aaa-007518 3 2Q3 14 VCC 1Q0 8 1 2 7 1CP 1MR GND 74HC393 74HCT393 14 VCC 74HC393 74HCT393 Fig. 8. Pin configuration SOT762-1 (DHVQFN14) 5.2. Pin description Table 2. Pin description Symbol Pin Description 1CP 1 clock input (HIGH-to-LOW, edge-triggered) 1MR 2 asynchronous master reset input (active HIGH) 1Q0, 1Q1, 1Q2, 1Q3 3, 4, 5, 6 flip-flop output GND 7 ground (0 V) 2Q3, 2Q2, 2Q1, 2Q0 8, 9, 10, 11 flip-flop output 2MR 12 asynchronous master reset input (active HIGH) 2CP 13 clock input (HIGH-to-LOW, edge-triggered) VCC 14 supply voltage 74HC_HCT393 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 22 October 2021 © Nexperia B.V. 2021. All rights reserved 3 / 15 74HC393; 74HCT393 Nexperia Dual 4-bit binary ripple counter 6. Functional description Table 3. Count sequence for one counter H = HIGH voltage level; L = LOW voltage level. Count Output nQ0 nQ1 nQ2 nQ3 0 L L L L 1 H L L L 2 L H L L 3 H H L L 4 L L H L 5 H L H L 6 L H H L 7 H H H L 8 L L L H 9 H L L H 10 L H L H 11 H H L H 12 L L H H 13 H L H H 14 L H H H 15 H H H H 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +7 V VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V - ±20 mA IO output current VO = -0.5 V to VCC + 0.5 V - ±25 mA ICC supply current - ±50 mA IGND ground current - ±50 mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 500 mW [1] [1] For SOT108-1 (SO14) package: Ptot derates linearly with 10.1 mW/K above 100 °C. For SOT402-1 (TSSOP14) package: Ptot derates linearly with 7.3 mW/K above 81 °C. For SOT762-1 (DHVQFN14) package: Ptot derates linearly with 9.6 mW/K above 98 °C. 74HC_HCT393 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 22 October 2021 © Nexperia B.V. 2021. All rights reserved 4 / 15 74HC393; 74HCT393 Nexperia Dual 4-bit binary ripple counter 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC393 74HCT393 Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 +25 +125 -40 +25 +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V -40 °C to +125 °C Unit 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V VI = VIH or VIL HIGH-level output voltage IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V VI = VIH or VIL LOW-level output voltage IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V 74HC393 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage - 0.16 0.26 - 0.33 - 0.4 V II input leakage VI = VCC or GND; VCC = 6.0 V current - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 μA CI input capacitance - 3.5 - - - - - pF 74HC_HCT393 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 22 October 2021 © Nexperia B.V. 2021. All rights reserved 5 / 15 74HC393; 74HCT393 Nexperia Dual 4-bit binary ripple counter Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Min Typ Max Min Max Min Max Unit 74HCT393 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH VI = VIH or VIL; VCC = 4.5 V HIGH-level output voltage IO = -20 μA 4.4 4.5 - 4.4 - 4.4 - V 3.98 4.32 - 3.84 - 3.7 - V IO = -4 mA VOL VI = VIH or VIL; VCC = 4.5 V LOW-level output voltage IO = 20 μA IO = 4.0 mA - 0 0.1 - 0.1 - 0.1 V - 0.15 0.26 - 0.33 - 0.4 V II input leakage VI = VCC or GND; VCC = 5.5 V current - - ±0.1 - ±1.0 - ±1.0 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80 - 160 μA ΔICC VI = VCC - 2.1 V; additional supply current other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A per input pin; nCP - 40 144 - 180 - 196 μA per input pin; nMR - 100 360 - 450 - 490 μA - 3.5 - - - - - pF CI input capacitance 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Fig. 11. Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 41 125 - 155 - 190 ns VCC = 4.5 V - 15 25 - 31 - 38 ns VCC = 5 V; CL = 15 pF - 12 - - - - - ns VCC = 6.0 V - 12 21 - 26 - 32 ns VCC = 2.0 V - 14 45 - 55 - 70 ns VCC = 4.5 V - 5 9 - 11 - 14 ns VCC = 5 V; CL = 15 pF - 5 - - - - - ns VCC = 6.0 V - 4 8 - 9 - 12 ns 74HC393 tpd propagation delay nCP to nQ0; see Fig. 9 [1] nQx to nQ(x+1); see Fig. 9 74HC_HCT393 Product data sheet [1] All information provided in this document is subject to legal disclaimers. Rev. 8 — 22 October 2021 © Nexperia B.V. 2021. All rights reserved 6 / 15 74HC393; 74HCT393 Nexperia Dual 4-bit binary ripple counter Symbol Parameter tPHL tt tW HIGH to LOW propagation delay Conditions 25 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 39 140 - 175 - 210 ns VCC = 4.5 V - 14 28 - 35 - 42 ns VCC = 5 V; CL = 15 pF - 11 - - - - - ns VCC = 6.0 V - 11 24 - 30 - 36 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns VCC = 2.0 V 80 17 - 100 - 120 - ns VCC = 4.5 V 16 6 - 20 - 24 - ns VCC = 6.0 V 14 5 - 17 - 20 - ns VCC = 2.0 V 80 19 - 100 - 120 - ns VCC = 4.5 V 16 7 - 20 - 24 - ns VCC = 6.0 V 14 6 - 17 - 20 - ns VCC = 2.0 V 5 3 - 5 - 5 - ns VCC = 4.5 V 5 1 - 5 - 5 - ns VCC = 6.0 V 5 1 - 5 - 5 - ns VCC = 2.0 V 6 30 - 5 - 4 - MHz VCC = 4.5 V 30 90 - 24 - 20 - MHz - 99 - - - - - MHz 35 107 - 28 24 - MHz - 23 - - - - - pF VCC = 4.5 V - 15 25 - 31 - 38 ns VCC = 5 V; CL = 15 pF - 20 - - - - - ns VCC = 4.5 V - 6 10 - 13 - 15 ns VCC = 5 V; CL = 15 pF - 6 - - - - - ns VCC = 4.5 V - 18 32 - 40 - 48 ns VCC = 5 V; CL = 15 pF - 15 - - - - - ns - 7 15 - 19 - 22 ns nMR to nQx; see Fig. 10 transition time Qn; see Fig. 9 pulse width -40 °C to +85 °C [2] nCP HIGH or LOW; see Fig. 9 nMR HIGH; see Fig. 10 trec fclk(max) recovery time maximum clock frequency nMR to nCP; see Fig. 10 see Fig. 9 VCC = 5 V; CL = 15 pF VCC = 6.0 V CPD power dissipation capacitance CL = 50 pF; f = 1 MHz; VI = GND to VCC [3] nCP to nQ0; see Fig. 9 [1] 74HCT393 tpd propagation delay nQx to nQ(x+1); see Fig. 9 tPHL tt HIGH to LOW propagation delay nMR to nQx; see Fig. 10 transition time Qn; see Fig. 9 VCC = 4.5 V 74HC_HCT393 Product data sheet [1] [2] All information provided in this document is subject to legal disclaimers. Rev. 8 — 22 October 2021 © Nexperia B.V. 2021. All rights reserved 7 / 15 74HC393; 74HCT393 Nexperia Dual 4-bit binary ripple counter Symbol Parameter tW pulse width Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max 19 11 - 24 - 29 - ns 16 6 - 20 - 24 - ns 5 0 - 5 - 5 - ns 27 48 - 22 - 18 - MHz - 53 - - - - - MHz - 25 - - - - - pF nCP HIGH or LOW; see Fig. 9 VCC = 4.5 V nMR HIGH; see Fig. 10 VCC = 4.5 V trec recovery time nMR to nCP; see Fig. 10 fclk(max) maximum clock frequency see Fig. 9 power dissipation capacitance CL = 50 pF; f = 1 MHz; VI = GND to VCC - 1.5 V VCC = 4.5 V CPD [1] [2] [3] VCC = 4.5 V VCC = 5 V; CL = 15 pF [3] tpd is the same as tPLH and tPHL. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of outputs. 10.1. Waveforms 1/f max VI input nCP VM GND t PHL t PLH VOH output nQx VM VOL t THL t TLH 001aad537 Measurement points are given in Table 8. VOL and VOH are the typical output voltage levels that occur with the output load. Fig. 9. Propagation delays clock (nCP) to output (nQx), the output transition times and the maximum clock frequency 74HC_HCT393 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 22 October 2021 © Nexperia B.V. 2021. All rights reserved 8 / 15 74HC393; 74HCT393 Nexperia Dual 4-bit binary ripple counter VI input nMR VM GND tW t rec VI input nCP VM GND t PHL VOH output nQx VM VOL 001aad538 Measurement points are given in Table 8. VOL and VOH are the typical output voltage levels that occur with the output load. Fig. 10. Propagation delays clock (nCP) to output (nQx), pulse width master reset (nMR), and recovery time master reset (nMR) to clock (nCP) Table 8. Measurement points Type Input Output VM VM 74HC393 0.5VCC 0.5VCC 74HCT393 1.3 V 1.3 V VI negative pulse VM VI GND VM 10 % GND positive pulse tW 90 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 9. Definitions test circuit: RT = termination resistance should be equal to output impedance Zo of the pulse generator. CL = load capacitance including jig and probe capacitance. Fig. 11. Test circuit for measuring switching times Table 9. Test data Type Load Input Test VI tr, tf CL 74HC393 VCC 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HCT393 3.0 V 6.0 ns 15 pF, 50 pF tPLH, tPHL 74HC_HCT393 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 22 October 2021 © Nexperia B.V. 2021. All rights reserved 9 / 15 74HC393; 74HCT393 Nexperia Dual 4-bit binary ripple counter 11. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.05 0.01 0.01 0.004 0.028 0.012 0.244 0.039 0.028 0.041 0.228 0.016 0.024 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig. 12. Package outline SOT108-1 (SO14) 74HC_HCT393 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 22 October 2021 © Nexperia B.V. 2021. All rights reserved 10 / 15 74HC393; 74HCT393 Nexperia Dual 4-bit binary ripple counter TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm D SOT402-1 E A X c y HE v M A Z 8 14 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 7 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig. 13. Package outline SOT402-1 (TSSOP14) 74HC_HCT393 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 22 October 2021 © Nexperia B.V. 2021. All rights reserved 11 / 15 74HC393; 74HCT393 Nexperia Dual 4-bit binary ripple counter DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 14 terminals; body 2.5 x 3 x 0.85 mm B D SOT762-1 A A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e v w b 2 6 C A B C y y1 C L 1 7 14 8 Eh e k 13 9 Dh X k 0 2 Dimensions (mm are the original dimensions) Unit max nom min mm A(1) 1 A1 b 0.05 0.30 0.02 0.25 0.00 0.18 4 mm scale c D(1) Dh E(1) Eh e e1 0.2 3.1 3.0 2.9 1.65 1.50 1.35 2.6 2.5 2.4 1.15 1.00 0.85 0.5 2 k L v 0.2 0.5 0.4 0.3 0.1 w y 0.05 0.05 y1 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. Outline version SOT762-1 References IEC JEDEC JEITA sot762-1_po European projection Issue date 15-04-10 15-05-05 MO-241 Fig. 14. Package outline SOT762-1 (DHVQFN14) 74HC_HCT393 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 22 October 2021 © Nexperia B.V. 2021. All rights reserved 12 / 15 74HC393; 74HCT393 Nexperia Dual 4-bit binary ripple counter 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT393 v.8 20211022 Product data sheet - Modifications: • 74HC_HCT393 v.7.1 20201021 Modifications: • • • • • • Table 6: VOH and VOL conditions for 74HCT393 corrected. (Errata) Product data sheet - 74HC_HCT393 v.6 The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type numbers 74HC393DB and 74HCT393DB (SOT337-1/SSOP14) removed. Section 1 (Errata) and Section 2 updated. Table 4: Derating values for Ptot total power dissipation updated. v.7.1: Table 6: Values input leakage current for 74HC393 aligned with 74HCT393. (Errata) 74HC_HCT393 v.6 20151203 Modifications: • 74HC_HCT393 v.5 20140401 Modifications: • 74HC_HCT393 v.4 20130516 Modifications: • • 74HC_HCT393 v.7.1 Product data sheet - 74HC_HCT393 v.5 Type numbers 74HC393N and 74HCT393N (SOT27-1) removed. Product data sheet - 74HC_HCT393 v.4 Table 7: The conditions for CPD have been corrected (errata). Product data sheet - 74HC_HCT393 v.3 The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. Legal texts have been adapted to the new company name where appropriate. 74HC_HCT393 v.3 20050906 Product data sheet - 74HC_HCT393_CNV v.2 74HC_HCT393_CNV v.2 19901201 Product specification - - 74HC_HCT393 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 22 October 2021 © Nexperia B.V. 2021. All rights reserved 13 / 15 74HC393; 74HCT393 Nexperia Dual 4-bit binary ripple counter 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74HC_HCT393 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 8 — 22 October 2021 © Nexperia B.V. 2021. All rights reserved 14 / 15 74HC393; 74HCT393 Nexperia Dual 4-bit binary ripple counter Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 3 6. Functional description................................................. 4 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................5 9. Static characteristics....................................................5 10. Dynamic characteristics............................................ 6 10.1. Waveforms.................................................................8 11. Package outline........................................................ 10 12. Abbreviations............................................................ 13 13. Revision history........................................................13 14. Legal information......................................................14 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 22 October 2021 74HC_HCT393 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 8 — 22 October 2021 © Nexperia B.V. 2021. All rights reserved 15 / 15
74HCT393DB,118 价格&库存
很抱歉,暂时无法提供与“74HCT393DB,118”相匹配的价格&库存,您可以联系我们找货
