74LVC2T45GD,125
74LVC2T45GD,125
    NEXPERIA(安世)
    XSON8
    TXRX TRANSLATING 3ST XSON8U
74LVC2T45GD,125 数据手册
74LVC2T45; 74LVCH2T45 Dual supply translating transceiver; 3-state Rev. 11 — 16 September 2021 Product data sheet 1. General description The 74LVC2T45; 74LVCH2T45 are dual bit, dual supply translating transceivers with 3-state outputs that enable bidirectional level translation. They feature two 2-bits input-output ports (nA and nB), a direction control input (DIR) and dual supply pins (VCC(A) and VCC(B)). Both VCC(A) and VCC(B) can be supplied at any voltage between 1.2 V and 5.5 V making the device suitable for translating between any of the low voltage nodes (1.2 V, 1.5 V, 1.8 V, 2.5 V, 3.3 V and 5.0 V). Pins nA and DIR are referenced to VCC(A) and pins nB are referenced to VCC(B). A HIGH on DIR allows transmission from nA to nB and a LOW on DIR allows transmission from nB to nA. The devices are fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing any damaging backflow current through the device when it is powered down. In suspend mode when either VCC(A) or VCC(B) are at GND level, both A port and B port are in the high-impedance OFF-state. Active bus hold circuitry in the 74LVCH2T45 holds unused or floating data inputs at a valid logic level. 2. Features and benefits • • • • • • • • • • • • • Wide supply voltage range: • VCC(A): 1.2 V to 5.5 V • VCC(B): 1.2 V to 5.5 V High noise immunity Complies with JEDEC standards: • JESD8-7 (1.2 V to 1.95 V) • JESD8-5 (1.8 V to 2.7 V) • JESD8C (2.7 V to 3.6 V) • JESD36 (4.5 V to 5.5 V) ESD protection: • HBM JESD22-A114F Class 3A exceeds 4000 V • MM JESD22-A115-A exceeds 200 V • CDM JESD22-C101E exceeds 1000 V Maximum data rates: • 420 Mbps (3.3 V to 5.0 V translation) • 210 Mbps (translate to 3.3 V)) • 140 Mbps (translate to 2.5 V) • 75 Mbps (translate to 1.8 V) • 60 Mbps (translate to 1.5 V) Suspend mode Latch-up performance exceeds 100 mA per JESD 78 Class II ±24 mA output drive (VCC = 3.0 V) Inputs accept voltages up to 5.5 V Low power consumption: 16 μA maximum ICC IOFF circuitry provides partial Power-down mode operation Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state 3. Ordering information Table 1. Ordering information Type number Package 74LVC2T45DC Temperature range Name Description -40 °C to +125 °C VSSOP8 plastic very thin shrink small outline package; 8 leads; SOT765-1 body width 2.3 mm -40 °C to +125 °C XSON8 plastic extremely thin small outline package; no leads; SOT833-1 8 terminals; body 1 × 1.95 × 0.5 mm -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35 × 1 × 0.5 mm SOT1089 -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.2 × 1.0 × 0.35 mm SOT1116 -40 °C to +125 °C XSON8 extremely thin small outline package; no leads; 8 terminals; body 1.35 × 1.0 × 0.35 mm SOT1203 74LVCH2T45DC 74LVC2T45GT 74LVCH2T45GT 74LVC2T45GF 74LVCH2T45GF 74LVC2T45GN 74LVCH2T45GN 74LVC2T45GS 74LVCH2T45GS Version 4. Marking Table 2. Marking Type number Marking code [1] 74LVC2T45DC V45 74LVCH2T45DC X45 74LVC2T45GT V45 74LVCH2T45GT X45 74LVC2T45GF V5 74LVCH2T45GF X5 74LVC2T45GN V5 74LVCH2T45GN X5 74LVC2T45GS V5 74LVCH2T45GS X5 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 2 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state 5. Functional diagram DIR 1A 5 DIR 2 1A 7 2A 1B 1B 3 2A 6 VCC(A) 2B 2B VCC(B) VCC(A) VCC(B) 001aag577 Fig. 1. 001aag578 Logic symbol Fig. 2. Logic diagram 6. Pinning information 6.1. Pinning 74LVC2T45 74LVCH2T45 VCC(A) 1 8 VCC(B) 1A 2 7 1B 2A 3 6 2B GND 4 5 DIR 74LVC2T45 74LVCH2T45 VCC(A) 1 8 VCC(B) 1A 2 7 1B 2A 3 6 2B GND 4 5 DIR 001aai905 Transparent top view 001aai904 Fig. 3. Pin configuration SOT765-1 (VSSOP8) 74LVC_LVCH2T45 Product data sheet Fig. 4. Pin configuration SOT833-1, SOT1089, SOT1116 and SOT1203 (XSON8) All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 3 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state 6.2. Pin description Table 3. Pin description Symbol Pin Description VCC(A) 1 supply voltage A (port A and DIR) 1A 2 data input or output 2A 3 data input or output GND 4 ground (0 V) DIR 5 direction control 2B 6 data input or output 1B 7 data input or output VCC(B) 8 supply voltage B (port B) 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Supply voltage Input Input/output [1] VCC(A), VCC(B) DIR nA nB 1.2 V to 5.5 V L nA = nB input 1.2 V to 5.5 V H input nB = nA GND [2] X Z Z [1] [2] The input circuit of the data I/O is always active. When either VCC(A) or VCC(B) is at GND level, the device goes into suspend mode. 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 4 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC(A) supply voltage A -0.5 +6.5 V VCC(B) supply voltage B -0.5 +6.5 V IIK input clamping current VI input voltage IOK output clamping current VO < 0 V VO output voltage Active mode VI < 0 V [1] -50 - -0.5 +6.5 -50 - [1][2][3] -0.5 Suspend or 3-state mode [1] -0.5 [2] mA V mA VCCO + 0.5 V +6.5 V - ±50 mA - 100 mA IO output current VO = 0 V to VCCO ICC supply current ICC(A) or ICC(B) IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 250 mW [1] [2] [3] [4] Tamb = -40 °C to +125 °C [4] The minimum input voltage ratings and output voltage ratings may be exceeded if the input and output current ratings are observed. VCCO is the supply voltage associated with the output port. VCCO + 0.5 V should not exceed 6.5 V. For SOT765-1 (VSSOP8) package: Ptot derates linearly with 4.9 mW/K above 99 °C. For SOT833-1 (XSON8) package: Ptot derates linearly with 3.1 mW/K above 68 °C. For SOT1089 (XSON8) package: Ptot derates linearly with 4.0 mW/K above 88 °C. For SOT1116 (XSON8) package: Ptot derates linearly with 4.2 mW/K above 90 °C. For SOT1203 (XSON8) package: Ptot derates linearly with 3.6 mW/K above 81 °C. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Conditions Min Max Unit VCC(A) supply voltage A 1.2 5.5 V VCC(B) supply voltage B 1.2 5.5 V VI input voltage 0 5.5 V VO output voltage 0 VCCO V 0 5.5 V -40 +125 °C - 20 ns/V VCCI = 1.4 V to 1.95 V - 20 ns/V VCCI = 2.3 V to 2.7 V - 20 ns/V VCCI = 3 V to 3.6 V - 10 ns/V VCCI = 4.5 V to 5.5 V - 5 ns/V Active mode [1] Suspend or 3-state mode Tamb ambient temperature Δt/ΔV input transition rise and fall rate [1] [2] VCCI = 1.2 V [2] VCCO is the supply voltage associated with the output port. VCCI is the supply voltage associated with the input port. 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 5 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state 10. Static characteristics Table 7. Typical static characteristics at Tamb = 25 °C At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ Max VOH HIGH-level output voltage VI = VIH or VIL; IO = -3 mA; VCCO = 1.2 V VOL LOW-level output voltage II Unit [1] - 1.09 - V VI = VIH or VIL; IO = 3 mA; VCCO = 1.2 V [1] - 0.07 - V input leakage current DIR input; VI = 0 V to 5.5 V; VCCI = 1.2 V to 5.5 V [2] - - ±1 μA IBHL bus hold LOW current A or B port; VI = 0.42 V; VCCI = 1.2 V [2] - 19 - μA IBHH bus hold HIGH current A or B port; VI = 0.78 V; VCCI = 1.2 V [2] - -19 - μA IBHLO bus hold LOW overdrive current A or B port; VCCI = 1.2 V [2][3] - 19 - μA IBHHO bus hold HIGH overdrive current A or B port; VCCI = 1.2 V [2][3] - -19 - μA IOZ OFF-state output current A or B port; VO = 0 V or VCCO; VCCO = 1.2 V to 5.5 V [1] - - ±1 μA IOFF power-off leakage current A port; VI or VO = 0 V to 5.5 V; VCC(A) = 0 V; VCC(B) = 1.2 V to 5.5 V - - ±1 μA B port; VI or VO = 0 V to 5.5 V; VCC(B) = 0 V; VCC(A) = 1.2 V to 5.5 V - - ±1 μA CI input capacitance DIR input; VI = 0 V or 3.3 V; VCC(A) = VCC(B) = 3.3 V - 2.2 - pF CI/O input/output capacitance A and B port; suspend mode; VO = 3.3 V or 0 V; VCC(A) = VCC(B) = 3.3 V - 6.0 - pF [1] [2] [3] VCCO is the supply voltage associated with the output port. VCCI is the supply voltage associated with the data input port. To guarantee the node switches, an external driver must source/sink at least IBHLO/IBHHO when the input is in the range VIL to VIH. Table 8. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions VIH data input HIGH-level input voltage -40 °C to +85 °C -40 °C to +125 °C Unit Min Max Min Max VCCI = 1.2 V 0.8VCCI - 0.8VCCI - V VCCI = 1.4 V to 1.95 V 0.65VCCI - 0.65VCCI - V VCCI = 2.3 V to 2.7 V 1.7 - 1.7 - V VCCI = 3.0 V to 3.6 V 2.0 - 2.0 - V VCCI = 4.5 V to 5.5 V 0.7VCCI - 0.7VCCI - V VCCI = 1.2 V 0.8VCC(A) - 0.8VCC(A) - V VCCI = 1.4 V to 1.95 V 0.65VCC(A) - 0.65VCC(A) - V VCCI = 2.3 V to 2.7 V 1.7 - 1.7 - V VCCI = 3.0 V to 3.6 V 2.0 - 2.0 - V VCCI = 4.5 V to 5.5 V 0.7VCC(A) - 0.7VCC(A) - V [1] DIR input 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 6 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state Symbol Parameter Conditions -40 °C to +85 °C Min VIL LOW-level input data input voltage VCCI = 1.2 V -40 °C to +125 °C Max Min Unit Max [1] - 0.2VCCI - 0.2VCCI V VCCI = 1.4 V to 1.95 V - 0.35VCCI - 0.35VCCI V VCCI = 2.3 V to 2.7 V - 0.7 - 0.7 V VCCI = 3.0 V to 3.6 V - 0.8 - 0.8 V VCCI = 4.5 V to 5.5 V - 0.3VCCI - 0.3VCCI V VCCI = 1.2 V - 0.2VCC(A) - 0.2VCC(A) V VCCI = 1.4 V to 1.95 V - 0.35VCC(A) - 0.35VCC(A) V VCCI = 2.3 V to 2.7 V - 0.7 - 0.7 V VCCI = 3.0 V to 3.6 V - 0.8 - 0.8 V VCCI = 4.5 V to 5.5 V - 0.3VCC(A) - - VCCO - 0.1 - V DIR input VOH VOL HIGH-level output voltage LOW-level output voltage IO = -100 μA; VCCO = 1.2 V to 4.5 V [2] VCCO - 0.1 IO = -6 mA; VCCO = 1.4 V 1.0 - 1.0 - V IO = -8 mA; VCCO = 1.65 V 1.2 - 1.2 - V IO = -12 mA; VCCO = 2.3 V 1.9 - 1.9 - V IO = -24 mA; VCCO = 3.0 V 2.4 - 2.4 - V IO = -32 mA; VCCO = 4.5 V 3.8 - 3.8 - V IO = 100 μA; VCCO = 1.2 V to 4.5 V - 0.1 - 0.1 V IO = 6 mA; VCCO = 1.4 V - 0.3 - 0.3 V IO = 8 mA; VCCO = 1.65 V - 0.45 - 0.45 V IO = 12 mA; VCCO = 2.3 V - 0.3 - 0.3 V IO = 24 mA; VCCO = 3.0 V - 0.55 - 0.55 V IO = 32 mA; VCCO = 4.5 V - 0.55 - 0.55 V - ±2 - ±10 μA VI = 0.49 V; VCCI = 1.4 V 15 - 10 - μA VI = 0.58 V; VCCI = 1.65 V 25 - 20 - μA VI = 0.70 V; VCCI = 2.3 V 45 - 45 - μA VI = 0.80 V; VCCI = 3.0 V 100 - 80 - μA 100 - 100 - μA VI = 0.91 V; VCCI = 1.4 V -15 - -10 - μA VI = 1.07 V; VCCI = 1.65 V -25 - -20 - μA VI = 1.60 V; VCCI = 2.3 V -45 - -45 - μA VI = 2.00 V; VCCI = 3.0 V -100 - -80 - μA VI = 3.15 V; VCCI = 4.5 V -100 - -100 - μA VI = VIL [2] II input leakage current DIR input; VI = 0 V to 5.5 V; VCCI = 1.2 V to 5.5 V IBHL bus hold LOW current A or B port [1] VI = 1.35 V; VCCI = 4.5 V IBHH bus hold HIGH current 74LVC_LVCH2T45 Product data sheet 0.3VCC(A) V VI = VIH A or B port [1] All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 7 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state Symbol Parameter IBHLO IBHHO bus hold LOW overdrive current bus hold HIGH overdrive current Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Max Min Max VCCI = 1.6 V 125 - 125 - μA VCCI = 1.95 V 200 - 200 - μA VCCI = 2.7 V 300 - 300 - μA VCCI = 3.6 V 500 - 500 - μA VCCI = 5.5 V 900 - 900 - μA VCCI = 1.6 V -125 - -125 - μA VCCI = 1.95 V -200 - -200 - μA VCCI = 2.7 V -300 - -300 - μA VCCI = 3.6 V -500 - -500 - μA -900 - -900 - μA - ±2 - ±10 μA A or B port [1][3] A or B port [1][3] VCCI = 5.5 V IOZ OFF-state output current IOFF A port; VI or VO = 0 V to 5.5 V; power-off leakage current VCC(A) = 0 V; VCC(B) = 1.2 V to 5.5 V - ±2 - ±10 μA B port; VI or VO = 0 V to 5.5 V; VCC(B) = 0 V; VCC(A) = 1.2 V to 5.5 V - ±2 - ±10 μA VCC(A), VCC(B) = 1.2 V to 5.5 V - 8 - 8 μA VCC(A), VCC(B) = 1.65 V to 5.5 V - 3 - 3 μA VCC(A) = 5.5 V; VCC(B) = 0 V - 2 - 2 μA VCC(A) = 0 V; VCC(B) = 5.5 V -2 - -2 - μA - 8 - 8 μA VCC(A), VCC(B) = 1.65 V to 5.5 V - 3 - 3 μA VCC(B) = 0 V; VCC(A) = 5.5 V -2 - -2 - μA VCC(B) = 5.5 V; VCC(A) = 0 V - 2 - 2 μA VCC(A), VCC(B) = 1.2 V to 5.5 V - 16 - 16 μA VCC(A), VCC(B) = 1.65 V to 5.5 V - 4 - 4 μA - 50 - 75 μA - 50 - 75 μA - 50 - 75 μA ICC supply current A or B port; VO = 0 V or VCCO; VCCO = 1.2 V to 5.5 V A port; VI = 0 V or VCCI; IO = 0 A [2] [1] B port; VI = 0 V or VCCI; IO = 0 A VCC(A), VCC(B) = 1.2 V to 5.5 V A plus B port (ICC(A) + ICC(B)); IO = 0 A; VI = 0 V or VCCI ΔICC additional supply current per input; VCC(A), VCC(B) = 3.0 V to 5.5 V A port; A port at VCC(A) - 0.6 V; DIR at VCC(A); B port = open [4] DIR input; DIR at VCC(A) - 0.6 V; A port at VCC(A) or GND; B port = open B port; B port at VCC(B) - 0.6 V; DIR at GND; A port = open [1] [2] [3] [4] [4] VCCI is the supply voltage associated with the data input port. VCCO is the supply voltage associated with the output port. To guarantee the node switches, an external driver must source/sink at least IBHLO/IBHHO when the input is in the range VIL to VIH. For non bus hold parts only (74LVC2T45). 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 8 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state 11. Dynamic characteristics Table 9. Typical dynamic characteristics at VCC(A) = 1.2 V and Tamb = 25 °C Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7; for waveforms see Fig. 5 and Fig. 6. Symbol Parameter Conditions VCC(B) Unit 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V 5.0 V tPLH LOW to HIGH propagation delay A to B 10.6 8.1 7.0 5.8 5.3 5.1 ns B to A 10.6 9.5 9.0 8.5 8.3 8.2 ns tPHL HIGH to LOW propagation delay A to B 10.1 7.1 6.0 5.3 5.2 5.4 ns B to A 10.1 8.6 8.1 7.8 7.6 7.6 ns HIGH to OFF-state propagation delay DIR to A 9.4 9.4 9.4 9.4 9.4 9.4 ns DIR to B 12.0 9.4 9.0 7.8 8.4 7.9 ns LOW to OFF-state propagation delay DIR to A 7.1 7.1 7.1 7.1 7.1 7.1 ns DIR to B 9.5 7.8 7.7 6.9 7.6 7.0 ns OFF-state to HIGH propagation delay DIR to A [1] 20.1 17.3 16.7 15.4 15.9 15.2 ns DIR to B [1] 17.7 15.2 14.1 12.9 12.4 12.2 ns OFF-state to LOW propagation delay DIR to A [1] 22.1 18.0 17.1 15.6 16.0 15.5 ns DIR to B [1] 19.5 16.5 15.4 14.7 14.6 14.8 ns tPHZ tPLZ tPZH tPZL [1] tPZH and tPZL are calculated values using the formula shown in Section 13.4. Table 10. Typical dynamic characteristics at VCC(B) = 1.2 V and Tamb = 25 °C Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7; for waveforms see Fig. 5 and Fig. 6. Symbol Parameter Conditions VCC(A) Unit 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V 5.0 V LOW to HIGH propagation delay A to B 10.6 9.5 9.0 8.5 8.3 8.2 ns B to A 10.6 8.1 7.0 5.8 5.3 5.1 ns tPHL HIGH to LOW propagation delay A to B 10.1 8.6 8.1 7.8 7.6 7.6 ns B to A 10.1 7.1 6.0 5.3 5.2 5.4 ns tPHZ HIGH to OFF-state propagation delay DIR to A 9.4 6.5 5.7 4.1 4.1 3.0 ns DIR to B 12.0 6.1 5.4 4.6 4.3 4.0 ns LOW to OFF-state propagation delay DIR to A 7.1 4.9 4.5 3.2 3.4 2.5 ns DIR to B 9.5 7.3 6.6 5.9 5.7 5.6 ns OFF-state to HIGH propagation delay DIR to A [1] 20.1 15.4 13.6 11.7 11.0 10.7 ns DIR to B [1] 17.7 14.4 13.5 11.7 11.7 10.7 ns OFF-state to LOW propagation delay DIR to A [1] 22.1 13.2 11.4 9.9 9.5 9.4 ns DIR to B [1] 19.5 15.1 13.8 11.9 11.7 10.6 ns tPLH tPLZ tPZH tPZL [1] tPZH and tPZL are calculated values using the formula shown in Section 13.4. 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 9 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state Table 11. Typical power dissipation capacitance at VCC(A) = VCC(B) and Tamb = 25 °C Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 1.8 V 2.5 V 3.3 V 5.0 V CPD A port: (direction A to B); B port: (direction B to A) 2 3 3 4 pF A port: (direction A to B); B port: (direction B to A) 15 16 16 18 pF [1] [2] power dissipation capacitance[1] [2] VCC(A) and VCC(B) Unit CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of the outputs. fi = 10 MHz; VI = GND to VCC; tr = tf = 1 ns; CL = 0 pF; RL = ∞ Ω. Table 12. Dynamic characteristics for temperature range -40 °C to +85 °C Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7; for waveforms see Fig. 5 and Fig. 6. Symbol Parameter Conditions VCC(B) Unit 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.4 V to 1.6 V tPLH LOW to HIGH propagation delay A to B 2.8 21.3 2.4 17.6 2.0 13.5 1.7 11.8 1.6 10.5 ns B to A 2.8 21.3 2.6 19.1 2.3 14.9 2.3 12.4 2.2 12.0 ns tPHL HIGH to LOW propagation delay A to B 2.6 19.3 2.2 15.3 1.8 11.8 1.7 10.9 1.7 10.8 ns B to A 2.6 19.3 2.4 17.3 2.3 13.2 2.2 11.3 2.3 11.0 ns HIGH to OFF-state propagation delay DIR to A 3.0 18.7 3.0 18.7 3.0 18.7 3.0 18.7 3.0 18.7 ns DIR to B 3.5 24.8 3.5 23.6 3.0 11.0 3.3 11.3 2.8 10.3 ns LOW to OFF-state propagation delay DIR to A 2.4 11.4 2.4 11.4 2.4 11.4 2.4 11.4 2.4 11.4 ns DIR to B 2.8 18.3 3.0 17.2 2.5 9.4 3.0 10.1 2.5 9.4 OFF-state to HIGH propagation delay DIR to A [1] - 39.6 - 36.3 - 24.3 - 22.5 - 21.4 ns DIR to B [1] - 32.7 - 29.0 - 24.9 - 23.2 - 21.9 ns OFF-state to LOW propagation delay DIR to A [1] - 44.1 - 40.9 - 24.2 - 22.6 - 21.3 ns DIR to B [1] - 38.0 - 34.0 - 30.5 - 29.6 - 29.5 ns tPHZ tPLZ tPZH tPZL 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © ns Nexperia B.V. 2021. All rights reserved 10 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state Symbol Parameter Conditions VCC(B) Unit 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.65 V to 1.95 V LOW to HIGH propagation delay A to B 2.6 19.1 2.2 17.7 2.2 9.3 1.7 7.2 1.4 6.8 B to A 2.4 17.6 2.2 17.7 2.3 16.0 2.1 15.5 1.9 15.1 ns HIGH to LOW propagation delay A to B 2.4 17.3 2.0 14.3 1.6 8.5 1.8 7.1 1.7 7.0 B to A 2.2 15.3 2.0 14.3 2.1 12.9 2.0 12.6 1.8 12.2 ns HIGH to OFF-state propagation delay DIR to A 2.9 17.1 2.9 17.1 2.9 17.1 2.9 17.1 2.9 17.1 ns DIR to B 3.2 24.1 3.2 21.9 2.7 11.5 3.0 10.3 2.5 8.2 LOW to OFF-state propagation delay DIR to A 2.4 10.5 2.4 10.5 2.4 10.5 2.4 10.5 2.4 10.5 ns DIR to B 2.5 17.6 2.6 16.0 2.2 9.2 2.7 8.4 2.4 7.1 tPZH OFF-state to HIGH propagation delay DIR to A [1] - 35.2 - 33.7 - 25.2 - 23.9 - 22.2 ns DIR to B [1] - 29.6 - 28.2 - 19.8 - 17.7 - 17.3 ns tPZL OFF-state to LOW propagation delay DIR to A [1] - 39.4 - 36.2 - 24.4 - 22.9 - 20.4 ns DIR to B [1] - 34.4 - 31.4 - 25.6 - 24.2 - 24.1 ns 16.0 1.5 8.5 1.3 6.2 1.1 4.8 ns tPLH tPHL tPHZ tPLZ ns ns ns ns VCC(A) = 2.3 V to 2.7 V tPLH LOW to HIGH propagation delay A to B 2.3 17.9 2.3 B to A 2.0 13.5 2.2 9.3 1.5 8.5 1.4 8.0 1.0 7.5 ns tPHL HIGH to LOW propagation delay A to B 2.3 15.8 2.1 12.9 1.4 7.5 1.3 5.4 0.9 4.6 ns B to A 1.8 11.8 1.9 8.5 1.4 7.5 1.3 7.0 0.9 6.2 ns HIGH to OFF-state propagation delay DIR to A 2.1 8.1 2.1 8.1 2.1 8.1 2.1 8.1 2.1 8.1 ns DIR to B 3.0 22.5 3.0 21.4 2.5 11.0 2.8 9.3 2.3 6.9 ns LOW to OFF-state propagation delay DIR to A 1.7 5.8 1.7 5.8 1.7 5.8 1.7 5.8 1.7 5.8 ns DIR to B 2.3 14.6 2.5 13.2 2.0 9.0 2.5 8.4 1.8 5.8 ns OFF-state to HIGH propagation delay DIR to A [1] - 28.1 - 22.5 - 17.5 - 16.4 - 13.3 ns DIR to B [1] - 23.7 - 21.8 - 14.3 - 12.0 - 10.6 ns OFF-state to LOW propagation delay DIR to A [1] - 34.3 - 29.9 - 18.5 - 16.3 - 13.1 ns DIR to B [1] - 23.9 - 21.0 - 15.6 - 13.5 - 12.7 ns tPHZ tPLZ tPZH tPZL VCC(A) = 3.0 V to 3.6 V LOW to HIGH propagation delay A to B 2.3 17.1 2.1 15.5 1.4 8.0 0.8 5.6 0.7 4.4 ns B to A 1.7 11.8 1.7 7.2 1.3 6.2 0.7 5.6 0.6 5.4 ns tPHL HIGH to LOW propagation delay A to B 2.2 15.6 2.0 12.6 1.3 7.0 0.8 5.0 0.7 4.0 ns B to A 1.7 10.9 1.8 7.1 1.3 5.4 0.8 5.0 0.7 4.5 ns tPHZ HIGH to OFF-state propagation delay DIR to A 2.3 7.3 2.3 7.3 2.3 7.3 2.3 7.3 2.7 7.3 ns DIR to B 2.9 18.0 2.9 16.5 2.3 10.1 2.7 8.6 2.2 6.3 ns LOW to OFF-state propagation delay DIR to A 2.0 5.6 2.0 5.6 2.0 5.6 2.0 5.6 2.0 5.6 ns DIR to B 2.3 13.6 2.4 12.5 1.9 7.8 2.3 7.1 1.7 4.9 ns OFF-state to HIGH propagation delay DIR to A [1] - 25.4 - 19.7 - 14.0 - 12.7 - 10.3 ns DIR to B [1] - 22.7 - 21.1 - 13.6 - 11.2 - 10.0 ns OFF-state to LOW propagation delay DIR to A [1] - 28.9 - 23.6 - 15.5 - 13.6 - 10.8 ns DIR to B [1] - 22.9 - 19.9 - 14.3 - 12.3 - 11.3 ns tPLH tPLZ tPZH tPZL 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 11 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state Symbol Parameter Conditions VCC(B) Unit 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 4.5 V to 5.5 V LOW to HIGH propagation delay A to B 2.2 16.6 1.9 15.1 1.0 7.5 0.7 5.4 0.5 3.9 ns B to A 1.6 10.5 1.4 6.8 1.0 4.8 0.7 4.4 0.5 3.9 ns HIGH to LOW propagation delay A to B 2.3 15.3 1.8 12.2 1.0 6.2 0.7 4.5 0.5 3.5 ns B to A 1.7 10.8 1.7 7.0 0.9 4.6 0.7 4.0 0.5 3.5 ns HIGH to OFF-state propagation delay DIR to A 1.7 5.4 1.7 5.4 1.7 5.4 1.7 5.4 1.7 5.4 ns DIR to B 2.9 17.3 2.9 16.1 2.3 9.7 2.7 8.0 2.5 5.7 ns LOW to OFF-state propagation delay DIR to A 1.4 3.7 1.4 3.7 1.3 3.7 1.0 3.7 0.9 3.7 ns DIR to B 2.3 13.1 2.4 12.1 1.9 7.4 2.3 7.0 1.8 4.5 ns tPZH OFF-state to HIGH propagation delay DIR to A [1] - 23.6 - 18.9 - 12.2 - 11.4 - 8.4 ns DIR to B [1] - 20.3 - 18.8 - 11.2 - 9.1 - 7.6 ns tPZL OFF-state to LOW propagation delay DIR to A [1] - 28.1 - 23.1 - 14.3 - 12.0 - 9.2 ns DIR to B [1] - 20.7 - 17.6 - 11.6 - 9.9 - 8.9 ns tPLH tPHL tPHZ tPLZ [1] tPZH and tPZL are calculated values using the formula shown in Section 13.4. Table 13. Dynamic characteristics for temperature range -40 °C to +125 °C Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 7; for waveforms see Fig. 5 and Fig. 6. Symbol Parameter Conditions VCC(B) Unit 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.4 V to 1.6 V LOW to HIGH propagation delay A to B 2.5 23.5 2.1 19.4 1.8 14.9 1.5 13.0 1.4 11.6 ns B to A 2.5 23.5 2.3 21.1 2.0 16.4 2.0 13.7 1.9 13.2 ns tPHL HIGH to LOW propagation delay A to B 2.3 21.3 1.9 16.9 1.6 13.0 1.5 12.0 1.5 11.9 ns B to A 2.3 21.3 2.1 19.1 2.0 14.6 1.9 12.5 2.0 12.1 ns tPHZ HIGH to OFF-state propagation delay DIR to A 2.7 20.6 2.7 20.6 2.7 20.6 2.7 20.6 2.7 20.6 ns DIR to B 3.1 27.3 3.1 26.0 2.7 12.1 2.9 12.5 2.5 11.4 ns LOW to OFF-state propagation delay DIR to A 2.1 12.6 2.1 12.6 2.1 12.6 2.1 12.6 2.1 12.6 ns DIR to B 2.5 20.2 2.7 19.0 2.2 10.4 2.7 11.2 2.2 10.4 ns OFF-state to HIGH propagation delay DIR to A [1] - 43.7 - 40.1 - 26.8 - 24.9 - 23.6 ns DIR to B [1] - 36.1 - 32.0 - 27.5 - 25.6 - 24.2 ns OFF-state to LOW propagation delay DIR to A [1] - 48.6 - 45.1 - 26.7 - 25.0 - 23.5 ns DIR to B [1] - 41.9 - 37.5 - 33.6 - 32.6 - 32.5 ns tPLH tPLZ tPZH tPZL 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 12 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state Symbol Parameter Conditions VCC(B) Unit 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.65 V to 1.95 V LOW to HIGH propagation delay A to B 2.3 21.1 1.9 19.5 1.9 10.3 1.5 8.0 1.2 7.5 B to A 2.1 19.4 1.9 19.5 2.0 17.6 1.8 17.1 1.7 16.7 ns HIGH to LOW propagation delay A to B 2.1 19.1 1.8 15.8 1.4 9.4 1.6 7.9 1.5 7.7 B to A 1.9 16.9 1.8 15.8 1.8 14.2 1.8 13.9 1.6 13.5 ns HIGH to OFF-state propagation delay DIR to A 2.6 18.9 2.6 18.9 2.6 18.9 2.6 18.9 2.6 18.9 ns DIR to B 2.8 26.6 2.8 24.1 2.4 12.7 2.7 11.4 2.2 9.1 LOW to OFF-state propagation delay DIR to A 2.1 11.6 2.1 11.6 2.1 11.6 2.1 11.6 2.1 11.6 ns DIR to B 2.2 19.4 2.3 17.6 1.9 10.2 2.4 9.3 2.1 7.9 tPZH OFF-state to HIGH propagation delay DIR to A [1] - 38.8 - 37.1 - 27.8 - 26.4 - 24.6 ns DIR to B [1] - 32.7 - 31.1 - 21.9 - 19.6 - 19.1 ns tPZL OFF-state to LOW propagation delay DIR to A [1] - 43.5 - 39.9 - 26.9 - 25.3 - 22.6 ns DIR to B [1] - 38.0 - 34.7 - 28.3 - 26.8 - 26.6 ns tPLH tPHL tPHZ tPLZ ns ns ns ns VCC(A) = 2.3 V to 2.7 V tPLH LOW to HIGH propagation delay A to B 2.0 19.7 2.0 17.6 1.3 9.4 1.1 6.9 0.9 5.3 ns B to A 1.8 14.9 1.9 10.3 1.3 9.4 1.2 8.8 0.9 8.3 ns tPHL HIGH to LOW propagation delay A to B 2.0 17.4 1.8 14.2 1.2 8.3 1.1 6.0 0.8 5.1 ns B to A 1.6 13.0 1.7 9.4 1.2 8.3 1.1 7.7 0.8 6.9 ns HIGH to OFF-state propagation delay DIR to A 1.8 9.0 1.8 9.0 1.8 9.0 1.8 9.0 1.8 9.0 ns DIR to B 2.7 24.8 2.7 23.6 2.2 12.1 2.5 10.3 2.0 7.6 ns LOW to OFF-state propagation delay DIR to A 1.5 6.4 1.5 6.4 1.5 6.4 1.5 6.4 1.5 6.4 ns DIR to B 2.0 16.1 2.2 14.6 1.8 9.9 2.2 9.3 1.6 6.4 ns OFF-state to HIGH propagation delay DIR to A [1] - 31.0 - 24.9 - 19.3 - 18.1 - 14.7 ns DIR to B [1] - 26.1 - 24.0 - 15.8 - 13.3 - 11.7 ns OFF-state to LOW propagation delay DIR to A [1] - 37.8 - 33.0 - 20.4 - 18.0 - 14.5 ns DIR to B [1] - 26.4 - 23.2 - 17.3 - 15.0 - 14.1 ns tPHZ tPLZ tPZH tPZL VCC(A) = 3.0 V to 3.6 V LOW to HIGH propagation delay A to B 2.0 18.9 1.8 17.1 1.2 8.8 0.7 6.2 0.6 4.9 ns B to A 1.5 13.0 1.5 8.0 1.1 6.9 0.6 6.2 0.5 6.0 ns tPHL HIGH to LOW propagation delay A to B 1.9 17.2 1.8 13.9 1.1 7.7 0.7 5.5 0.6 4.4 ns B to A 1.5 12.0 1.6 7.9 1.1 6.0 0.7 5.5 0.6 5.0 ns tPHZ HIGH to OFF-state propagation delay DIR to A 2.0 8.1 2.0 8.1 2.0 8.1 2.0 8.1 2.4 8.1 ns DIR to B 2.6 19.8 2.6 18.2 2.0 11.2 2.4 9.5 1.9 7.0 ns LOW to OFF-state propagation delay DIR to A 1.8 6.2 1.8 6.2 1.8 6.2 1.8 6.2 1.8 6.2 ns DIR to B 2.0 15.0 2.1 13.8 1.7 8.6 2.0 7.9 1.5 5.4 ns OFF-state to HIGH propagation delay DIR to A [1] - 28.0 - 21.8 - 15.5 - 14.1 - 11.4 ns DIR to B [1] - 25.1 - 23.3 - 15.0 - 12.4 - 11.1 ns OFF-state to LOW propagation delay DIR to A [1] - 31.8 - 26.1 - 17.2 - 15.0 - 12.0 ns DIR to B [1] - 25.3 - 22.0 - 15.8 - 13.6 - 12.5 ns tPLH tPLZ tPZH tPZL 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 13 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state Symbol Parameter Conditions VCC(B) Unit 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 4.5 V to 5.5 V LOW to HIGH propagation delay A to B 1.9 18.3 1.7 16.7 0.9 8.3 0.6 6.0 0.4 4.3 ns B to A 1.4 11.6 1.2 7.5 0.9 5.3 0.6 4.9 0.4 4.3 ns HIGH to LOW propagation delay A to B 2.0 16.9 1.6 13.5 0.9 6.9 0.6 5.0 0.4 3.9 ns B to A 1.5 11.9 1.5 7.7 0.8 5.1 0.6 4.4 0.4 3.9 ns HIGH to OFF-state propagation delay DIR to A 1.5 6.0 1.5 6.0 1.5 6.0 1.5 6.0 1.5 6.0 ns DIR to B 2.6 19.1 2.6 17.8 2.0 10.7 2.4 8.8 2.2 6.3 ns LOW to OFF-state propagation delay DIR to A 1.2 4.1 1.2 4.1 1.1 4.1 0.9 4.1 0.8 4.1 ns DIR to B 2.0 14.5 2.1 13.4 1.7 8.2 2.0 7.7 1.6 5.0 ns tPZH OFF-state to HIGH propagation delay DIR to A [1] - 26.1 - 20.9 - 13.5 - 12.6 - 9.3 ns DIR to B [1] - 22.4 - 20.8 - 12.4 - 10.1 - 8.4 ns tPZL OFF-state to LOW propagation delay DIR to A [1] - 31.0 - 25.5 - 15.8 - 13.2 - 10.2 ns DIR to B [1] - 22.9 - 19.5 - 12.9 - 11.0 - 9.9 tPLH tPHL tPHZ tPLZ [1] ns tPZH and tPZL are calculated values using the formula shown in Section 13.4. 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 14 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state 11.1. Waveforms and test circuit VI VM nA, nB input GND tPHL tPLH VOH nB, nA output VM 001aaj644 VOL Measurement points are given in Table 14. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 5. The data input (A, B) to output (B, A) propagation delay times VI DIR input VM GND t PLZ output LOW-to-OFF OFF-to-LOW t PZL VCCO VM VX VOL t PHZ output HIGH-to-OFF OFF-to-HIGH VOH t PZH VY VM GND outputs enabled outputs disabled outputs enabled 001aae968 Measurement points are given in Table 14. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 6. Enable and disable times Table 14. Measurement points Supply voltage Input [1] Output [2] VCC(A), VCC(B) VM VM VX VY 1.2 V to 1.6 V 0.5VCCI 0.5VCCO VOL + 0.1 V VOH - 0.1 V 1.65 V to 2.7 V 0.5VCCI 0.5VCCO VOL + 0.15 V VOH - 0.15 V 3.0 V to 5.5 V 0.5VCCI 0.5VCCO VOL + 0.3 V VOH - 0.3 V [1] [2] VCCI is the supply voltage associated with the data input port. VCCO is the supply voltage associated with the output port. 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 15 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 15. RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance. VEXT = External voltage for measuring switching times. Fig. 7. Test circuit for measuring switching times Table 15. Test data Supply voltage Input VCC(A), VCC(B) VI [1] Δt/ΔV [2] CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ [3] 1.2 V to 5.5 V VCCI ≤ 1.0 ns/V 15 pF 2 kΩ open GND 2VCCO [1] [2] [3] Load VEXT VCCI is the supply voltage associated with the data input port. dV/dt ≥ 1.0 V/ns. VCCO is the supply voltage associated with the output port. 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 16 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state 12. Typical propagation delay characteristics 001aai907 14 tPHL (ns) 12 (1) 10 001aai908 14 tPLH (ns) 12 (1) 10 (2) 8 (2) 8 (3) 6 (3) (4) (5) (6) 6 (4) (5) (6) 4 4 2 2 0 0 5 10 15 20 25 30 35 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai909 14 tPHL (ns) 12 (1) 0 10 8 (4) (5) (6) 8 6 6 4 4 2 2 5 10 15 20 25 30 35 CL (pF) c. HIGH to LOW propagation delay (B to A) 10 15 20 25 30 35 CL (pF) 001aai910 14 tPLH (ns) 12 (2) (3) 0 5 b. LOW to HIGH propagation delay (A to B) 10 0 0 0 (1) (2) (3) (4) (5) (6) 0 5 10 15 20 25 30 35 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 8. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 1.2 V 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 17 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state 001aai911 14 tPHL (ns) 12 001aai912 14 tPLH (ns) 12 (1) 10 10 (1) 8 8 (2) (2) 6 (4) 4 (3) 6 (3) (4) (5) (6) 4 (5) 2 0 2 (6) 0 5 10 15 20 25 30 35 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai913 14 tPHL (ns) 12 10 0 0 5 10 15 20 25 30 35 CL (pF) b. LOW to HIGH propagation delay (A to B) 001aai914 14 tPLH (ns) 12 10 (1) 8 (1) 8 6 (2) (3) (4) 6 (2) (3) (4) (5) (5) (6) 4 2 0 (6) 4 2 0 5 10 15 20 25 30 35 CL (pF) c. HIGH to LOW propagation delay (B to A) 0 0 5 10 15 20 25 30 35 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 9. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 1.5 V 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 18 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state 001aai915 14 tPHL (ns) 12 10 (1) 10 (1) 8 8 (2) 6 (3) (4) 4 (5) (6) 2 0 001aai916 14 tPLH (ns) 12 0 5 10 15 20 25 6 (3) 4 (4) (5) (6) 2 30 35 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai917 14 tPHL (ns) 12 (2) 10 0 0 5 10 15 20 25 b. LOW to HIGH propagation delay (A to B) 001aai918 14 tPLH (ns) 12 10 8 8 (1) (1) 6 (2) (3) (4) (5) (6) 6 (2) (3) (4) (5) (6) 4 4 2 0 30 35 CL (pF) 2 0 5 10 15 20 25 30 35 CL (pF) c. HIGH to LOW propagation delay (B to A) 0 0 5 10 15 20 25 30 35 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 10. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 1.8 V 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 19 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state 001aai919 14 tPHL (ns) 12 10 001aai920 14 tPLH (ns) 12 (1) 10 (1) 8 8 (2) (2) 6 6 (3) (3) 4 2 0 0 5 10 15 20 25 2 30 35 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai921 14 tPHL (ns) 12 0 8 8 0 (2) (3) (4) (5) (6) 0 5 10 15 20 25 10 15 20 25 (1) (2) (3) (4) (5) (6) 4 2 30 35 CL (pF) c. HIGH to LOW propagation delay (B to A) 30 35 CL (pF) 001aai922 6 (1) 2 5 14 tPLH (ns) 12 10 4 0 b. LOW to HIGH propagation delay (A to B) 10 6 (4) (5) (6) 4 (4) (5) (6) 0 0 5 10 15 20 25 30 35 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 11. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 2.5 V 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 20 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state 001aai923 14 tPHL (ns) 12 10 001aai924 14 tPLH (ns) 12 10 (1) (1) 8 8 (2) 6 (2) 6 (3) (3) 4 2 0 4 (4) (5) (6) 0 5 10 15 20 25 2 30 35 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai925 14 tPHL (ns) 12 0 8 8 (2) (3) (4) (5) (6) 4 2 0 0 5 10 15 20 25 30 35 CL (pF) c. HIGH to LOW propagation delay (B to A) 5 10 15 20 25 30 35 CL (pF) 001aai926 14 tPLH (ns) 12 10 (1) 0 b. LOW to HIGH propagation delay (A to B) 10 6 (4) (5) (6) 6 (1) 4 (2) (3) 2 (4) (5) (6) 0 0 5 10 15 20 25 30 35 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 12. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 3.3 V 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 21 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state 001aai927 14 tPHL (ns) 12 10 001aai928 14 tPLH (ns) 12 10 (1) (1) 8 8 (2) 6 (2) 6 (3) (3) 4 2 0 4 (4) (5) (6) 0 5 10 15 20 25 2 30 35 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai929 14 tPHL (ns) 12 (4) (5) (6) 0 0 5 10 15 20 25 30 35 CL (pF) b. LOW to HIGH propagation delay (A to B) 001aai930 14 tPLH (ns) 12 10 10 8 8 6 (1) 6 4 (2) (3) 4 (2) (3) 2 (4) (5) (6) 2 (4) (5) (6) 0 0 5 10 15 20 25 30 35 CL (pF) c. HIGH to LOW propagation delay (B to A) 0 (1) 0 5 10 15 20 25 30 35 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 13. Typical propagation delay versus load capacitance; Tamb = 25 °C; VCC(A) = 5.0 V 74LVC_LVCH2T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 22 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state 13. Application information 13.1. Unidirectional logic level-shifting application The circuit given in Fig. 14 is an example of the 74LVC2T45; 74LVCH2T45 being used in a unidirectional logic level-shifting application. VCC1 VCC2 VCC(A) VCC1 1A 1 8 VCC(B) VCC2 1B 74LVC2T45 7 2A 2B 3 74LVCH2T45 6 GND VCC1 2 4 5 system-1 DIR VCC2 system-2 001aai931 Fig. 14. Unidirectional logic level-shifting application Table 16. Description of unidirectional logic level-shifting application Pin Name Function Description 74LVC_LVCH2T45 Product data sheet 1 VCC(A) VCC1 supply voltage of system-1 (1.2 V to 5.5 V) 2 1A OUT output level depends on VCC1 voltage 3 2A OUT output level depends on VCC1 voltage 4 GND GND device GND 5 DIR DIR the GND (LOW level) determines B port to A port direction 6 2B IN input threshold value depends on VCC2 voltage 7 1B IN input threshold value depends on VCC2 voltage 8 VCC(B) VCC2 supply voltage of system-2 (1.2 V to 5.5 V) All information provided in this document is subject to legal disclaimers. Rev. 11 — 16 September 2021 © Nexperia B.V. 2021. All rights reserved 23 / 33 74LVC2T45; 74LVCH2T45 Nexperia Dual supply translating transceiver; 3-state 13.2. Bidirectional logic level-shifting application Fig. 15 shows the 74LVC2T45; 74LVCH2T45 being used in a bidirectional logic level-shifting application. Since the device does not have an output enable pin, the system designer should take precautions to avoid bus contention between system-1 and system-2 when changing directions. VCC1 I/O-1 VCC1 VCC2 VCC(A) PULL-UP/DOWN 1A 2A GND 1 8 VCC(B) VCC2 PULL-UP/DOWN I/O-2 1B 2 74LVC2T45 7 2B 74LVCH2T45 3 6 4 5 DIR DIR CTRL DIR CTRL system-1 system-2 001aai932 Pull-up or pull-down only needed for 74LVC2T45. Fig. 15. Bidirectional logic level-shifting application Table 17 gives a sequence that will illustrate data transmission from system-1 to system-2 and then from system-2 to system-1. Table 17. Description of bidirectional logic level-shifting application H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. State DIR CTRL I/O-1 I/O-2 Description 1 H output input system-1 data to system-2 2 H Z Z system-2 is getting ready to send data to system-1. I/O-1 and I/O-2 are disabled. The bus-line state depends on bus hold 3 L Z Z DIR bit is set LOW. I/O-1 and I/O-2 still are disabled. The bus-line state depends on bus hold 4 L input output system-2 data to system-1 13.3. Power-up considerations The device is designed such that no special power-up sequence is required other than GND being applied first. Table 18. Typicaltotal supply current (ICC(A) + ICC(B)) VCC(A) VCC(B) 74LVC_LVCH2T45 Product data sheet Unit 0V 1.8 V 2.5 V 3.3 V 5.0 V 0V 0
74LVC2T45GD,125
物料型号:74LVC2T45, 74LVCH2T45
器件简介:74LVC2T45 和 74LVCH2T45 是双路双向电压转换收发器,具备三态输出,支持双向电平转换。
它们具备两个2位的输入输出端口(nA和nB)、方向控制输入(DIR)和双电源引脚(VCC(A) 和 VCC(B))。
引脚分配: - VCC(A):端口A和DIR的供电电压 - 1A、2A:数据输入或输出 - GND:地(0V) - DIR:方向控制 - 1B、2B:数据输入或输出 - VCC(B):端口B的供电电压
参数特性: - 宽电源电压范围:VCC(A) 和 VCC(B) 均为 1.2V 至 5.5V - 高抗扰度 - ESD保护:HBM、MM、CDM - 最大数据速率:420 Mbps(3.3V 至 5.0V 转换)、210 Mbps(转换至 3.3V)、140 Mbps(转换至 2.5V)、75 Mbps(转换至 1.8V)、60 Mbps(转换至 1.5V)
功能详解: - 设备在DIR为高电平时,允许从nA到nB的传输;DIR为低电平时,允许从nB到nA的传输。
- 在部分断电应用中使用IOFF功能,可以在断电时禁用输出,防止通过设备产生危险的反向电流。
- 在挂起模式下,当任一VCC(A)或VCC(B)处于GND电平时,A端口和B端口都处于高阻态。
- 74LVCH2T45具有活跃的总线保持电路,可以在未使用或浮动的数据输入上保持有效的逻辑电平。
应用信息: - 适用于需要双向电平转换的应用,如不同电压级别的系统间通信。
封装信息: - VSSOP8(塑料超薄小型封装;8引脚;宽度2.3mm) - XSON8(塑料极薄小型封装;无引脚;8个终端;尺寸1x1.95x0.5 mm) - SOT765-1、SOT833-1、SOT1089、SOT1116 和 SOT1203 为具体的封装型号。
74LVC2T45GD,125 价格&库存
很抱歉,暂时无法提供与“74LVC2T45GD,125”相匹配的价格&库存,您可以联系我们找货
