CP421
CP421
    CHEMTRONICS
    WIPES PRE-SAT LENS OPTICS 25PCS
CP421 数据手册
Rev. C (6/18) Page 1 of 2 Electro-Washâ MX Cleaner Degreaser Presaturated Wipe Product# CP421 Product Description Electro-Wash MX Cleaner Degreaser is a high flash point cleaner that quickly removes soils, adhesives, and residues from insulation jackets and conductors on telecom, fiber optic and coaxial cables. Engineered with very low surface tension, this formulation penetrates and removes soils quickly with excellent wetting action, lifting and removing soils from the dirtiest areas. Electro-Wash MX Cleaner Degreaser is also ideal for removing carbonization, oxidized oils and greases from metal surfaces. § § § § § § § Removes encrusted dirt, grease, silicone and other contaminants Removes flooding compound and “ickypic” Moderate evaporation Leaves no residues Low odor Contains no CFCs or HCFCs Contains no chlorinated solvents Typical Applications Typical Product Data and Physical Properties Electro-Wash MX Cleaner Degreaser is engineered to clean: Boiling Point Solubility in Water: Specific Gravity: Evaporation Rate: (butyl acetate=1) Appearance: Odor: Flash Point (TCC): Kauri-Butanol (KB) number 239° F (115ºC) initial Negligible 0.72 >1 Shelflife 5 years RoHS Compliant Yes § § § § § § § § Fiber Optics & Connectors Cables Hard-line Coax Cable Metal & Fiber Optic Cable Splices PC Boards Motors & Transformers Control Systems Screens & Stencils Clear, colorless liquid Hydrocarbon 45° F (7.2ºC) 29 1-770-424-4888 Ÿ www.chemtronics.com Rev. C (6/18) Page 2 of 2 â Electro-Wash MX Cleaner Degreaser Presaturated Wipe Product# CP421 Compatibility Electro-Wash MX Cleaner Degreaser is generally compatible with most materials. As with any cleaning agent, solvent/component compatibility must be determined on a non-critical area prior to use. Material Compatibility ABS Buna-N EPDM Graphite HDPE Kynar™ LDPE Lexan™ Neoprene Noryl® Nylon 66™ Cross-Linked PE Polypropylene Polystyrene PVC Silicone Rubber Teflon™ Viton™ Excellent Excellent Excellent Excellent Excellent Excellent Excellent Excellent Excellent Excellent Excellent Excellent Excellent Excellent Excellent Excellent Excellent Excellent Usage Instructions For industrial use only. Read SDS carefully prior to use. Remove wipe from packets and lightly wipe away any dust or contaminants from surfaces. Allow surface to dry completely before use. Availability CP421 25 Premoistened Wipes Environmental Impact Data CFC HCFC-141b HCFC-225 VOC HFC nPB 0.0% 0.0% 0.0% 100% 0.0% 0.0 CFC, HCFC-225, HCFC-141b, VOC, HFC, and nPB percentages shown are the content by weight. Technical and Application Assistance Chemtronics provides a technical hotline to answer your technical and application related questions. The toll free number is: 1-800-TECH-401. Note: This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. CHEMTRONICS does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. 8125 Cobb Center Drive, Kennesaw, GA 30152 Ÿ 1-770-424-4888 Ÿ www.chemtronics.com 1-770-424-4888 Ÿ www.chemtronics.com
CP421 价格&库存
很抱歉,暂时无法提供与“CP421”相匹配的价格&库存,您可以联系我们找货
CP421
    库存:11
