C910
C910
    CHEMTRONICS
    WIPES DRY CRITICAL TASKS 6 BAGS
C910 数据手册
Rev. A (7/18) Page 1 of 1 ControlWipes™ Product# C910 Product Description ControlWipes consist of cellulose and polyester nonwoven fabric. These wipers have excellent absorbency, and contamination entrapment, as well as high strength. ControlWipes are ideal as an economical utility wipe for any clean area. • • • • • • • Economical Durable Excellent particle entrapment High absorbency capacity and rate Low ion contamination Solvent and dilute acid resistant Low linting compared to cotton Typical Applications Typical Product Data and Physical Properties ControlWipes can be used to: • • • • • • • Wipe Material: Clean water processing areas Clean-up acids and other chemical spills Wipe down of machinery, and instrumentation Clean photo-mask areas Clean laminar flow benches Clean quartzware General purpose wiping in cleanrooms Compatibility ControlWipes are compatible with most common solvents such as isopropyl alcohol, methanol. and ketones such as acetone or methyl ethyl ketone. These wipes are generally compatible with dilute or weak acids. Availability C910 9” x 9” (22.9cm x 22.9cm) 150 wipes/bag Technical and Application Assistance Chemtronics provides a technical hotline to answer your technical and application related questions. The toll free number is: 1-800-TECH-401. Particle Count: 0.5 micron or larger (Biaxial Shake Test) Chloride: Sodium: Potassium: Phosphate: Absorbency: Capacity: 45% Polyester / 55% cellulose nonwoven fabric 30 million/m2 20 ppm 55 ppm 5 ppm None detected 275 ml/m2 300 % The tests were done using the recommended practices of the Institute of Environmental Science, Swabs and Wipes Working Group. Note: This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. CHEMTRONICS does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. Chemtronics is registered trademark of Chemtronics. All rights reserved. ControlWipes is a trademark of Chemtronics. All rights reserved 8125 Cobb Center Drive, Kennesaw, GA 30152  1-770-424-4888  www.chemtronics.com
很抱歉,暂时无法提供与“C910”相匹配的价格&库存,您可以联系我们找货
C910
    库存:23
