Desiccant is a drying agent used to lower the moisture content of air
inside a closed space, such as a Moisture Barrier Bag. Desiccant is
packaged in fractional units in order to facilitate its usage with a variety of
bag sizes. One full “unit” of packaged desiccant will absorb the following
quantities of water at equilibrium with air at 77°F (25°C): 3.00 grams @
20% rH and 6.00 grams @ 40% rH, when tested to MIL-D-3464.
In order to provide a complete moisture barrier packaging assembly,
desiccant must be inserted into the bag, prior to having the bag vacuum
sealed. The recommended amount of desiccant is dependent on the
interior surface area of the bag to be used. Figure 4 is a reference table
indicating recommended minimum amounts of desiccant that should be
used with Moisture Barrier Bags.
INTERIOR BAG NUMBER OF DESICCANT UNITS
SURFACE AREA*
**MIH
很抱歉,暂时无法提供与“48880”相匹配的价格&库存,您可以联系我们找货
