6209HC
6209HC
    CHEMTRONICS
    WIPES DRY CRITICAL TASKS 12 BAGS
6209HC 数据手册
TECHNICAL Data Sheet Rev. C (11/18) Page 1 of 2 Poly-Wipes Product# 6209, 6209HC, 62096HC, 6259, 6259HC Product Description Poly-Wipes are constructed from monofilament polyester no-run knit, providing excellent strength, good absorbency and chemical compatibility. These wipers are a perfect choice for general cleanroom and equipment maintenance, or any critical applications were lint can be detrimental. For even lower particle counts specify 6209HC or 6259HC with sealed edges. • • • • • • • • Excellent solvent and acid resistance Monofilament "no-run" construction does not generate loose fibers Excellent durability for cleaning rough, abrasive, or irregular surfaces Low ionic, nonvolatile residue and particle contamination Good absorbency Available in heavy or light weight styles Available stacked or bulk packed Processed and packaged in a Class 10 cleanroom Typical Applications Poly-Wipes can be used to clean: • Semiconductor Wafer Fabs • Aerospace Production Areas • Disk Drives Production Areas • Pharmaceutical / Biotechnical Production Areas • General Cleanroom Cleaning • Clean and polish critical surfaces both metal and • non-metal Compatibility Poly-Wipes are compatible with most common solvents such as isopropyl alcohol, methanol and ketones such as acetone or methyl ethyl ketone. These wipes are generally compatible with dilute or weak bases, as well as with most dilute or weak acids. Availability 6200 Series Poly-Wipes (Standard Weight) 62096HC 6" x 9" (15.2cm x 22.9cm) Sealed Edge Polyester 2 wipe,125g/m , 150/Bag 6209 9" x 9" (22.9cm x 22.9cm) Polyester wipe, 2 125g/m , 150/Bag 6209HC 9" x 9" (22.9cm x 22.9cm) Sealed Edge Polyester 2 wipe,125g/m , 150/Bag 6250 Series Poly-Wipes (Heavy Weight) 6259 9" x 9" (22.9cm x 22.9cm) Polyester wipe, 2 143g/m , 150/Bag 6259HC 9" x 9" (22.9cm x 22.9cm) Sealed Edge Polyester 2 wipe,140g/m , 150/Bag 770-424-4888 • www.chemtronics.com TECHNICAL Data Sheet Rev. C (11/18) Page 2 of 2 Poly-Wipes Product# 6209, 6209HC, 62096HC, 6259, 6259HC Poly-Wipes Test Data Wipe Material Polyester Knit Fabric (70 denier) Wipe 6200 Series 6250B Series Availability Basis Weight 9”x9” (6209) 2 125 g/m 2 (+/- 5 g/m ) 6”x6”(6256B) 2 143 g/m 2 (+/- 5 g/m ) Particle Counts (LPC) >/= 0.5 microns 11 million/m 2 17 million/m 2 6250 Series 4" x 4" (6254) 9" x 9" (6259) 2 143 g/m 2 (+/- 5 g/m ) 12 million/m 2 6250LE Series 9" x 9"(6259LE) 2 140 g/m 2 (+/- 5 g/m ) 9.2 million/m 2 NVR in DI water None Detected None Detected 0.053 g/g None Detected NVR in IPA None Detected None Detected 0.22 g/g None Detected FTIR : silicone, amide, phthalates Chloride Ions Flouride Ions Nitrite Ions Nitrate Ions Phosphate Ions Sulphate Ions Sodium Ions Calcium Ions Zinc Ions Ammonium Absorbency None Detected None Detected None Detected None Detected None Detected 0.001 g/g None Detected 0.004 g/g 0.007 g/g None Detected None Detected None Detected None Detected 0.001 g/g 0.001 g/g 0.0015 g/g None Detected None Detected 2 412 ml/m None Detected None Detected None Detected None Detected None Detected 0.001 0.001 0.0012 None Detected None Detected 2 410 ml/m 365 ml/m 2 0.021 g/g 2 412 ml/m The wipe tests were done using the recommended practices of the Institute of Environmental Science, Swabs and Wipes Working Group. Technical and Application Assistance Chemtronics provides a technical hotline to answer your technical and application related questions. The toll free number is: 1-800-TECH-401 Note: This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. CHEMTRONICS does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. Chemtronics is a registered trademark of Chemtronics. All rights reserved. Coventry is a trademark of Chemtronics. All rights reserved. 8125 Cobb Center Drive • Kennesaw, GA 30152 1-770-424-4888 • www.chemtronics.com
6209HC 价格&库存
很抱歉,暂时无法提供与“6209HC”相匹配的价格&库存,您可以联系我们找货
6209HC
  • 1+992.646051+128.13100
  • 12+909.0296012+117.33777
  • 36+880.5060836+113.65594
  • 60+868.6095060+112.12033
  • 108+855.87486108+110.47654
库存:26
