2500
2500
    ACLSTATICIDE
    STATIC DISS PERM COATING CLEAR
2500 数据手册
NEW WATER-BASED FORMULA STOP STATIC ELECTRICITY PERMANENTLY, WITH NEW AND IMPROVED STATICIDE® ESD CLEAR AEROSOL COATING!* • Environmentally Friendly • No Organic Solvent Hazards • Non-Ozone Producing • Low V.O.C. (40% max.) • Non-Ozone Depleting Staticide® ESD permanent aerosol spray coating can be applied to plastics, painted metals, laminates, glass, paper and other materials. Independent laboratory tests show that Staticide® ESD meets the EOS/ESD association’s standard test S11.11 for permanent electrostatic protection. Staticide® ESD works as a static electricity problem solver and may be applied to keyboards, computers, mice, oscilloscopes, multi-meters, shelving, workstations, mini-environments and wherever dangerous static electricity invades and threatens your electronic equipment. Simply spray Staticide® ESD on any surface to get instant permanent static protection (108 ohms @ 10 volts) even down to zero humidity. Staticide® ESD meets Federal Standard 209E for zero particulation in cleanrooms. Staticide® ESD meets California air quality standards and is exempt from V.O.C. reporting as an ESD aerosol product. *Note: Clean means semi-transparent; not window-glass clarity. Staticide®. The number one name in static control. ACL Staticide® 1960 E. Devon Ave., Elk Grove Village, IL 60007 USA ISO 9001:2000 Registered KRC 2/05 STATICIDE® ESD #2500 PERMANENT CLEAR AEROSOL COATING* Staticide® ESD permanent clear coating is the first permanent electrostatic dissipative clear coating* available to stop dangerous static electricity. Staticide® ESD is not a temporary anti-stat like other spray or wipe on products. Staticide® ESD uses a unique semi-conductor technology to provide permanent static dissipation even under zero humidity conditions. Combined with ultra tough acrylic polymers in a water-based formula, Staticide® ESD is an easy to use aerosol spray which dries to the touch in minutes. Staticide® ESD meets the EOS/ESD association’s S11.11 test standards for electrostatic dissipation. Staticide® ESD meets California air quality standards and is exempt from V.O.C reporting as an ESD aerosol product. Staticide® ESD meets Federal Standard 209E for zero particulation in cleanrooms. However, product should not be sprayed inside cleanrooms. Staticide® ESD does not contain hazardous solvents. Staticide® ESD does not contain ozone producing or ozone depleting chemicals. Staticide® ESD is bio-degradable in liquid form. 1. 2. 3. 4. 5. 6. 7. 8. 9. APPLICATION INSTRUCTIONS Shake can well for 1 minute after agitator ball rattle is heard. Insure that the object surface to be coated is clean of dust, grease, oil and other contamination by cleaning with lint-free cloth containing isopropyl alcohol. Use Staticide® ESD in a well-ventilated area. For best results apply between 60° F to 100° F. Hold can 10” to 12” from surface. Spray objects with can in an upright position. Press spray head firmly and apply with steady light even strokes while spraying. Spray apply a continuous heavy wet film. Allow to dry 24 hours at room temperature (72° F). Clean up overspray with soap and water. Invert can and spray to clean nozzle. For best results use a clean rag and water to wipe off nozzle tip build-up. Once dry, the coated product may be washed with water or Staticide 6001 Mat and Table Top Cleaner. PACKAGING: 12 – 12 oz. cans per case *Note: clean means semi-transparent; not window-glass clarity. CAUTION Keep out of reach of children Contents flammable Spray can contents under pressure Dispose of empty can properly Do not incinerate Do not breathe vapors ACL Staticide® 1-800-782-8420 • 847-981-9212 • FAX 847-981-9278 1960 E. Devon Ave., Elk Grove Village, IL 60007 USA • www.aclstaticide.com Staticide®. The number one name in static control. KRC 2/05
很抱歉,暂时无法提供与“2500”相匹配的价格&库存,您可以联系我们找货
