10601
10601
    DESCO
    WIPES ANTISTATC CAN OF 60, 12 CT
10601 数据手册
DESCO INDUSTRIES INC. Technical Bulletin TB-7020 Application Instructions Reztore™ Static-Wipes Made in America Directions Lift the container cover from the canister and remove the seal from the lip of the container. Locate the first wipe in the center of the roll of wipes. Feed and push the first wipe through the hole in the center of the top cover and firmly re-attach the cover to the canister. Figure 2. When separating a tissue, tear at an angle. Figure 1. Reztore™ Static-Wipes: 60 Wipes in an Anti-Static Canister 160 Wipes in an Anti-Static Canister Description Reztore™ Static-Wipes are celluloserayon-polyester tissues saturated with an aqueous alcohol antistatic cleaning solution and packaged in a convenient anti-static reclosable pop-up container. They are used to clean surfaces and make surfaces static safe in most environments. General Guidelines The solution, which is non-flammable and non-toxic, can be applied to any surface such as computer screens, heel and toe grounders, rubber mats, vinyl mats, field service kits, laminated table tops, painted surfaces, acrylic, glass, shelving, conveyor belts, containers, optical surfaces, keyboards, telephones, and office copiers in order to remove and prevent the generation of static charges. This solution cleans and removes static charges from these surfaces. Reztore™ Static-Wipes clean and remove dust, grease, grime, fingerprints, and solder flux from surfaces used in a static sensitive area. Static-Wipes leave no insulative residue, are fast drying, non-streaking and contain no alkali or ammonia. The tissues trap particles without recontaminating the surface with loose fibers. These wipes clean without ozone depleting fluorocarbons. Because each tissue is individually dispensed in a handy, reclosable static dissipative container, it is ideal for both the office and assemblymanufacturing areas and can be stored on the work bench. This product eliminates sprayers, bottles, solvent cans and individually wrapped foil envelopes. To dispense a wipe, pull up the tissue at an angle in order to tear the tissue at the perforation. Unfold the tissue and wipe all surfaces that are to be cleaned and static protected. Wipe all surfaces liberally, using both sides of the tissue if needed. Wait approximately 30 seconds for the solution to dry. For heavily soiled areas apply medium pressure and rub vigorously until clean. When through be sure to close the pop-up closure in order to prevent the remaining tissues from drying. “Only cleaning materials or processes which do not degrade the properties of the ESD protective items shall be used.” (EN 61340-5-1 clause 5.5 EPA working practices) Reztore™ Static-Wipes are sold in individual canisters of 160 6” x 6” (15cm x 15cm) wipes or in cartons of 12 canisters of 60 4” x 6” (10cm x 15cm) wipes per canister. Figure 3. Application of the Reztore™ Static-Wipes when cleaning a computer monitor screen. DESCO INDUSTRIES INC. • 3651 Walnut Avenue, Chino, CA 91710 • (909) 627-8178 • Fax (909) 627-7449 • Web Site: DescoIndustries.com TB-7020 October 2009 Page 1 of 6 © 2009 DESCO INDUSTRIES INC. Employee Owned Specifications Appearance of solution: Transparent clear violet pH: 6-8 Odor: Slight floral alcohol Solubility: Water, acetone, alcohols Toxicity, Irritation, Sensitivity: Non-toxic by dermal contact or inhalation Flammability: Non-flammable Ion Level: (mg/l)    Fluoride 0.3 Sulfate
10601 价格&库存
很抱歉,暂时无法提供与“10601”相匹配的价格&库存,您可以联系我们找货
