44070
44070
    CHEMTRONICS
    SWAB CLEANRM 3.2" POLYTIP 500PC
44070 数据手册
TECHNICAL Data Sheet Rev. B (9/18) Page 1 of 3 Sealed Foam Swabs Product# 41050, 41050I, 43170, 44070, 48040, 49280 Product Description Coventry™ Sealed Foam Swabs are constructed from reticulated 100 pores per inch medical grade foam which features the best open cell structure, providing excellent particle entrapment characteristics. The foam is thermally bonded to the swab handle without using adhesives. These swabs are the most economical and are ideal for general applications. • • • • • • Traps surface particles while cleaning High solvent capacity; holds solvent well Fiberless construction does not generate loose fibers or particles No adhesives or binders are used in the construction Economical for high quantity applications Available Aqua-Prime™ processed Typical Applications Coventry™ Sealed Foam Swabs can be used to: • • • • • • • Clean excess adhesives after gluing Remove contamination from disk drives Micro mechanical cleaning Maintenance and care of fax machines VCR's, PC's, printers, and copiers Remove flux residue from printed circuit boards Good for general purpose cleaning Compatibility Foam Heads are compatible with most common solvents such as isopropyl alcohol, and methanol. Not recommended for use with ketones such as acetone or methyl ethyl ketone. Wood Handles are generally compatible with all solvents except with dilute or weak acids. Polypropylene Handles are generally compatible with all common solvents including most dilute or weak acids. Availability 41050 2.80 " (7.1 cm) Polypropylene Handle 0 .14" (3.56 mm) Foam Head, 500/ bag 41050I Cleaned using Aqua-Prime™ process 43170 6.0 " (15.24 cm) Wood, Foam Over Cotton 0.35" (8.8 mm) Head, 500/ bag 44070 3.2 " (8.0 cm) Polypropylene Handle 0.13" (3.3 mm) Foam Head , 500/ bag 48040 2.75 " (6.8 cm) Polypropylene Flexible Tip 0 .12" (3.0 mm) Foam Head, 500/ bag 49280 6.5 " (16.4 cm) Polypropylene Flexible Tip 0.19" (4.7 mm) Foam Head, 500/ bag 770-424-4888 • www.chemtronics.com TECHNICAL Data Sheet Rev. B (9/18) Page 2 of 3 Sealed Foam Swabs Product# 41050, 41050I, 43170, 44070, 48040, 49280 41050, 41050I 43170 44070 48040 770-424-4888 • www.chemtronics.com TECHNICAL Data Sheet Rev. B (9/18) Page 3 of 3 Sealed Foam Swabs Product# 41050, 41050I, 43170, 44070, 48040, 49280 49280 Sealed Foam Swabs Test Data Head Material Swabs: Sealed Foam 41050 41050I 44070 48040 0.5 - 1 um 571 484 1,867 797 1.0 - 2 um 96 63 336 230 2.0 – 5 um 37 18 71 66 5.0 – 10 um 31 13 31 24 10 – 25 um 19 8 15 11 Over 25 um 9 1 2 2 762 586 2,322 1,130 NVR (ug/swab) none detected none detected Chlorides (ug/swab) none detected none detected Particle Counts: TOTAL none detected 0.21 none detected The swabs were tested by Particle Measurement Technology. All the swabs tests were done using the recommended practices of the Institute of Environmental Science, Swabs and Wipes Working Group. Test data not available for 43170 and 49280. Technical and Application Assistance Chemtronics provides a technical hotline to answer your technical and application related questions. The toll free number is: 1-800-TECH-401 Note: This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. CHEMTRONICS does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. Chemtronics is a registered trademark of Chemtronics. All rights reserved. Coventry and Econowipes are trademarks of Chemtronics. All rights reserved. 8125 Cobb Center Drive • Kennesaw, GA 30152 1-770-424-4888 • www.chemtronics.com
44070 价格&库存
很抱歉,暂时无法提供与“44070”相匹配的价格&库存,您可以联系我们找货
  • 1+813.444821+105.36956
  • 1+588.837121+76.27500
  • 3+555.077123+71.90190
库存:28
