Rev. C (1/21) Page 1 of 3
Foamtips
Product# CF50, CF1050, CF2050, CF3050,
CF4050, CFP50
Product Description
The Chemtronics Foamtips Swabs are constructed from
medical grade foam which features the best open cell structure,
providing excellent particle entrapment characteristics. The
foam is thermally bonded to the swab handle without using
adhesives. These swabs are ideal for general cleaning
applications.
Traps surface particles while cleaning
High solvent capacity; holds solvent well
Fiberless construction does not generate loose fibers or
particles
No adhesives or binders are used in the construction
Economical for high quantity applications
Typical Applications
Chemtronics Foamtips Swabs can be used to:
Clean excess adhesives after gluing
Remove contamination from disk drives
Micro mechanical cleaning
Maintenance and care of fax machines VCR's PC's
printers, and copiers
Remove flux residue from printed circuit boards
Good for general purpose cleaning
Compatibility
Foam Heads are compatible with most common solvents such
as isopropyl alcohol, and methanol. Not recommended for use
with ketones such as acetone or methyl ethyl ketone.
Polypropylene Handles (CF1050, CF2050, CF3050, CF4050)
are generally compatible with all common solvents including
most dilute or weak acids.
Wood Handles (CF50) are compatible with all common
solvents and are static neutral.
Shelf Life
5 Years from date of manufacture.
CF50
1-770-424-4888 www.chemtronics.com
Rev. C (1/21) Page 2 of 3
Foamtips
CF4050, CFP50
CF1050
CF2050
CF3050
Rev. C (1/21) Page 3 of 3
Foamtips
CF4050, CFP50
CF4050
CFP50
Availability
CF50
CF1050
CF2050
CF3050
CF4050
CFP50
6-1/8 " swab with wood handle, foam over
cotton head
50 swabs / bag
5” round foamtip swab, polypropylene handle,
1” head
50 swabs / bag
5” rectangular foamtip swab, polypropylene handle,
1” x ½” head
50 swabs / bag
6” foamtip swab, polypropylene handle,
¾” x ¼” head
50 swabs / bag
2-7/8” foamtip swab, polypropylene handle,
½” x 3/16” head
50 swabs / bag
6-7/5”” foamtip swab, polypropylene handle,
Scrub head (blue) – 0.8” x 3/16”
Absorb head (white) – ¾” x ¼”
50 swabs / bag
Technical and Application Assistance
Chemtronics provides a technical hotline to answer your
technical and application related questions.
The toll free number is: 1-800-TECH-401.
Note:
This information is believed to be accurate. It is intended for
professional end users having the skills to evaluate and use the
data properly. CHEMTRONICS does not guarantee the
accuracy of the data and assumes no liability in connection
with damages incurred while using it.
8125 Cobb Center Drive, Kennesaw, GA 30152 1-770-424-4888 www.chemtronics.com
很抱歉,暂时无法提供与“CF4050”相匹配的价格&库存,您可以联系我们找货
