Rev. C (1/22) Page 1 of 2
Flextips, Super Flextips
Product# CX50, SX50, CXM50
Product Description
Chemtronics Flextips and Super Flextips Swabs are
constructed from medical grade, 100 ppi, polyurethane foam
which features fine cell structure, providing excellent particle
entrapment characteristics. The foam is thermally bonded to
the nylon paddle and the polypropylene swab handle without
using adhesives. The tough nylon paddle is very flexible and
virtually unbreakable. These swabs are ideal for general
cleaning applications.
Flextips (CX50, CXM50) — open cell foam for high
absorbency, soil capture and gentle cleaning.
Super Flextips (SX50) — closed cell foam for increased
toughness and abrasion resistance.
Traps surface particles while cleaning
High solvent capacity; holds solvent well
Fiberless construction does not generate loose fibers or
particles
No adhesives or binders are used in the construction
Economical for high quantity applications
Typical Applications
Chemtronics Flextips and Super Flextips Swabs can be used to:
Clean excess adhesives after gluing
Clean micro-mechanical devices
Maintain and service Fax machines, VCR's, PC's, printers
and copiers
Remove Flux residues from printed circuit boards
Apply small precise quantities of adhesive or lubricants
Compatibility
Foam Heads are compatible with most common solvents such
as isopropyl alcohol, and methanol. Not recommended for use
with ketones such as acetone or methyl ethyl ketone.
Nylon/Polypropylene Handles are generally compatible with
all common solvents including most dilute or weak acids.
Shelf Life
5 Years from date of manufacture.
CX50, SX50
1-770-424-4888 www.chemtronics.com
Rev. C (1/22) Page 2 of 2
Flextips,
s Super Flextips
CXM50
Availability
Technical and Application Assistance
Flextips
CX50
4 7/16 " swab with ¼” x ¼” open cell foam head
50 swabs / bag
Chemtronics provides a technical hotline to answer your
technical and application related questions.
The toll free number is: 1-800-TECH-401.
CXM50 4 1/8 " swab with 3/16” x 5/32” open cell foam head
50 swabs / bag
Super Flextips
SX50
4 7/16 " swab with ¼” x ¼” closed cell foam head
50 swabs / bag
Note:
This information is believed to be accurate. It is intended for
professional end users having the skills to evaluate and use the
data properly. CHEMTRONICS does not guarantee the
accuracy of the data and assumes no liability in connection
with damages incurred while using it.
8125 Cobb Center Drive, Kennesaw, GA 30152 1-770-424-4888 www.chemtronics.com
很抱歉,暂时无法提供与“CXM50”相匹配的价格&库存,您可以联系我们找货
