Rev. B (9/17) Page 1 of 2
Cottontips MicroPoint
Product# CCT2425
Product Description
Cottontips MicroPoint Swabs consist of cotton fibers which are
tightly wrapped around a handle. The handle of this swab is
made from a special, clean room grade composite material.
Because of the tightly wrapped head, there is very little linting.
These swabs have excellent absorbency, as well as high
strength especially when saturated with water. This swab is
designed for cleaning applications where absorbency is critical.
Tightly wrapped head construction
Small size for delicate precision cleaning
Extremely low linting
High absorbency capacity and rate
Good solvent compatibility
Sharp point
Non-static generating
Typical Applications
Compatibility
Cottontips MicroPoint Swabs can be used to:
Cottontips MicroPoint Swabs are compatible with all Chemtronics
cleaning solvents, and most common cleaning solvents such as
isopropyl alcohol, methanol, and ketones such as acetone.
Clean equipment and machinery, especially in small
crevices or openings
Remove flux residues from PCBs
Delicate parts and even some optics
Apply cleaning fluids
Absorb liquid chemical residues
Removes soils from holes, grooves and corners where
most swabs will not
0.12" (3.0mm)
Shelf Life
5 Years from date of manufacture.
0.06" (1.5mm) ø
0.47" (11.9mm)
0.12" (3.0mm)
0.47" (11.9mm)
3" (76mm)
CCT2425
1-770-424-4888 www.chemtronics.com
Rev. B (9/17) Page 2 of 2
Chamois Tips
s
Product# CC50
Availability
CCT2425
3 " (75 mm) Handle, double pointed head,
25 swabs / bag
Technical and Application Assistance
Chemtronics provides a technical hotline to answer your
technical and application related questions.
The toll free number is: 1-800-TECH-401.
Note:
This information is believed to be accurate. It is intended for
professional end users having the skills to evaluate and use the
data properly. CHEMTRONICS does not guarantee the
accuracy of the data and assumes no liability in connection
with damages incurred while using it.
8125 Cobb Center Drive, Kennesaw, GA 30152 1-770-424-4888 www.chemtronics.com
