CF50
CF50
    CHEMTRONICS
    SWABSGLHEADFOAMCOTTON50PC
CF50 数据手册
Rev. C (1/21) Page 1 of 3 Foamtips Product# CF50, CF1050, CF2050, CF3050, CF4050, CFP50 Product Description The Chemtronics Foamtips Swabs are constructed from medical grade foam which features the best open cell structure, providing excellent particle entrapment characteristics. The foam is thermally bonded to the swab handle without using adhesives. These swabs are ideal for general cleaning applications.  Traps surface particles while cleaning  High solvent capacity; holds solvent well  Fiberless construction does not generate loose fibers or particles  No adhesives or binders are used in the construction  Economical for high quantity applications Typical Applications Chemtronics Foamtips Swabs can be used to: Clean excess adhesives after gluing Remove contamination from disk drives Micro mechanical cleaning Maintenance and care of fax machines VCR's PC's printers, and copiers  Remove flux residue from printed circuit boards  Good for general purpose cleaning     Compatibility Foam Heads are compatible with most common solvents such as isopropyl alcohol, and methanol. Not recommended for use with ketones such as acetone or methyl ethyl ketone. Polypropylene Handles (CF1050, CF2050, CF3050, CF4050) are generally compatible with all common solvents including most dilute or weak acids. Wood Handles (CF50) are compatible with all common solvents and are static neutral. Shelf Life 5 Years from date of manufacture. CF50 1-770-424-4888  www.chemtronics.com Rev. C (1/21) Page 2 of 3 Foamtips Product# CF50, CF1050, CF2050, CF3050, CF4050, CFP50 CF1050 CF2050 CF3050 1-770-424-4888  www.chemtronics.com Rev. C (1/21) Page 3 of 3 Foamtips Product# CF50, CF1050, CF2050, CF3050, CF4050, CFP50 CF4050 CFP50 Availability CF50 CF1050 CF2050 CF3050 CF4050 CFP50 6-1/8 " swab with wood handle, foam over cotton head 50 swabs / bag 5” round foamtip swab, polypropylene handle, 1” head 50 swabs / bag 5” rectangular foamtip swab, polypropylene handle, 1” x ½” head 50 swabs / bag 6” foamtip swab, polypropylene handle, ¾” x ¼” head 50 swabs / bag 2-7/8” foamtip swab, polypropylene handle, ½” x 3/16” head 50 swabs / bag 6-7/5”” foamtip swab, polypropylene handle, Scrub head (blue) – 0.8” x 3/16” Absorb head (white) – ¾” x ¼” 50 swabs / bag Technical and Application Assistance Chemtronics provides a technical hotline to answer your technical and application related questions. The toll free number is: 1-800-TECH-401. Note: This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. CHEMTRONICS does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. 8125 Cobb Center Drive, Kennesaw, GA 30152  1-770-424-4888  www.chemtronics.com 1-770-424-4888  www.chemtronics.com
很抱歉,暂时无法提供与“CF50”相匹配的价格&库存,您可以联系我们找货
CF50
    • 2+409.982642+53.14156
    • 6+282.284586+36.58946
    • 12+260.1738212+33.72348
    • 18+259.5071418+33.63707
    库存:19
    CF50
    • 1+321.619641+41.68803
    CF50
      库存:19
