Rev. B (9/17) Page 1 of 1
MicroTip
Product# CM502
Product Description
Chemtronics Microtip is designed for precision applications
needing pinpoint accuracy. The tapered porous polyvinylidene
fluoride tip is effective as a stylus or pick for areas with tight
tolerances. The tip is attached to the handle without the use of
potentially contaminating adhesives or glues. This swab is ideal
for adhesive and lubricant application.
Polyvinylidene fluoride tip has low extractables and
particulate levels
Compatible with most solvents and adhesives
Tapered 1.925 mm tip can be used as a stylus
Assembled without adhesives or glues
Compatibility
Microtip Swab is compatible with most common solvents such
as alcohols, ketones, hydrocarbon and chlorinated solvents.
Shelf Life
5 Years from date of manufacture
Chemtronics provides a technical hotline to answer your
technical and application related questions.
The toll free number is: 1-800-TECH-401.
Note:
This information is believed to be accurate. It is intended for
professional end users having the skills to evaluate and use the
data properly. CHEMTRONICS does not guarantee the
accuracy of the data and assumes no liability in connection with
damages incurred while using it.
Availability
CM502
Technical and Application Assistance
6.7" swab with 0.07" x 0.62" head
50 swabs / bag
0.62" (15.7mm)
0.13" (3.3mm) ø
6.7" (170mm)
0.08" (1.93mm) ø
CM502
8125 Cobb Center Drive, Kennesaw, GA 30152 1-770-424-4888 www.chemtronics.com
很抱歉,暂时无法提供与“CM502”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+283.71458
- 5+277.75787
- 10+271.11384
