SXM50
SXM50
    CHEMTRONICS
    SWABSGLHEADFOAM4.13"50PC
SXM50 数据手册
Rev. C (1/22) Page 1 of 2 Flextips, Super Flextips Product# CX50, SX50, CXM50 Product Description Chemtronics Flextips and Super Flextips Swabs are constructed from medical grade, 100 ppi, polyurethane foam which features fine cell structure, providing excellent particle entrapment characteristics. The foam is thermally bonded to the nylon paddle and the polypropylene swab handle without using adhesives. The tough nylon paddle is very flexible and virtually unbreakable. These swabs are ideal for general cleaning applications. Flextips (CX50, CXM50) — open cell foam for high absorbency, soil capture and gentle cleaning. Super Flextips (SX50) — closed cell foam for increased toughness and abrasion resistance.  Traps surface particles while cleaning  High solvent capacity; holds solvent well  Fiberless construction does not generate loose fibers or particles  No adhesives or binders are used in the construction  Economical for high quantity applications Typical Applications Chemtronics Flextips and Super Flextips Swabs can be used to:  Clean excess adhesives after gluing  Clean micro-mechanical devices  Maintain and service Fax machines, VCR's, PC's, printers and copiers  Remove Flux residues from printed circuit boards  Apply small precise quantities of adhesive or lubricants Compatibility Foam Heads are compatible with most common solvents such as isopropyl alcohol, and methanol. Not recommended for use with ketones such as acetone or methyl ethyl ketone. Nylon/Polypropylene Handles are generally compatible with all common solvents including most dilute or weak acids. Shelf Life 5 Years from date of manufacture. CX50, SX50 1-770-424-4888  www.chemtronics.com Rev. C (1/22) Page 2 of 2 Flextips, s Super Flextips Product# CX50, SX50, CXM50 CXM50 Availability Technical and Application Assistance Flextips CX50 4 7/16 " swab with ¼” x ¼” open cell foam head 50 swabs / bag Chemtronics provides a technical hotline to answer your technical and application related questions. The toll free number is: 1-800-TECH-401. CXM50 4 1/8 " swab with 3/16” x 5/32” open cell foam head 50 swabs / bag Super Flextips SX50 4 7/16 " swab with ¼” x ¼” closed cell foam head 50 swabs / bag Note: This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. CHEMTRONICS does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. 8125 Cobb Center Drive, Kennesaw, GA 30152  1-770-424-4888  www.chemtronics.com 1-770-424-4888  www.chemtronics.com
SXM50 价格&库存
很抱歉,暂时无法提供与“SXM50”相匹配的价格&库存,您可以联系我们找货
