34860
34860
    CHEMTRONICS
    KIT PLATINUM FOR 2010E
34860 数据手册
TECHNICAL Data Sheet Rev. C (8/21) Page 1 of 3 Sealed Polyester Swabs Product# 34860, 38040, 38140, 38540, 36060, 36061I, 36850 Product Description Coventry™ Sealed Fabric Swabs are constructed from either a non-woven or a knit fabric. The head is thermoformed and welded to the handle in a single step using a proprietary process that yields an exceptionally clean swab that will not fall apart. The heads are made from either polyester knit, a polyester/nylon microfiber knit, or a polyester non-woven fabric. These swabs are acid and solvent resistant, including acetone. • • • • • • • • Excellent strength High absorbency and absorbency rate Excellent solvent compatibility Does not generate loose fibers or particles No adhesives or binders are used in the construction Good for tight tolerance work Micro-fiber has increased number of microspace to trap more particles, regardless of wet or dry Available Aqua-Prime™ processed Typical Applications Coventry™ Sealed Polyester Swabs can be used to: • • • • Validate biogenetic/pharmaceutical surfaces Clean disk drive components Clean sensitive surfaces in optics Clean aerospace hardware Availability 34860 3.2” (8.2 cm) polypropylene handle, 0.11” (2.7 mm) conical microfiber head, 500/bag 38040 2.7” (6.9 cm) polypropylene flexible tip paddle handle, 0.12" (3.0 mm) knit polyester fabric head, 500/ bag 38140 2.7" (6.9 cm) polypropylene flexible tip paddle handle, 0 .12" (3.0 mm) knit polyester fabric thin 0.07” (1.8 mm) head, 500/ bag 38540 2.7 " (6.9 cm) polypropylene flexible tip paddle handle, 0 .12" (3.0 mm) non-woven polyester fabric head, 500/ bag 36060 5.8" (14.7 cm) polypropylene handle, 0.21" (5.6 mm) knit polyester fabric head, 500/bag 36061I 36060 Aqua Prime™ processed, 25/bag 36850 5.8" (14.7 cm) glass filled nylon handle, 0.21" (5.3 mm) knit polyester/nylon microfiber fabric head (swab handle tip slightly tapered), 500/bag Compatibility Fabric Heads and Polypropylene Handles are compatible with most common solvents and dilute or weak acids, as well as ketones such as acetone or methyl ethyl ketone. Aqua Prime™ process available on all polyester swabs. 770-424-4888 • www.chemtronics.com TECHNICAL Data Sheet Rev. C (8/21) Page 2 of 3 Sealed Polyester Swabs Product# 34860, 38040, 38140, 38540, 36060, 36061I, 36850 34860 38040 38140 38540 36060, 36061I 770-424-4888 • www.chemtronics.com TECHNICAL Data Sheet Rev. C (8/21) Page 3 of 3 Sealed Polyester Swabs Product# 34860, 38040, 38140, 38540, 36060, 36061I, 36850 36850 Sealed Polyester Swabs Test Data Head Material Swabs: Polyester Knit Fabric 36060 36061I 38040 38140 0.5 - 1 um 685 504 685 685 1.0 - 2 um 189 81 189 189 2.0 – 5 um 58 31 58 58 5.0 – 10 um 30 8 30 30 10 – 25 um 19 9 19 19 Over 25 um 9 2 9 9 990 635 990 990 NVR (ug/swab) none detected none detected none detected none detected Chlorides (ug/swab) none detected 1 none detected none detected 4.2 4.1 4.2 4.2 Particle Counts: TOTAL TOC (ug/swab) The swabs were tested by Particle Measurement Technology. All the swabs tests were done using the recommended practices of the Institute of Environmental Science, Swabs and Wipes Working Group. Test data not available for 38540, 34860 and 36850. Technical and Application Assistance Chemtronics provides a technical hotline to answer your technical and application related questions. The toll free number is: 1-800-TECH-401 Note: This information is believed to be accurate. It is intended for professional end users having the skills to evaluate and use the data properly. CHEMTRONICS does not guarantee the accuracy of the data and assumes no liability in connection with damages incurred while using it. Chemtronics is a registered trademark of Chemtronics. All rights reserved. Coventry and Aqua Prime are trademarks of Chemtronics. All rights reserved. 8125 Cobb Center Drive • Kennesaw, GA 30152 1-770-424-4888 • www.chemtronics.com
34860
1. 物料型号:型号为EL817,是一款光耦器件。 2. 器件简介:EL817是一个高增益光晶体管输出的光耦器件,具有较高的电流传输比(CTR)和快速响应时间。 3. 引脚分配:EL817有6个引脚,分别为1(发光二极管正极),2(发光二极管负极),3(输出晶体管集电极),4(输出晶体管发射极),5(输出晶体管基极),6(发光二极管引脚)。 4. 参数特性:包括最大电流传输比(CTR)为100%,最大输入电流为50mA,输出晶体管的Vce(sat)为0.5V,最大工作温度为100°C等。 5. 功能详解:EL817通过发光二极管和光敏晶体管实现电信号隔离,适用于低频信号传输和电源控制。 6. 应用信息:EL817广泛应用于电源、测量设备、通信设备等领域。 7. 封装信息:EL817采用DIP-6封装形式。
34860 价格&库存
很抱歉,暂时无法提供与“34860”相匹配的价格&库存,您可以联系我们找货
