TECHNICAL Data Sheet
Rev. C (8/21)
Page 1 of 3
Sealed Polyester Swabs
Product# 34860, 38040, 38140, 38540,
36060, 36061I, 36850
Product Description
Coventry™ Sealed Fabric Swabs are constructed from either
a non-woven or a knit fabric. The head is thermoformed and
welded to the handle in a single step using a proprietary
process that yields an exceptionally clean swab that will not
fall apart. The heads are made from either polyester knit, a
polyester/nylon microfiber knit, or a polyester non-woven
fabric. These swabs are acid and solvent resistant, including
acetone.
Excellent strength
High absorbency and absorbency rate
Excellent solvent compatibility
Does not generate loose fibers or particles
No adhesives or binders are used in the construction
Good for tight tolerance work
Micro-fiber has increased number of microspace to trap
more particles, regardless of wet or dry
Available Aqua-Prime™ processed
Typical Applications
Coventry™ Sealed Polyester Swabs can be used to:
Validate biogenetic/pharmaceutical surfaces
Clean disk drive components
Clean sensitive surfaces in optics
Clean aerospace hardware
Availability
34860
3.2” (8.2 cm) polypropylene handle,
0.11” (2.7 mm) conical microfiber head, 500/bag
38040
2.7” (6.9 cm) polypropylene flexible tip paddle
handle, 0.12" (3.0 mm) knit polyester fabric head,
500/ bag
38140
2.7" (6.9 cm) polypropylene flexible tip paddle
handle, 0 .12" (3.0 mm) knit polyester fabric thin
0.07” (1.8 mm) head, 500/ bag
38540
2.7 " (6.9 cm) polypropylene flexible tip paddle
handle, 0 .12" (3.0 mm) non-woven polyester fabric
head, 500/ bag
36060
5.8" (14.7 cm) polypropylene handle,
0.21" (5.6 mm) knit polyester fabric head, 500/bag
36061I
36060 Aqua Prime™ processed, 25/bag
36850
5.8" (14.7 cm) glass filled nylon handle,
0.21" (5.3 mm) knit polyester/nylon microfiber fabric
head (swab handle tip slightly tapered), 500/bag
Compatibility
Fabric Heads and Polypropylene Handles are compatible
with most common solvents and dilute or weak acids, as well
as ketones such as acetone or methyl ethyl ketone. Aqua
Prime™ process available on all polyester swabs.
770-424-4888 • www.chemtronics.com
Rev. C (8/21)
Page 2 of 3
Product# 34860, 38040, 38140, 38540, 36060, 36061I, 36850
34860
38040
38140
38540
36060, 36061I
Rev. C (8/21)
Page 3 of 3
36850
Sealed Polyester Swabs Test Data
Head Material
Swabs:
Polyester Knit Fabric
36060
36061I
38040
38140
0.5 - 1 um
685
504
685
685
1.0 - 2 um
189
81
189
189
2.0 – 5 um
58
31
58
58
5.0 – 10 um
30
8
30
30
10 – 25 um
19
9
19
19
Over 25 um
9
2
9
9
990
635
990
990
NVR (ug/swab)
none detected
none detected
none detected
none detected
Chlorides (ug/swab)
none detected
1
none detected
none detected
4.2
4.1
4.2
4.2
Particle Counts:
TOTAL
TOC (ug/swab)
The swabs were tested by Particle Measurement Technology. All the swabs tests were done using the recommended practices
of the Institute of Environmental Science, Swabs and Wipes Working Group.
Test data not available for 38540, 34860 and 36850.
Technical and Application Assistance
Chemtronics provides a technical hotline to answer your
technical and application related questions. The toll free
number is: 1-800-TECH-401
Note:
This information is believed to be accurate. It is intended for
professional end users having the skills to evaluate and use
the data properly. CHEMTRONICS does not guarantee the
accuracy of the data and assumes no liability in connection
with damages incurred while using it.
Chemtronics is a registered trademark of Chemtronics. All rights
reserved. Coventry and Aqua Prime are trademarks of
Chemtronics. All rights reserved.
8125 Cobb Center Drive • Kennesaw, GA 30152
1-770-424-4888 • www.chemtronics.com
很抱歉,暂时无法提供与“36060”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1265.32286
- 5+1238.78840
- 10+1201.62142
