3M2A1-C-TNG
3M2A1-C-TNG
    SCS
    EM AWARE TNG ESD MON STARTER KIT
3M2A1-C-TNG 数据手册
Product Data Sheet Product Data Sheet 3M™ EM Aware TNG ESD Event Monitor The EM Aware TNG Event Monitor is designed to: • Provide a real time detection of most ESD events, change of static voltage and verification of critical environment ionizers (< + 5V offset) • Continuously monitor the environment for ESD • Provide a comprehensive diagnostic tool The EM Aware TNG ESD Event Monitor measures parameters through a single remote antenna, rejects most non-ESD events, and provides output of data. Properties Typical Value ESD Event Monitor Measurement Magnitude of HF Electromagnetic Field by ESD Event ESD Event Threshold Range 60 – 140 dBμV typical (default setting: 80dBμV) Raw Input Signal 60 dBμV - 134 dBμV typical Filtering Function ESD Static Voltage Monitor Measurement Change of static voltage Static Voltage Setting Range (+/-) 12.5V, 100V, 250V, 500V, 1000V Analog Output Vout = 1 V (4 mA for 250Ω) typical for high negative static voltage value range Vout = 5 V (20 mA for 250Ω) typical for high positive static voltage value range Verification of Ionizer* ( Model 3M034-031-TNG only) Compatible Ionizer Monitoring Balance Range Steady State DC Blower Ionizer ± 5V* *typical Connectivity Selection Guide Model 3M034-031-TNG 3M034-030-TNG Input SMA Connector for Remote antenna Outputs RJ45 connector, 4-20mA analog output or RS485 as digital output ESD Events Event Magnitude Event Counter Change on Static Voltage Ionizer Verification* General Alarm Buzzer √ √ √ √ √ Display LCD Power Universal 100 - 240VAC 0.5A, ~ 50 - 60Hz Output: 12VDC 1.5A Dimension (approx.) 3.17" W x 2.23" H x 1.50" D (antenna not included) (81 mm W x 57 mm H x 38 mm D) Weight (approx.) 146g √ √ √ √ *Only for ionizers having less than ± 5V offset *Only for ionizers having less than + 5V offset ** The readings of ionization voltage and decay under identical conditions may not always be correlated with CPM. 3M™ EM Aware TNG ESD Event Monitor is not a replacement for regular test of ionizer by CPM. Product Data Sheet Product Data Sheet 3M™ EM Aware TNG ESD Event Monitor 3M is a trademark of 3M Company. Important Notice All statements, technical information, and recommendations related to 3M’s products are based on information believed to be reliable, but the accuracy or completeness is not guaranteed. Before using this product, you must evaluate it and determine if it is suitable for your intended application. You assume all risks and liability associated with such use. Any statements related to the product which are not contained in 3M’s current publications, or any contrary statements contained on your purchase order shall have no force or effect unless expressly agreed upon, in writing, by an authorized officer of 3M. 3 Electronics Materials Solutions Division Static Control Products 926 JR Industrial Drive Sanford, NC 27332-9733 Toll-Free: 866-722-3736 International: 919-718-0000 Email: 3mstaticinfo@mmm.com www.3Mstatic.com Please recycle. Printed in USA. © 3M 2014. All rights reserved. 78-9102-1947-2 JHA Warranty; Limited Remedy; Limited Liability. This product will be free from defects in material and manufacture for one year from the time of purchase. 3M MAKES NO OTHER WARRANTIES INCLUDING, BUT NOT LIMITED TO, ANY IMPLIED WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. If this product is defective within the warranty period stated above, your exclusive remedy shall be, at 3M’s option, to replace or repair the 3M product or refund the purchase price of the 3M product. Except where prohibited by law, 3M will not be liable for any indirect, special, incidental or consequential loss or damage arising from this 3M product, regardless of the legal theory asserted. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: SCS: 3M3A1-C-TNG 3M2A3-C-TNG 3M2AM3-C-TNG 3M034-031-TNG 3M034-030-TNG 3M3A3-C-TNG 3M1A4-C-TNG 3M2AM2-C-TNG 3M2A2-C-TNG 3M2A4-C-TNG 3M2A6-C-TNG 3M2A1-C-TNG 3M3A5-C-TNG 3M3A4-C-TNG
3M2A1-C-TNG 价格&库存
很抱歉,暂时无法提供与“3M2A1-C-TNG”相匹配的价格&库存,您可以联系我们找货
