ACL475
ACL475
    ACLSTATICIDE
    METER DELUXE SURFACE RESISTIVITY
ACL475 数据手册
Model ACL 475 Specialists in Static Control ACL 475 PORTABLE SURFACE RESISTIVITY METER The ACL 475 Portable Surface Resistivity Meter is the latest in static control instrumentation available. Designed to provide fast, repeatable, comparative measurements of surface resistivity. The ACL 475 conveniently checks resistivity specifications for static control products such as anti-static bags, static dissipative mats and conductive work surfaces. Consistent reliable measurements over a wide range (up to 1014 ohms/square) can be easily made with this instrument, making it ideally suited for applications in a manufacturing environment. FEATURES: Auxiliary Weight Kit available. • • • • • Easy to use – no cable or probes to adjust Portable – rechargeable battery powered. Wide range of direct readings in Ohms per square. Designed to widely accepted ASTM-D257 standards. Includes cord for measuring resistance to ground. SPECIFICATIONS: Range: Automatic from 104 ohms per square to 1014 ohms per square. Accuracy: +/- 1/2 decade Internal Supply: 100 volts 1mA above 105 ohms per square 10 volts, 10mA for 104 and 105 ohms per square Display: LEDs one per decade Power: Rechargeable battery with 115 VAC adapter/charger supplied. Battery operation 4-8 hours steady use. Dimensions: 4" wide x 3 1/2" high x 5 3/4" long Designed to ASTM-D257 standards. ISO 9001: 2000 Registered 1960 East Devon Ave., Elk Grove Village, IL 60007 1-800-782-8420 · 847-981-9212 · FAX: 847-981-9278 www.aclstaticide.com
ACL475 价格&库存
很抱歉,暂时无法提供与“ACL475”相匹配的价格&库存,您可以联系我们找货
