35009
35009
    DESCO
    ESDBADGEHOLDERCLIP-ONVERT
35009 数据手册
  TECHNICAL BULLETIN TB-4017  ESD Bottle Hang Tags Made in the United States of America Figure 2. Item 35393 installed on a 6 oz bottle Figure 1. ESD Bottle Hang Tag, 35393 (left) & 35394 (right) Features • Pre-cut ESD safe hang tag adds additional labeling to MENDA bottles, with neck size 38-400. (35393 only) • 0.012” (0.3048 mm) thick, ±10% tolerance, ESD vinyl material front and back. • Dissipative Rtt: 1 x 106 to < 1 x 1010 ohms per ANSI/ESD S11.11 •  Tribocharging is less than 100 volts. • Includes 2-1/4" x 2-1/4" (Insert Size) front pouch to prevent the label from getting wet. • Front pocket includes inner anti-print, non-ESD vinyl layer, which will prevent ink transfer from the label to the tag. •  Can fit a folded 8-1/2" x 11" sheet of paper. • Includes ESD Protective Symbol imprint in bottom left corner of the front pocket. ITEM # DESCRIPTION 35393 ESD Bottle Hang Tag, Pre-Cut, 10 Pack 35394 ESD Bottle Hang Tag, 10 Pack Figure 2. Item 35394 installed on an 8 oz wash bottle 3651 Walnut Avenue, Chino, CA 91710 Phone: (909) 627-2453 • Web Site: MendaPump.com TB-4017 Page 1 of 2 November 2015 © 2015 DESCO INDUSTRIES, INC. Employee Owned Cutting Instructions for 35394 Bottle Hang Tag 1. Fold the uncut bottle hang tag in half lengthwise. 4. With sharp scissors or a utility knife, cut along the traced line mark from the previous step. 2. Fold down the unmarked top of the tag to the mid-seam line; it should be facing towards the ESD Symbol. 5. Remove the marked section completely, and unfold the hang tag. 3. 6. Check the fit of the hang tag by placing it over the bottle neck. Repeat steps and trim if needed. Place the folded corner on top of the bottle neck and using a pen or marker, trace where the edge of the bottle neck meets the vinyl tag. The tip of the folded corner should be centered in the middle of the bottle neck opening with the outside edge of the hang tag facing in the direction of the hand holding it. Limited Warranty, Warranty Exclusions, Limit of Liability and RMA Request Instructions See the Menda warranty http://menda.descoindustries.com/warranty.aspx 3651 Walnut Avenue, Chino, CA 91710 Phone: (909) 627-2453 • Web Site: MendaPump.com TB-4017 Page 2 of 2 © 2015 DESCO INDUSTRIES, INC. Employee Owned Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Menda: 35009
35009 价格&库存
很抱歉,暂时无法提供与“35009”相匹配的价格&库存,您可以联系我们找货
