35194
35194
    DESCO
    HOLDARMBADGEESDYLW23/8"X
35194 数据手册
OPENING Made in the United States of America Features: • ESD Arm Band Badge Holder is ideal for use by electronic manufacturers working with ESD sensitive components • Perfect for active personnel if standard badges fall off their clothing • Adjustable black elastic band flexes with arm movement for secure fit • Material Thickness: 0.036" (0.9 mm) ESD vinyl on the back and 0.012” (0.3 mm) clear firm copy guard ESD vinyl as front inner liner to ensure durability and high-end appearance ◦ Material Tolerance (thickness): ±10% • ESD symbol allows people to immediately know the Badge Holder has ESD control properties - low charging antistatic and dissipative • Made with a custom dissipative material made exclusively for Desco Industries Inc ◦ Rtt: 1 x 10 6 to < 1 x 1010 ohms per ANSI/ESD STM11.11 ◦ Tribocharging: Less than 100 volts • 4" x 4-5/16" (Outer Dimension), 2-3/8" x 3-3/8" (Insert Size) • Made in the United States of America “It should be understood that any object, item, material or person could be a source of static electricity in the work environment. Removal of unnecessary nonconductors, replacing nonconductive materials with dissipative or conductive materials and grounding all conductors are the principle methods of controlling static electricity in the workplace, regardless of the activity.” [ESD Handbook ESD TR20.20 section 2.4 Sources of Static Electricity] Item Description 35193 Clear Arm Band Badge Holder, Black Elastic Band ± 1/16" tolerances on dimensions unless specified. Specifications and procedures subject to change without notice. ARM BAND ESD BADGE HOLDER, 2-3/8" x 3-3/8" INSERT SIZE 3651 WALNUT AVENUE, CHINO, CA 91710 PHONE: (909) 627-2453 WEBSITE: MENDATools.com © 2021 DESCO INDUSTRIES INC Employee Owned DRAWING NUMBER 35193 DATE September 2021 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Menda: 35194
35194 价格&库存
很抱歉,暂时无法提供与“35194”相匹配的价格&库存,您可以联系我们找货
