10023
10023
    SCS
    Static Shielding Bag
10023 数据手册
BU-60 Series (Uninsulated Steel Alligator Clips) • • • • • • Mueller Electric’s BU-60 is the most common and versatile alligator clip. Compatible with BU-62 and BU-62S high-temperature PVC insulators. Overall length 1.96” (50.1mm), overall width 0.31” (7.9mm), maximum jaw spread = 0.31” (7.9mm) Can be attached to wire via solder or crimp connection. Ratings: Current 10 Amps The BU-60 is sold under the following models: BU-60 Nickel-plated steel clip, compatible with 4mm banana plugs BU-60HT Zinc-plated steel BU-60, rated to 1100°F (593°C) BU-60X Stainless-steel BU-60 (including hardware) BU-60BLACK Black BU-60 BU-60G Gold-plated steel BU-60 BU-60U BU-60 with U-shaped barrel BU-60TBO BU-60 with 8-32 threaded barrel BU-60PR2 BU-60 with phone tip/test prod tip connection BU-60S BU-60 with #6 screw for wire attachment BU-60-ZZZN Same as BU-60 with no screw hole, no wire strap RoHS 3 compliant Mueller Electric Company 2850 Gilchrist Rd. Bld 5A Akron, OH 44305 www.muellerelectric.com Toll Free: 800.955.2629 Phone: 330.780.2525 Fax: 330.780.2524
10023 价格&库存
很抱歉,暂时无法提供与“10023”相匹配的价格&库存,您可以联系我们找货
    • 100+0.83311
    库存:1900
    10023
    库存:1900
