82101
82101
    DESCO
    DISPOSABLE ESD MAT 14X22
82101 数据手册
Made in America Description Desco’s Disposable ESD Mat meets ANSI/ESD S20.20 worksurface required limit and recommendation of ANSI/ESD S4.1 for contact with ESD susceptible items. The material is intended to be a sacrificial material to protect a more expensive worksurfaces from damage caused by conformal coating, solder fluxes, or other contaminates. The material is made from a 100% recyclable dissipative impregnated worksurface material and has an internal conductive layer so that it does not generate a static charge and will control the discharge rate from all conductors (including ESD susceptible items) that are placed on the surface. The mat may be grounded by placing it onto an already grounded ESD worksurface. PROPERTIES Surface Resistance High-Voltage Discharge Resistance Static Shielding Corrosivity Antistat Transfer Sloughing Test Recyclability Biodegradability TYPICAL VALUES TEST PROCEDURES/METHOD 10E6 - 10E8 ohms ANSI/ESD S4.1 Failure rate 0/5 (no oxide damage in five consecutive tests) Rockwell International Test Report of December 20, 1991 99.9% attenuation at 10kV; 99.6% attenuation at 30kV EIA 541, appendix E, capacitive probe test Contains 1-3 ppm reducible sulfur FED-STD-101, Method 3005 for reducible sulfur No transfer Rockwell International Test Report of January 8, 1992 Negligible surface damage at 10 cycles and
82101 价格&库存
很抱歉,暂时无法提供与“82101”相匹配的价格&库存,您可以联系我们找货
