TM30600L3BL
TM30600L3BL
    SCS
    Conductive, Dissipative Floor Runner Grounding Mat Vinyl Blue 50' (15.24m) X 2.5' (0.76m)
TM30600L3BL 数据手册
Premium 3-Layer Vinyl Worksurface Mat This three-layer vinyl material provides excellent electrical properties. The top layer is made from a tough, easy-to-clean dissipative vinyl. The center layer, a highly conductive metal scrim, moves the charge from the surface to ground quickly. The bottom layer is a durable, non-skid, cushion of dissipative foam. Compatible with constant monitors. Available in rolls, mats, and mats with a ground cord. Meets ANSI/ESD S20.20 worksurface required limits and recommendation of ANSI/ESD S4.1. Made in the United States of America Properties Typical Value Thickness* 0.125" (3.2 mm) ± 10 % Color* Blue and Gray Hardness 75 ± 5 Shore A Resistances* Surface to Ground (Rtg) Surface to Surface (Rtt) 1 x 106 to < 1 x 109 ohms 1 x 106 to < 1 x 109 ohms Tolerance Mat Kit Rolls Test Method ANSI/ESD S4.1 & ESD TR53 ANSI/ESD S4.1 & ESD TR53 Width +/- 0.250" Length +/- 0.250" Width +/- 0.250" Length +12" / -1" Mat Kit Item Numbers Size Blue 24" x 36" (0.6 m x 0.9 m) TM2436L3BL-L 24" x 48" (0.6 m x 1.2 m) TM2448L3BL-L Table Mat Includes: 1 Table Mat, size as specified 1 LPCGC151M 15' (4.6 m) Low-Profile Common Ground Cord 2 Female 3/8" Snaps (installed) Mat Roll Item Numbers *Color, texture and thickness may vary between lots and mills. RoHS, REACH and Conflict Minerals, Statement See the Desco Industries RoHS, REACH, and Conflict Minerals Statement: DescoIndustries.com/ROHS3.aspx See the SCS Limited Warranty: StaticControl.DescoIndustries.com/Limited-Warranty.aspx Specifications and procedures subject to change without notice. Size Blue Gray 2' x 50' (0.6 m x 15.2 m) TM24600L3BL TM24600L3GR 2' x 100' (0.6 m x 30.4 m) TM241200L3BL 2.5 x 50' (0.8 m x 15.2 m) TM30600L3BL 2.5 x 100' (0.8 m x 30.4 m) TM301200L3BL 3' x 50' (0.9 m x 15.2 m) TM36600L3BL 3' x 100' (0.9 m x 30.4 m) TM361200L3BL TM30600L3GR TM36600L3GR Hardware not included Grounding: This material must be properly grounded for optimum electrical performance. See Grounding Cords. PREMIUM QUALITY 3-LAYER VINYL WORKSURFACE MAT 926 JR Industrial Drive, Sanford, NC 27332 WEB SITE: StaticControl.com PHONE: EAST: (919) 718-0000 | WEST: (909) 627-9634 © 2020 DESCO INDUSTRIES INC Employee Owned DRAWING NUMBER TM PREMIUM DATE October 2020
TM30600L3BL 价格&库存
很抱歉,暂时无法提供与“TM30600L3BL”相匹配的价格&库存,您可以联系我们找货
