Bubble Cells
Specifications:
0.6
Standard Document
ANSI/ESD S20.20
25
Electrical Properties
Rtt Resistance
Rtg Resistance
Typical Values
1 x 104 to < 1 x 106 ohms
Meets Requirements of:
Flooring
Test Procedures/Method
ANSI/ESD STM7.1.
ANSI/ESD STM7.1.
Physical Properties
Material:
Ethylene Propylene Diene Monomer (EPDM)¹
Thickness:
0.625" (15.5mm)
Color:² Black
Texture:²
Bubble Cells
Grounding & Cleaning
If the material is used on top of an already properly grounded surface,
grounding hardware may not be necessary. Where no properly grounded
surface is available, grounding hardware is required to provide a
path-to-ground. Rtg compliance verification measurements must be made as
outlined in ESD TR53 with a surface resistance meter.
See Tech Bulletin TB-7000 for Reztore® Surface & Mat Cleaner Application
Instructions.
Tolerances:
Width ± 0.250"
Length ± 0.250" every 1 linear foot of running material.
¹Rubber material is vulcanized and may contain sulfur.
²Color and Texture may vary between lots and mills
For Sizes and Item Numbers, Click Here
Limited Lifetime Warranty:
Desco warrants for one year that Statfree® matting products will be free of
defects in materials and workmanship and will guarantee dissipative/conductive
mat properties for the life of the mat. Damage to matting caused by misuse of
any kind, including using inappropriate cleaners is not covered by Desco Limited
Warranty.
RoHS 2, REACH, and Conflict Minerals Statement
See the Desco Industries RoHS 2, REACH, and Conflict Minerals Statement:
http://www.descoindustries.com/ROHS2.aspx
See the Desco Limited Warranty:
http://desco.descoindustries.com/Limited-Warranty.aspx
See the Desco Disclaimer:
http://desco.descoindustries.com/Disclaimer.aspx
Made in the
United States of America
STATFREE i™ INTERLOCKING FLOOR MAT, CONDUCTIVE, ERGONOMIC, 0.625” (15.5MM)
DESCO
PHONE
DESCO
PHONE
© 2020 DESCO INDUSTRIES INC.
Employee Owned
WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
(909) 627-8178 FAX (909) 627-7449
EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
(781) 821-8370 FAX (781) 575-0172
MATERIAL
STATFREE i™
DRAWING PM-107
DATE:
June
2020
很抱歉,暂时无法提供与“40930”相匹配的价格&库存,您可以联系我们找货
