40936
40936
    DESCO
    FLOORMATRUBBERBLACK5'X3'
40936 数据手册
Bubble Cells Specifications: 0.6 Standard Document ANSI/ESD S20.20 25 " Electrical Properties Rtt Resistance Rtg Resistance Typical Values 1 x 104 to < 1 x 106 ohms 1 x 104 to < 1 x 106 ohms Meets Requirements of: Flooring Test Procedures/Method ANSI/ESD STM7.1. ANSI/ESD STM7.1. Physical Properties Material: Ethylene Propylene Diene Monomer (EPDM)¹ Thickness: 0.625" (15.5mm) Color:² Black Texture:² Bubble Cells Grounding & Cleaning If the material is used on top of an already properly grounded surface, grounding hardware may not be necessary. Where no properly grounded surface is available, grounding hardware is required to provide a path-to-ground. Rtg compliance verification measurements must be made as outlined in ESD TR53 with a surface resistance meter. See Tech Bulletin TB-7000 for Reztore® Surface & Mat Cleaner Application Instructions. Tolerances: Width ± 0.250" Length ± 0.250" every 1 linear foot of running material. ¹Rubber material is vulcanized and may contain sulfur. ²Color and Texture may vary between lots and mills For Sizes and Item Numbers, Click Here Limited Lifetime Warranty: Desco warrants for one year that Statfree® matting products will be free of defects in materials and workman­ship and will guarantee dissipative/conductive mat properties for the life of the mat. Damage to matting caused by misuse of any kind, including using inappropriate cleaners is not covered by Desco Limited Warranty. RoHS 2, REACH, and Conflict Minerals Statement See the Desco Industries RoHS 2, REACH, and Conflict Minerals Statement: http://www.descoindustries.com/ROHS2.aspx See the Desco Limited Warranty: http://desco.descoindustries.com/Limited-Warranty.aspx See the Desco Disclaimer: http://desco.descoindustries.com/Disclaimer.aspx Made in the United States of America STATFREE i™ INTERLOCKING FLOOR MAT, CONDUCTIVE, ERGONOMIC, 0.625” (15.5MM) DESCO PHONE DESCO PHONE © 2020 DESCO INDUSTRIES INC. Employee Owned WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com (909) 627-8178 FAX (909) 627-7449 EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 (781) 821-8370 FAX (781) 575-0172 MATERIAL STATFREE i™ DRAWING PM-107 DATE: June 2020
40936 价格&库存
很抱歉,暂时无法提供与“40936”相匹配的价格&库存,您可以联系我们找货
