TM30600L1GR
TM30600L1GR
    SCS
    ROLL VINYL ESD 2.5'X50'
TM30600L1GR 数据手册
Product Data Sheet Product Data Sheet 3M™ Economy Vinyl Table Mat Part Numbers Economy Mats mats are constructed of homogeneous anti-static vinyl. Not compatible with workstation monitors. SIZE BLUE P/N GRAY P/N 24x36 inches TM2436L1BL TM2436L1GR 24x48 inches TM2448L1BL TM2448L1GR SIZE BLUE P/N GRAY P/N 24x36 inches TM2436L1BL-L TM2436L1GR-L 24x48 inches TM2448L1BL-L TM2448L1GR-L Mats Call for custom sizes. Mat Kits DISSIPATIVE VINYL Specifications Typical Value Resistance to Ground point (RTG)* 10 9-10 ohms Resistance Top to Top (RTT)* 10 9-10 ohms Thickness 0.096 inches Colors Blue and Gray *Tested per ESD Association Standard ANSI/ESD S4.1 *Color and appearance of mats may vary by lot. Call for custom sizes. Rolls Includes roll of matting material. SIZE BLUE P/N GRAY P/N 2x50 feet TM24600L1BL TM24600L1GR 3x50 feet TM36600L1BL TM36600L1GR 30”x50 feet TM30600L1BL TM30600L1GR 4x50 feet TM48600L1BL TM48600L1GR RTG is the resistance from one point on the mat’s surface to the mat’s ground point, and is the fundamental electrical test for a mat. A proper RTG ensures that a mat can conduct charge from a point on the surface to the mat ground point. The guideline in ESD STM-4.1 for RTG is 1x106 to 1x109 ohms. ANSI/ESD S20.20 requires RTG at 1x106 ohms. ANSI/ESD S20.20 requires RTT at
TM30600L1GR 价格&库存
很抱歉,暂时无法提供与“TM30600L1GR”相匹配的价格&库存,您可以联系我们找货
