16317
16317
    DESCO
    ROLL TRUSTAT B80 VINYL 30X50'
16317 数据手册
Description: 0.080" Trustat® B80 mats are 0.080" thick, extruded homogenous vinyl material. The material is designed to provide a path to ground and eliminate static charge generation when used as a worksurface table mat, shelf liner, or tray liner. The surface resistance (1 x 106 < 1 x 109 ohms Rtt) meets the ANSI/ESD S20.20 worksurface required limit and the ANSI/ESD S4.1 recommendation for contact with ESD susceptible items. Made in the United States of America Electrical Properties: Property Charge Decay: Rtt Resistance: Rtg Resistance: Test Method FTMS 101C, M 4046 ANSI/ESD S4.1 ANSI/ESD S4.1 Value
16317 价格&库存
很抱歉,暂时无法提供与“16317”相匹配的价格&库存,您可以联系我们找货
