RM48600L2RBL
RM48600L2RBL
    SCS
    ULTRA-R2 48X600 BLUE RUBBER MAT
RM48600L2RBL 数据手册
Ultra-R2 Rubber Table Mat Mat Item Numbers Meets ANSI/ESD S20.20 worksurface required limit (and recommendation of ANSI/ESD S4.1) tested per ANSI/ESD S4.1 and ESD TR53. Resistance to solvents, hot solder and soldering irons makes the Ultra-R2 Rubber Table Mat a versatile static-safe worksurface. Electrical performance is accomplished by using a two-layer combination of top color static dissipative and bottom black conductive rubber materials. Compatible with Constant Monitors. Available in rolls, mats and mats with ground cord. Size Blue Gray 24" x 36" (0.6 m x 1.2 m) RM2436L2RBL RM2436L2RGR 24" x 48" (0.6 m x 1.2 m) RM2448L2RBL RM2448L2RGR Made in the United States of America Mat Includes: 1 Table Mat, size as specified 2 3050 Snap Fasteners (installed) Table Mat Kit Item Numbers Size Blue Gray 24" x 36" (0.6 m x 1.2 m) RM2436L2RBL-L RM2465L2RGR-L 24" x 48" (0.6 m x 1.2 m) RM2448L2RBL-L RM2448L2RGR-L Table Mat Kit Includes: 1 Table Mat, size as specified 1 3040 15' (4.6 m) Ground Cord 2 3050 Snap Fasteners (installed) Roll Item Numbers Properties Typical Value Thickness* 0.064ʺ (1.6 mm) Color* Blue/Black and Gray/Black Resistances Surface to Ground (Rtg) Surface to Surface (Rtt) 1 x 106 to < 1 x 109 ohms 1 x 106 to < 1 x 109 ohms Tolerance Test Method ANSI/ESD S4.1 ANSI/ESD S4.1 Width +/- 0.250" Length +/- 0.250" *Color, texture and thickness may vary between lots and mills. Size Blue Gray 2' x 50' (0.6 m x 15.2 m) RM24600L2RBL RM24600L2RGR 3' x 50' (0.9 m x 15.2 m) RM36600L2RBL RM36600L2RGR 30ʺ x 50' (0.8 m x 15.2 m) RM30600L2RBL RM30600L2RGR 4' x 50' (1.2 m x 15.2 m) RM48600L2RBL RM48600L2RGR Includes roll of matting material. Specifications and procedures subject to change without notice. ULTRA-R2 RUBBER TABLE MAT 926 JR Industrial Drive, Sanford, NC 27332 WEB SITE: StaticControl.com PHONE (919) 718-0000 © 2015 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER Ultra-R2 Series DATE August 2015
RM48600L2RBL 价格&库存
很抱歉,暂时无法提供与“RM48600L2RBL”相匹配的价格&库存,您可以联系我们找货
