66090
66090
    DESCO
    RUBBER DISS BEIGE .060 48X40'
66090 数据手册
Description: Statfree® Type T2 meets the worksurface requirements of ANSI/ESD S20.20 and EIA-625. This material is a dual purpose rubber matting material. The two layer construction allows it to be used as a dissipative or a conductive matting product. The soft dissipative layer makes an excellent table mat, ideal for use in soldering and assembly areas. This rubber material has superior resistance to heat, abrasion, chemicals, and is easy to clean and maintain. Statfree® Type T2 material will not melt and does not burn when coming into contact with hot metal parts or soldering debris. It is amine, chloride, sulfide, alumina, and magnesia free. Statfree® Type T2 is suitable for use with continuous monitors. Statfree® Type T2 is manufactured without any ozone depleting substances, and in accordance with the Montreal Protocol. Electrical Properties: BLUE, DARK GREY, BEIGE, DARK BLUE Disclaimer: All statements, technical data, and recommendations contained herein are based upon tests we believe to be reliable. However, the accuracy or completeness thereof is not guaranteed. The proper and correct applications of products and data is the responsibility of the user. Statements or recommendations not contained herein shall have no force or effect unless embodied in a written agreement signed by authorized offers of Desco Industries, Inc. Tolerances: Width +/- .250" Length +/- .250" every 1 linear foot of running material. Property RTT Resistance: RTG Resistance: Charge Decay: Test Method ESD S4.1 ESD S4.1 FTMS 101C, Method 4046 Value 106 - 108 Ohms 106 - 108 Ohms 0.01seconds Electrical Properties obtained by testing to industrial standards by an independent testing laboratory @ 100 Volts and 50% relative humidity unless otherwise specified. Complete text of the test report is available upon request. Limited Lifetime Warranty: Desco warrants for one year that Statfree® matting products will be free of defects in materials and workmanship and will guarantee dissipative/ conductive mat properties for the life of the mat. Damage to matting caused by misuse of any kind, including using inappropriate cleaners is not covered by Desco Limited Warranty. Specifications: Construction: Thickness: Color:* Texture:* Weight: Hardness: Heat Resistance: Chemical Resistance: Dual-layer rubber material 0.060" (1.5mm) Blue, Dark Blue, Dark Grey, Beige (top), Black (bottom) Slight embossed 0.43 lbs./sq. ft. (0.2g/cm2) 65 ± 5 Shore “A”, per ASTM-D2240 Does not melt or burn when coming into contact with hot solder and soldering irons. Resistance to degradation by inorganic acids, organic acids, reducing agents, aliphatic hydrocarbons, mineral oil, aldehydes, and amines *Color and texture may vary between lots and mills See reverse side for available mat and roll sizes. Grounding: This material must be properly grounded for optimum electrical performance. Ask for Technical Bulleltin TB-2000 for mat grounding instructions. Cleaning: Use only ESD mat cleaner such as Reztore™ Surface & Mat Cleaner to clean and extend mat useful life. Do not use cleaners contaiing silicone as silicone will create an insulative film on the surface. Do not sue solvent based cleaners as solvents will dry out matting and may cause curling. Made in America STATFREE® MATERIAL, DISSIPATIVE, RUBBER, 2-LAYER, 0.060" (1.5mm) DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: www.desco.com PHONE (909) 627-8178 FAX (909) 627-7449 DESCO EAST: 90 HUDSON RD, CANTON, MA 02021-1407 PHONE (781) 821-8370 FAX (781) 575-0172 © 2005 DESCO INDUSTRIES INC. Employee Owned MATERIAL TYPE T2 DRAWING PM-104 DATE: 4/05 Item Number Reference For Statfree® Type T2 Rubber, Dissipative, 2-Layer KITS Mat Top Kit Item Numbers SIZE BEIGE BLUE DK. GREY DK. BLUE 24" x 36" 66030 66040 66050 66051 24" x 48" 66035 66045 66055 66056 Look for the Statfree® brand on Desco ESD matting. All Desco mat top kits are permanently marked for your protection and auditing purposes. MAT TOP KIT INCLUDES 1 Benchmat, Type T2, size as specified 1 09826, common point ground cord 1 09864, universal snap kit ROLL STOCK Roll Stock Item Numbers 0.060" (1.5mm) THICK ROLLS Type T2 Is Also Available In Full Rolls SIZE BEIGE BLUE DK. GREY DK. BLUE 24" x 40' 66060 66070 66080 66081 30" x 40' 66115 66110 66105 66106 36" x 40' 66065 66075 66085 66086 48" x 40' 66090 66095 66100 66101 Hardware is not included with rolls. As a general rule, continuous runs of ESD matting should be grounded at ten-foot intervals to ensure path-to-ground and not substantially increasing RTG. Each individual ESD mat should be grounded with ground snap located no further than five feet from either end. © 2005 DESCO INDUSTRIES INC. Employee Owned Matting materials have a tendency to shrink slightly when first unrolled. In applications where length is critical, allow the material to relax for at least 4 hours before cutting to size. Always trim with a sharp knife or razor blade.
66090 价格&库存
很抱歉,暂时无法提供与“66090”相匹配的价格&库存,您可以联系我们找货
