40932
40932
    DESCO
    MAT COND BUBBLE .50X36X48" BLK
40932 数据手册
Electrical Properties: Property RTT Resistance: RTG Resistance: Test Method ESD-S7.1 ESD-S7.1 Specifications: Value 103 - 105 Ohms 103 - 105 Ohms Thickness: Color:* Texture:* Electrical Properties obtained by testing to industrial standards by an independent testing laboratory @ 10 Volts and 50% relative humidity unless otherwise specified. Complete text of the test report is available upon request. Black 0.50" (12.7mm) Black Bubble cells *Color and texture may vary between lots and mills Grounding: This material must be properly grounded for optimum electrical performance. Ask for Technical Bulletin TB-2000 for mat grounding instructions. Disclaimer: All statements, technical data, and recommendations contained herein are based upon tests we believe to be reliable. However, the accuracy or completeness thereof is not guaranteed. The proper and correct applications of products and data is the responsibility of the user. Statements or recommendations not contained herein shall have no force or effect unless embodied in a written agreement signed by authorized offers of Desco Industries, Inc. Cleaning: For optimum electrical performance, surface must be cleaned regularly using an ESD mat cleaner. Desco suggests using our Reztore™ Surface & Mat Cleaner Item #10435 or Static-Wipes Item #10600. Do not use cleaners with silicone. Silicone buildup will create an insulative film on the surface. Description: This material is designed primarily to be used as a floor runner or to protect an entire room. The unique anti-fatigue dome/support cells provide extra comfort and prevent the mat from shifting on the floor. Its interlocking strip can be easily trimmed to give clean beveled edges. Statfree i™ will not trap moisture underneath. Its patented structure allows air to circulate under mat to eliminate mold or mildew problems. It will not delaminate. The rubber material is heat, abrasion, and chemical resistant. 0.5 0" Sections are Interlocking 0.50" (12.7mm) Thick Sections Desco warrants for one year that Statfree® matting products will be free of defects in materials and workmanship and will guarantee dissipative/ conductive mat properties for the life of the mat. Damage to matting caused by misuse of any kind, including using inappropriate cleaners is not covered by Desco Limited Warranty. Item 40932 features a drain-through, which is ideal for areas having liquids present. Statfree i™ meets the ESD protective flooring requirements of ANSI/ESD S20.20 and EIA-625. Statfree i™ is a manufactured rubber article and is excluded from the requirements of M.S.D.S. as defined by OSHA 29 CFR Ch. XVII §1910.1200. Tolerances: Width +/- .250" Length +/- .250" every 1 linear foot of running material. Limited Lifetime Warranty Item No. Description 40930 24" x 36" (0.6m x 0.9m) Section 40931 36" x 48" (0.9m x 1.2m) Section 40932 36" x 48" (0.9m x 1.2m) Section, with Drain Through STATFREE i™ FLOOR MAT, CONDUCTIVE, RUBBER MODULAR, 0.50" (12.7mm) DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: www.desco.com PHONE (909) 627-8178 FAX (909) 627-7449 DESCO EAST: 90 HUDSON RD, CANTON, MA 02021-1407 PHONE (781) 821-8370 FAX (781) 575-0172 © 2005 DESCO INDUSTRIES INC. Employee Owned Made in America MATERIAL STATFREE i™ DRAWING PM-107 DATE: 4/05
40932 价格&库存
很抱歉,暂时无法提供与“40932”相匹配的价格&库存,您可以联系我们找货
