66184
66184
    DESCO
    MAT RUBBER ECON BLU 0.080X24X36"
66184 数据手册
Specifications: Construction: Thickness: Texture:* Colors:* Two Layer Rubber 0.060” (1.5mm) -0+10% Smooth on both sides Dark Blue (top) and Black (bottom) Made in America *Color, texture, and gauge may vary between lots and mills Grounding: This material must be properly grounded for optimum electrial performance. Cleaning: For optimum electrical performance, surface must be cleaned regularly using an ESD mat cleaner. We suggest using our Reztore™ Surface & Mat Cleaner Item #10435 or Static-Wipes Item #10600. Do not use cleaners that are not specifically designed for ESD control use. As they can contain chemicals and/or leave residue that will alter the ESD and physical properties. Electrical Properties: Dark Blue Description: Two Layer Rubber meets the worksurface required limits of ANSI/ESD S20.20 of < 1 x 10E9 ohms. When properly grounded, the purpose of the Two Layer Rubber worksurface is two-fold. (1) To provide a surface where electrostatic charges are limited, and (2) To provide a surface that will remove charges from all conductors (including ESD susceptible devices and assemblies) that are placed on the surface. Where potential CDM (Charged Device Model) damage is a concern, the worksurface should have a lower limit of 1 x 10E6 ohms removing charges at a slower rate. Surfaces that are
66184 价格&库存
很抱歉,暂时无法提供与“66184”相匹配的价格&库存,您可以联系我们找货
