Specifications:
Construction:
Thickness:
Texture:*
Colors:*
Two Layer Rubber
0.060” (1.5mm) -0+10%
Smooth on both sides
Dark Blue (top) and Black (bottom)
Made in America
*Color, texture, and gauge may vary between lots and mills
Grounding: This material must be properly grounded for optimum electrial performance.
Cleaning: For optimum electrical performance, surface must be cleaned regularly using an ESD mat cleaner. We suggest using our
Reztore™ Surface & Mat Cleaner Item #10435 or Static-Wipes Item #10600. Do not use cleaners that are not specifically designed for ESD
control use. As they can contain chemicals and/or leave residue that will alter the ESD and physical properties.
Electrical Properties:
Dark Blue
Description:
Two Layer Rubber meets the worksurface
required limits of ANSI/ESD S20.20
of < 1 x 10E9 ohms. When properly
grounded, the purpose of the Two Layer
Rubber worksurface is two-fold. (1) To
provide a surface where electrostatic
charges are limited, and (2) To provide
a surface that will remove charges from
all conductors (including ESD susceptible
devices and assemblies) that are placed
on the surface. Where potential CDM
(Charged Device Model) damage is a
concern, the worksurface should have a
lower limit of 1 x 10E6 ohms removing
charges at a slower rate. Surfaces that
are
很抱歉,暂时无法提供与“66186”相匹配的价格&库存,您可以联系我们找货
