09814
09814
    DESCO
    CORD GROUND 15' FOR 10MM STUD
09814 数据手册
Made in the United States of America 0.320" Key: A. 10mm (0.395 in.) male threaded snap to attach to mat (alternate attachment to female socket snap – not included with 09813 / 09814). B. Molded in black thermoplastic elastomer. C. Wire High flex strand copper, 20 gauge, with PVC insulation. OD = 0.107" 09813 - Wire insulation Color: Black 09814 - Wire insulation Color: Green with yellow stripe D. Ring terminal, 0.200" ID, (#10). E. Extra ring terminal provided for customizing length. F. Item 09813 has a one megohm resistor between the snap and wire. Item 09814 has no resistor between the snap and wire. G. Brass crimp secures conductors and provides strain relief. H. Desco logo molded onto cap on top of shroud. I. Date coded to show month and year of manufacture. Arrow points to month of manufacture (12:00 = December), numerals indicate the year (10=2010). J. 6-32 x 1/4" flat head screw and washer allow mat ground cord to be bolted to most mats by shorter or alternate longer screw (x 3/8" long) depending on mat thickness. Item Wire Insulation Color Resistance 09813 Black 1 megohm (±5%) 09814 Green / Yellow No Resistor 14234* Black 1 megohm (±5%) *Includes 09813 and 6-32 x 1/4" flat head screw, 6-32 x 3/8" long flat head screw, and female socket snap. Screw allows ground cord to be bolted to mat to keep cord from disconnecting. NOTE: Use a punch or Philips screw driver to create a hole in the mat. Unless otherwise specified tolerance ± 10% 14234 kit includes female universal snap kit. Specifications and procedures subject to change without notice. GROUND CORD, MAT, THREADED 10MM SNAP STUD DESCO WEST:3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 ©2017 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 09814 DATE: May 2017
09814 价格&库存
很抱歉,暂时无法提供与“09814”相匹配的价格&库存,您可以联系我们找货
