23312
23312
    DESCO
    WRSTSTRP ECON ADJ 6' 4MM
23312 数据手册
H B I A J BACK D C E G F WRIST STRAP: A. Stamped 4mm (nominal) stud. To fit 4mm (nominal) spring loaded medical snap socket. B. Easy to open plastic clasp secures elastic material in place, and allows the user to easily adjust the wrist band size. Maintains electrical continuity even when open. C. Non-allergenic stainless steel base plate, provides excellent skin contact, for superior grounding. D. Insulating cap, thermoplastic. Band Circumference: E. Soft elastic band. Min: 3" 76mm GROUND CORD: F. Barrel type banana plug. Fits industry standard banana jack 4.22mm (nominal). G. Metallized, high flex tinsel, black jacket. H. Alligator clip included. I. Spring loaded snap socket. J. One megohm, resistor, molded within snap assembly, limits current for operator safety. *The color of the band material may vary.* Max: 15" 381mm Width: 0.75" 19mm Item Description 23311 Wrist Strap, Economy, Adjustable, 12 ft Cord, 4mm 23312 Wrist Strap, Economy, Adjustable, 6 ft Cord, 4mm Specifications and procedures subject to change without notice Wrist Strap, Adjustable, Economy ESD SYSTEMS.COM 432 NORTHBORO ROAD CENTRAL MARLBORO, MA 01752 USA TEL. (508) 485-7390  FAX (508) 480-0257  ©2010 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER TD-23311 DATE May 2010
23312 价格&库存
很抱歉,暂时无法提供与“23312”相匹配的价格&库存,您可以联系我们找货
