4 mm
Machined Studs
Adjustable Clasp
3.5 mm
Mono Plug
4 mm
Sockets
“If any part of the loop should open (become disconnected or have out of limit
resistance), the circuit will go into the alarm state” [ref TR20.20], nonetheless,
due to the redundancy inherent in the dual wire wrist strap design, the
operator will continue to be grounded via the second intact wire.
Per ESD Handbook TR20.20 section 5.3.9.2.2 Dual Conductor Resistance
Continuous Monitors, “This type of monitor is used with a two wire (dual
conductor) wrist strap. The wrist strap assembly consists of a two-wire ground
cord and a wristband that has two isolated halves. When a person is wearing
the wrist strap properly, the monitor measures the loop resistance consisting
of one wire of the ground cord, one-half of the wristband, the person’s skin,
the second half of the wristband, and a second wire in the ground cord. If
resistance), the circuit will go into the alarm state.
ESD Handbook TR 20.20 paragraph 5.3.2.4.4 Test Frequency “Because wrist
straps have a finite life, it is important to develop a test frequency that will
guarantee integrity of the system. Typical test programs recommend that wrist
straps that are used daily should be tested daily. However, if the products that
are being produced are of such value that knowledge of a continuous, reliable
ground is needed, and then continuous monitoring should be considered or
even required”
Continuous Monitors pay for themselves improving quality, productivity,
eliminating wrist strap daily testing and test result logging. Per ESD-S1.1
paragraph 6.1.3 Frequency of Functional Testing “Daily [Wrist Strap] testing
may be omitted if constant monitoring is used.”
Improve wrist strap contact with Reztore™ ESD Hand Lotion
• Used with resistive loop technology continuous monitor, continuously verifies the
proper resistance to ground of the operator
• Comfortable adjustable wrist band made of silver suffused monofilament
conductive interior
• 304 stainless steel back plate
• Woven Silveron™ fabric infused with silver monofilament conductive fiber is
comfortable and hypo-allergenic
• Patented* dual wire technology
• Superior warranty - See details of 1 year Limited Warranty
http://www.Desco.com/LimitedJewelWarranty.aspx
• Superior quality product Made in America at our Chino CA facility
• UL listed
Cleaning
For proper operation, the wrist strap, especially the wrist band, must be kept clean.
All wrist band should be cleaned with a mild detergent on a periodic basis.
Use patented* Dual Wire Wrist Strap with Desco’s Dual Wire Continuous Monitor,
3M monitors, or other brands which use 3.5 mm mono plug.
Minimum
Circumference
Maximum
Circumference
19691 ADJ. Wristband only, 4mm male snaps
4.5 in
12 in
09163 ADJ. Wrist Strap, 4mm male snaps, w/ 6' coil cord
4.5 in
12 in
09164 ADJ. Wrist Strap, 4mm male snaps, w/ 12' coil cord
4.5 in
12 in
Item
Description
See drawing 09160 for details on the Jewel® coil cords.
Thermoplastic elastomer strain relief molded on. Flex life average >11,700,000 cycles (per ESD
S1.1 Bending Life Test, greatly exceeding the 16,000 average cycle requirement). Break load
average 30 pounds.
Meets ESD S1.1 breakaway force requirement >1 pound
很抱歉,暂时无法提供与“19691”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+96.429061+12.47090
