17222
17222
    DESCO
    FOOT GROUND TOE
17222 数据手册
Description: B 90P1 D LISTED C A The 17222 Toe Ground provides a continuous ground path between an operator and a properly grounded ESD protected flooring. These toe grounders are designed for use on standard shoes, including high heeled shoes. They can be easily adjusted to fit most wearers. Desco’s toe grounders have a lining that prevents carbon marks on shoes. Toe grounder model 17222 has a discrete one megohm resistor built into the contact strip. The product has been tested to ESD STM 97.2 - Floor Materials and Footwear Voltage Measurement in Combination with a Person. It is a suitable ESD footwear component in Flooring - Footwear System when used as the primary grounding method (
17222 价格&库存
很抱歉,暂时无法提供与“17222”相匹配的价格&库存,您可以联系我们找货
