14114
14114
    DESCO
    CORD COILED BLACK BANANA 20'
14114 数据手册
Made in the United States of America Banana-Banana Coil Cord allows cart users to ground carts to common grounding point on a bench. A. Patented* barrel type banana plug with machined contour spring support. Crimped uniformly from 4 sides for maximum strength. Fits industry standard banana jack ≥ .157". Will maintain greater than 1 pound disengagement force over the life of the cord. ITEM 14113 14114 Retracted Length X 24" 30" Y 32" 38" B. Thermoplastic elastomer strain relief molded on. Bending Life Test average >1,000,000 cycles per ANSI/ESD S20.20 (Tested per ESD S1.1). Break load average 30 pounds. C. Wire insulation black color PVC. Break load average 30 pounds. D. Single T-2940 tinsel conductor. Consisting of 7 strands of polyester wrapped with copper. High flex life. Equivalent is 29 gauge (cir mil and/or ohms). Extended Length Nominal 12' 15' Max 17' 22' Unless otherwise noted, tolerance is ±10% Specifications and procedures subject to change without notice. *U.S. Patent 5951337 Relaxed Retraction Coil Cords DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 FAX (909) 627-7449 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 FAX (781) 575-0172 ©2011 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 14113 DATE: September 2011
14114 价格&库存
很抱歉,暂时无法提供与“14114”相匹配的价格&库存,您可以联系我们找货
