A. Right angle barrel type banana plug with patented* machined contour spring
support. Fits industry standard banana jack ≥ .157”. Will maintain greater than
1 pound disengagement force over the life of the cord.
B. Crimped termination to stranded conductor.
C. Thermoplastic elastomer strain relief molded on. Bending Life Test average
>50,000,000 cycles per ANSI/ESD S20.20 (Tested per ESD S1.1). Break load
average 30 pounds.
D. Polyurethane wire insulation in Jewel® Sapphire color. Rapid retraction coil
cord compresses length with resulting benefit of less tangling and dragging
along work surface. Break load average 30 pounds.
E. Tinsel conductor. Consisting of polyester wrapped with copper. High flex life.
Equivalent is 29 gauge (cir mil and/or Ohms).
F. Autosplice brass crimp secures conductors to resistor lead and provides stress
relief for resistor.
G. One megohm ±5%, 1/4 watt, series resistor limits current for operator safety.
H. Spring loaded 4mm medical snap socket. Spring separation .125” - .165”.
Provides 1-5 pound breakaway from .160” snap stud (EOS/ESD-S1).
Made in America
ITEM
09150
09151
Retracted Length
X
10”
16”
Y
27”
33”
Extended Length
Nominal
6’
10’
Max
8.5’
13’
Compatible with most major brands.
I. Jewel® logo molded in compliance with EOS/ESD-S1.
J. Date coded with date of manufacture.
K. Underwriters Laboratory Listing 90P1C when used with Desco 09025, 09026,
09027, 09028, 09041, 09043, 09044, 09045, or 14840 wristbands.
L. Right angle design has lower profile, making it less likely to be snagged and
accidentally pulled out. Swivels on banana barrel for less strain - extending the
life of the cord.
M. Ribbed molding assists grasping of right angle banana plug. The plug will not
be removed by tugging on cord.
Jewel® Lifetime Limited Warranty
Desco expressly warrants that for a period of 1 year from the date of purchase, Desco Jewel® Wrist Straps
and Coil Cords will be free of defects in material (parts) and workmanship (labor). In addition, normal use will
not cause Coil Cord resistor strain relief connection or Wrist Band 4 mm snap stud to wear sufficiently to open
path-to-ground circuit. Within the lifetime warranty period, a credit for purchase of replacement Desco Jewel®
products, or, at Desco’s option, the Desco Jewel® product will be repaired or replaced free of charge. If product
credit is issued, the amount will be calculated based upon the original invoice purchase price.
*U.S. Patent 5951337
GROUND CORD, WRIST STRAP, RAPID RETRACTION, COILED, RIGHT ANGLE
DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
PHONE (909) 627-8178 FAX (909) 627-7449
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE (781) 821-8370 FAX (781) 575-0172
© 2009 DESCO INDUSTRIES INC.
Employee Owned
See drawing 09105 for wristband specifications.
DRAWING NUMBER
09150
DATE:
August
2009
很抱歉,暂时无法提供与“09151”相匹配的价格&库存,您可以联系我们找货
