Made in the
United States of America
1.24"
31.51 mm
1.00"
25.40 mm
1.00"
25.40 mm
1.00"
25.40 mm
A. Cap - ABS plastic, black
B. 300 Series stainless steel back plate is .021" thick. Provides 1.0
sq. in. of skin contact surface.
C. 4mm snap stud machined from 300 series stainless steel. Fits to
4mm spring loaded medical type socket. Coil cord disengages
from snap with 1-5 lbs. of perpendicular force. Durable, providing
long life well beyond that of sheet metal snaps.
ITEM
Description
09060
Wristband only
09078
Wristband with 6 ft. coil cord
D. Nylon, hook fastener is royal blue, 25mm (1.0") wide. 25mm (1.0")
nylon royal blue loop fastener material. Functional band
circumference 6.50" min. and 10.75" max. assumes all but .50”
of hook material is trimmed off to avoid overlapping. No exposed
conductive surfaces when worn.
E. Return loop for quick and easy adjustment.
F. Sewn in non-reactive, anti-microbial, anti-bacterial medical grade
conductive strip common with stainless plate adds 4 sq. in. of skin
surface area contact.
G. Desco, Item # and Made in USA are molded into cap.
Meets or exceeds requirements ANSI/ESD S1.1 and ESD TR53.
Unless otherwise noted, tolerance is ± 10%
Specifications and procedure subject to change without notice.
WRISTBAND, HOOK AND LOOP, ADJUSTABLE
DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
PHONE (909) 627-8178 FAX (909) 627-7449
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE (781) 821-8370 FAX (781) 575-0172
© 2011 DESCO INDUSTRIES INC.
Employee Owned
DATE:
DRAWING NUMBER
December
09060
2011
很抱歉,暂时无法提供与“09078”相匹配的价格&库存,您可以联系我们找货
