19690
19690
    DESCO
    WRISTSTRAPDUALADJSNAPS6'CRD
19690 数据手册
Adjustable Clasp "If any part of the loop should open (become disconnected or have out of limit resistance), the circuit will go into the alarm state" [ref TR20.20], nonetheless, due to the redundancy inherent in the dual wire wrist strap design, the operator will continue to be grounded via the second intact wire. Per ESD Handbook TR20.20 section 5.3.9.2.2 Dual Conductor Resistance Continuous Monitors, "This type of monitor is used with a two wire (dual conductor) wrist strap. The wrist strap assembly consists of a two-wire ground cord and a wristband that has two isolated halves. When a person is wearing the wrist strap properly, the monitor measures the loop resistance consisting of one wire of the ground cord, one-half of the wristband, the person's skin, the second half of the wristband, and a second wire in the ground cord. If any part of the loop should open (become disconnected or have out of limit resistance), the circuit will go into the alarm state. ESD Handbook TR 20.20 paragraph 5.3.2.4.4 Test Frequency "Because wrist straps have a finite life, it is important to develop a test frequency that will guarantee integrity of the system. Typical test programs recommend that wrist straps that are used daily should be tested daily. However, if the products that are being produced are of such value that knowledge of a continuous, reliable ground is needed, and then continuous monitoring should be considered or even required" Continuous Monitors pay for themselves improving quality, productivity, eliminating wrist strap daily testing and test result logging. Per ESD-S1.1 paragraph 6.1.3 Frequency of Functional Testing "Daily [Wrist Strap] testing may be omitted if constant monitoring is used." Improve wrist strap contact with Reztore™ ESD Hand Lotion *U.S. Patents 6,052,053 and 6,205,408 Made in America Dual Wire Wrist Strap provides redundancy; even if one dual wire wrist strap conductor is severed, operator has reliable path-to-ground with other wire. • Used with resistive loop technology continuous monitor, continuously verifies the proper resistance to ground of the operator • Comfortable adjustable wrist band made of silver suffused monofilament conductive interior • 4mm snaps are machined to precision profile from 300 series stainless steel for a consistent and reliable connection. 7mm snaps are stamped. • 304 stainless steel back plate • Woven Silveron™ fabric infused with silver monofilament conductive fiber is comfortable and hypo-allergenic • Patented* dual wire technology • Superior resistor connection strain relief Superior reliability. Greatly exceeds ESD S1.1 Bending Life Test. Tested at over 200,000 cycles vs. the 16,000 requirement • Superior warranty - See details of 1 year Limited Warranty at http://www.Desco.com/Warranty.aspx • Superior quality product Made in America at our Chino CA facility Use patented* Dual Wire Wrist Strap with Desco Dual Wire Continuous Monitor ITEM REF. # DESCRIPTION 19690 SE5000 Adjustable Wristband, 4mm male snaps, with 6' Snap-One Coil Cord, 4mm female snaps, right angle mono plug 19851 SE5100 Adjustable Wristband, 4mm male snaps, with 12' Snap-One Coil Cord, 4mm female snaps, right angle mono plug 19861 SPR1100 Adjustable Wristband, 7mm female snaps (UL Listed) 19860 SPR1006 Adjustable Wristband, 7mm female snaps, with 6’ Dual-snap Coil Cord, 7mm male snaps, right angle mono plug See Drawing 19695 for details on Snap-One Coil Cords See Drawing 19868 for details on the Dual-snap coil cords WRISTBAND, ELASTIC SILVERON™, DUAL WIRE, ADJUSTABLE DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 FAX (909) 627-7449 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 FAX (781) 575-0172 ©2009 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 19690 DATE: March 2009
19690 价格&库存
很抱歉,暂时无法提供与“19690”相匹配的价格&库存,您可以联系我们找货
