19882
19882
    DESCO
    MAGSNAP360COILCORD
19882 数据手册
0.28" (7mm) Made in the United States of America B C E D F D G H 0.83" (21mm) 0.11" (3mm) A I Y NON-RESISTOR END X A. Underwriters Laboratory Listing 90P1C. B. Compatible with Desco Dual-Wire Continuous Monitors and other brands that accept a 3.5mm phono plug. C. Desco logo molded in compliance with ANSI/ESD S1.1. D. Thermoplastic elastomer strain relief molded on. E. Relaxed retraction coil cord reduces tug on wearer’s wrist. Black PVC insulation. Break load average 30 pounds. Item Mold Color Mono Plug Tip Diameter 19880 Black 19881 19882 Retracted Length Extended Length F. Dual T-3067 tinsel conductor. Consists of stranded polyester wrapped in copper. Equivalent to 29 gauge (cir mil and/or ohms). G. 1 megohm (±5%) current limiting resistors on both conductors. H. Unique dual contact design is to be paired with a Desco MagSnap 360™ Wristband (not included) for a superior electrical connection. The magnetic connection made with the wristband maintains a 1-5 pound perpendicular breakaway force to prevent accidental disconnects. Spring loaded center contact rated to 1 million cycles. I. Date coded with date of manufacture in compliance with ANSI/ESD S1.1. X Y Nominal Max 0.132" 12" 20" 6' 8.5' Black 0.132" 24" 32" 12' 17' Black 0.132" 30" 38" 15' 22' 19877 Grey 0.116" 12" 20" 6' 8.5' Unless otherwise noted, tolerance ±10% 19878 Grey 0.116" 24" 32" 12' 17' Specifications and procedures subject to change without notice. 19879 Grey 0.116" 30" 38" 20' 22' U.S. Patent Pending Meets required limits of ANSI/ESD S20.20 and requirements of ANSI/ESD S1.1. MAGSNAP 360™ DUAL-WIRE COIL CORD DESCO WEST: 3651 WALNUT AVE, CHINO, CA 91710 WEBSITE: Desco.com PHONE: (909) 627-8178 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE: (781) 821-8370 © 2015 DESCO INDUSTRIES INC. Employee Owned RESISTOR END DRAWING NUMBER 19880 DATE January 2015
19882 价格&库存
很抱歉,暂时无法提供与“19882”相匹配的价格&库存,您可以联系我们找货
