19857
19857
    DESCO
    WRISTSTRAP DUAL ASSY MTL EXP 4MM
19857 数据手册
Dual Wire Wrist Strap provides redundancy; even if one dual wire wrist strap conductor is severed, operator has reliable path-toground with other wire. • Used with resistive loop technology continuous monitor, continuously verifies the proper resistance to ground of the operator • Black ABS plastic cap. 19859 "If any part of the loop should open (become disconnected or have out of limit resistance), the circuit will go into the alarm state" [ref TR20.20], nonetheless, due to the redundancy inherent in the dual wire wrist strap design, the operator will continue to be grounded via the second intact wire. Per ESD Handbook TR20.20 section 5.3.9.2.2 Dual Conductor Resistance Continuous Monitors, "This type of monitor is used with a two wire (dual conductor) wrist strap. The wrist strap assembly consists of a two-wire ground cord and a wristband that has two isolated halves. When a person is wearing the wrist strap properly, the monitor measures the loop resistance consisting of one wire of the ground cord, one-half of the wristband, the person's skin, the second half of the wristband, and a second wire in the ground cord. If any part of the loop should open (become disconnected or have out of limit resistance), the circuit will go into the alarm state. • 300 series stainless steel backplate (0.015" thick). Manufacturing date code is stamped into stainless steel back plate. • 4mm snaps are machined to precision profile from 300 series stainless steel for a consistent and reliable connection. • Premium metal expansion band. Inside links are constructed of 300 Series Stainless Steel. Width of links is 0.630". • .002" polyphenylsulfone sheet is laminated to each link before assembly. Provides >5,000 volt RMS insulation per ASTM D149. Will not flake or peel. • Patented* dual wire technology • Superior reliability. Greatly exceeds ESD S1.1 Bending Life Test. Tested at over 200,000 cycles vs. the 16,000 requirement • Superior warranty - See details of 1 year Limited Warranty at http://www.Desco.com/Warranty.aspx • Superior quality product Made in America at our Chino CA facility Use patented* Dual Wire Wrist Strap with Desco Dual Wire Continuous Monitor ESD Handbook TR 20.20 paragraph 5.3.2.4.4 Test Frequency "Because wrist straps have a finite life, it is important to develop a test frequency that will guarantee integrity of the system. Typical test programs recommend that wrist straps that are used daily should be tested daily. However, if the products that are being produced are of such value that knowledge of a continuous, reliable ground is needed, and then continuous monitoring should be considered or even required" 19859 SE7500S Premium Metal Expansion Wristband, 4mm male snaps, small, with Snap-One 6’ Coil Cord, 4mm female snaps, right angle mono plug 19858 Continuous Monitors pay for themselves improving quality, productivity, eliminating wrist strap daily testing and test result logging. Per ESD-S1.1 paragraph 6.1.3 Frequency of Functional Testing "Daily [Wrist Strap] testing may be omitted if constant monitoring is used." SE7500M Premium Metal Expansion Wristband, 4mm male snaps, medium, with Snap-One 6’ Coil Cord, 4mm female snaps, right angle mono plug 19857 SE7500L Premium Metal Expansion Wristband, 4mm male snaps, large, with Snap-One 6’ Coil Cord, 4mm female snaps, right angle mono plug Improve wrist strap contact with Reztore™ ESD Hand Lotion. ITEM REF. # DESCRIPTION See Drawing 19695 for details on Snap-One Coil Cords * U.S. Patents 6,052,053 and 6,205,408 Made in America Premium Metal Expansion Dual Wire 4mm Wrist Straps DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 FAX (909) 627-7449 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 FAX (781) 575-0172 © 2009 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 19859 DATE: March 2009
19857 价格&库存
很抱歉,暂时无法提供与“19857”相匹配的价格&库存,您可以联系我们找货
