09167
09167
    DESCO
    WRISTSTRAP JEWEL DUAL ONYX 6'CRD
09167 数据手册
A E C Made in the United States of America B D G F A. Black ABS plastic cap. E. .002" polyphenylsulfone sheet is laminated to each link before assembly. Provides >5,000 volt RMS insulation per ASTM D149. Will not flake or peel. B. 300 series stainless steel backplate (0.015" thick). C. Two 4mm snap studs machined from 300 series stainless steel. Fits to 4mm spring loaded medical type socket. Coil cord disengages from snap with 1-5 lbs. of perpendicular force. Compatible with Desco Dual-Wire Coil Cords ONLY (not including MagSnap® or MagSnap360™ products). F. Black ABS plastic insulator separates band into halves. G. Underwriters’ Laboratory listed 90P1C. Meets required limits of ANSI/ESD S20.20 and requirements of ANSI/ESD S1.1. D. Premium metal expansion wrist strap. Inside links are constructed of 300 Series Stainless Steel. Width of links is 0.630". ITEM BAND SIZE CIRCUMEFERENCE MIN MAX WIDTH 5.5" (140mm) 9" (229mm) 0.630" 19842 Small Medium 6" (152mm) 11" (279mm) 0.630" 19840 Large 7" (178mm) 12" (305mm) 0.630" 19844 Specifications and procedures subject to change without notice. Unless otherwise noted, tolerance ±10% *U.S. Patents 6,052,053 and 6,205,408 See Drawing 09163 for details on Jewel® Coil Cords Jewel® Premium Metal Expansion Dual-Wire Wrist Strap, 4mm DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 FAX (909) 627-7449 DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 FAX (781) 575-0172 © 2016 DESCO INDUSTRIES INC. Employee Owned DATE: DRAWING NUMBER November 09165 2016
09167 价格&库存
很抱歉,暂时无法提供与“09167”相匹配的价格&库存,您可以联系我们找货
