A
E
C
Made in the
United States of America
B
D
G
F
A. Black ABS plastic cap.
E. .002" polyphenylsulfone sheet is laminated to each link before assembly.
Provides >5,000 volt RMS insulation per ASTM D149. Will not flake or peel.
B. 300 series stainless steel backplate (0.015" thick).
C. Two 4mm snap studs machined from 300 series stainless steel. Fits to 4mm
spring loaded medical type socket. Coil cord disengages from snap with 1-5
lbs. of perpendicular force. Compatible with Desco Dual-Wire Coil Cords
ONLY (not including MagSnap® or MagSnap360™ products).
F. Black ABS plastic insulator separates band into halves.
G. Underwriters’ Laboratory listed 90P1C.
Meets required limits of ANSI/ESD S20.20 and requirements of ANSI/ESD S1.1.
D. Premium metal expansion wrist strap. Inside links are constructed of 300
Series Stainless Steel. Width of links is 0.630".
ITEM
BAND SIZE
CIRCUMEFERENCE
MIN
MAX
WIDTH
5.5" (140mm)
9" (229mm)
0.630"
19842
Small
Medium
6" (152mm)
11" (279mm)
0.630"
19840
Large
7" (178mm)
12" (305mm)
0.630"
19844
Specifications and procedures subject to change without notice.
Unless otherwise noted, tolerance ±10%
*U.S. Patents 6,052,053 and 6,205,408
See Drawing 09163 for details on Jewel® Coil Cords
Jewel® Premium Metal Expansion Dual-Wire Wrist Strap, 4mm
DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
PHONE (909) 627-8178 FAX (909) 627-7449
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE (781) 821-8370 FAX (781) 575-0172
© 2016 DESCO INDUSTRIES INC.
Employee Owned
DATE:
DRAWING NUMBER November
09165
2016
很抱歉,暂时无法提供与“09170”相匹配的价格&库存,您可以联系我们找货
